Question about Mtd Garden
Changing blades on 2008 mtd rideon mower,are they left hand thread or just incredibly tight.
    Dedicated:
    Visited the website for 20 consecutive days.
  • Mtd Expert
  • 242 Answers
To remove the bolt or nut turn it the same direction the blade turns when cutting. This way the bolt tightens itself as it mows not back out and slip.
Posted on Dec 15, 2016
How to change mower blades
I have seen lots of lawn tractors and never had a left hand thread. I have put a piece of two by four against the blade or vice grips as well.and put a pipe on my wrench and forced it to loosen. Oil the threads before reinstalling as well. Don't over tighten.
Sep 20, 2014 | Garden
Have difficulty removing mower blades. find it impossible to remove the nut. is it left or right hand thread ?
The threads are right hand....
wedge a block of wood into the blade to hold it
then you can really push on the nut...
also make sure you have a good fitting socket wrench
add a pipe on the handle for more leverage...
you also can heat the nut to red hot and then let it cool
which will also help to loosen it...
heatman101
Apr 02, 2011 | Mtd Garden
Replace blades on Mtd mower deck
no they are not left hand threads if nuts have molded washers you must use an impact gun. wash holds too much of blade surface and will not turn against it
Jul 17, 2010 | Yard Machines 155 Torque Briggs Stratton...
Hi , having trouble changing mtd 38
lefty loosey...use a block of wood to wedge the blade against the deck, and use a ratchet and extend it with a piece of pipe...the get real tight over time...an air gun or other impact gun works the best...
Apr 26, 2010 | Garden
Are blade mounting bolts left or right hand threaded ?
Right hand threads. I just replaced mine. The bolt will turn off in the same direction the blade turns when it is running.
Aug 08, 2009 | Mtd Arnold Corp No. Mtr - 42 - Ec 42" Mwr...
How do I change the blades on a mtd yard-man 42" riding mower
u do not have to remove the deck. all u need is a floor jack and some air pressure because the bolts may be very tight u will needs either a 7/8 or 13/16 socket and they come off normal lefty loose righty tight. good luck
Jul 08, 2009 | Mtd Products Yard Machines 158CC Tiller
My deck cuts shoter on the rt,ie uneven
Check your tire pressures:
10 psi. for rear tires.
14 psi. for the front.
Note that according to MTD:
Making sharp right hand turns. Twin-blade mower decks are designed with the discharge on the right side and two side-by-side blades. The side-by-side twin blade decks have the left hand blade positioned slightly forward and in front of the right blade. This provides cutting overlap when traveling in a straight line. As a result, the tractor should mainly operated making primarily left hand turns when cutting. During left turns this cutting overlap is maintained. If turning right when, it is possible to negate this overlap and leave an uncut strip.
May 31, 2009 | Mtd LAWN MOWER PART # 683-0439A DECK...
How to change blade
Most are right-hand threads, but pretty tight.
You might need to wear gloves to hold the blade, and a long-handled ratchet & socket to loosen the bolt,(after you disconnect the spark plug ,of course)
Apr 25, 2009 | Garden
Garden Logo
37 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
