Question about Garden
I have a Jacobson sno-burst snow blower? I need a megneto assembly part#126668 for a j-501st engine
    Top Expert:
  • Garden Master
  • 12,744 Answers
Can do an online search for part--notify a small motor --lawn and garden repair shop --
Posted on Dec 15, 2016
I have a Jacobson son burst blower n need the magneto assembly 126668
look up a small engine repair shop or online search for part
Dec 15, 2016 | Garden
Fluid levels in gear box
Amber. With machine on level surface,fill gear box with specified gear oil until it starts running out the fill hole on front of gear box.
press the helpful button and follow me on fixya for more tips
Craftsman snowblower auger gearbox lubricant
Sno Thro Engine Oil Gear Case Lube
Auger Gear Oil Sorry to ask again Snowblower Forum Snow Blower Forums
Feb 09, 2016 | Garden
Why sno thro continues to run after ice block is removed
Because that is how it's designed. It's designed to run again, after you remove ice block.
Apr 29, 2014 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Looking to see what shear pin the sno trac snowblower model 310-680502
Go to Look under who makes sno trac snow blowers. The article tell you what to do.
Mar 19, 2014 | Craftsman 16" High Garden Tractor Snow and...
Auto drive malfunction
the drive wheel is worn out or tension on the wheel needs adjustment
Feb 05, 2014 | Sno-Tek Snow Blowers. 24 in. Two-Stage...
Engine chugging
carb dirty
clean and put fresh gas in it
Dec 18, 2013 | Sno-Tek Snow Blowers. 24 in. Two-Stage...
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Auger shaft jamed
Try removing the belt and turning it by hand. If that doesn't work, you may have blown something into bits inside of the gear case.
Nov 03, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
I have a ariens 24 "sno tech it will not throw
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belt closest to the blower assembly. This is the blower drive belt. (Your operators manual will show you the location and how to remove the cover if you are unfamiliar with your snow blower)
With the engine not running, have someone depress the drive lever and check the belt. You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced. On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt)
You can get parts (the new belt) through your local Ariens dealer or
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Ariens 34 In. Zoom Series Riding Mower
I have a 7 HP Ariens snow blower Model # 910995 S # 007686. It made a popping sound and stopped yesterday. The elec start cranks but the engine won't start. Checked the engine oil, which was low and filled...
Pull the spark plug out, cover the hole with your finger and slowly pull the pull starter. You should feel compression. If not look for a blown head gasket or valve problem.
Jan 04, 2010 | RTO Sno Wovel wheeled snow shovel
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
