Question about Garden
I have a Jacobson son burst blower n need the magneto assembly 126668
    Top Expert:
  • Garden Master
  • 14,335 Answers
Look up a small engine repair shop or online search for part
Posted on Dec 15, 2016
I have a Jacobson sno-burst snow blower? I need a megneto assembly part#126668 for a j-501st engine
can do an online search for part--notify a small motor --lawn and garden repair shop --
Dec 15, 2016 | Garden
So you don't have echo
No Spark can be one of 3 faults.
The wire to the spark plug is either shorted somewhere along its length. An open circuit along the wire coming out of the magneto or
the magneto is not generating a spark.
Best way to test for a spark is to use a neon test lamp.
Hold one end and bring the other end close to high voltage wire under test. Test on your running car first.
Trace the HV wire back to the magneto on side of engine. rotate engine by hand to get magneto to generate a current. Remove spark plug to allow engine to rotate easier without compression.
The high voltage is generated from a coil inside magneto assembly.
Good Luck
Trevor
Aug 17, 2014 | Garden
My Craftsman 4 cycle leaf blower stalls after short use and appears to over heat
if it is not starting back after it is hot you have to check magneto ,, check and see if it is firing if not magneto bad,,,first just try cleaning it up good with air hose,, hope this help
Apr 15, 2013 | Craftsman 4 Cycle Blower/Vac
Will not fire after replacing spak plug
if it will not spark after the plug change, then you need to go deeper to the coil, and the magneto, alot of times the magneto plate just needs to be sanded or wire brushed.
Nov 13, 2010 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Homelite yard broom starts a clicking noise then power loss. Power may come back for short bursts and clicking ceases during these times.
Suspect the blower fan is loose on the crankshaft.
Open the housing on the fan side and check mounting nut. If this is the case, remove the nut, apply one or two drops of Loctite-Thread-Locker (in the blue package) to the crankshaft threads and reinstall the nut.
Hope this helps.
Oct 04, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite ht-17 magneto
Go to Gardnerinc.com and click on consumer. Then click on partsmartweb. On the left side of this page change your selection from Kohler to Homelite Consumer Products and enter your model number. You have it as HT 17. This brings up a lot of different equipment so I would enter just part of the serial number or the ut number. This is located on the body of the trimmer on a silver tag.
This will take you to the parts illustration and parts list for your trimmer.
Jun 23, 2009 | Homelite 'Yard Broom' Leaf Blower
Poulan Pro 200 Leaf Blower won't start. I have installed a carb kit with no results. The spark plug was wet before the new kit---it continues to be wet. I have tried a replacement spark plug with no...
Alright, remember that 2-Stroke motors are meant to do 2 things:
Break down, then Frustrate you.
So, here we go: (Electrical)
Rotor Magnets, Magneto (ignition coil), Spark Plug Wire, Spark Plug, Spark Plug Ground (Cylinder Head).
In that order!
Check your "fire" from the Magneto:
1. Check your Kill Switch. In other words, leave everything normal, and unhook it. Did she start? Kill Switch it is! Kill Switch/Wire comes from the Magneto (single wire/ground) to the Switch itself. So check that wire AT the Magneto (Is it loose and grounding out? Is the Kill Switch grounding you out where it is, because of crud, junk, or because it is touching the block when it is not supposed to?)
2. Check your Spark Plug Wire. Easy, unook it from the plug, stick your finger in, give it a crank (non-MultiMeter way). Did you get shocked? Then it ain't your Plug Wire and Magneto!
With a Multi-/Volt Meter, simply hook her up, and check for juice WHEN you pull the rope. If you got juice, it ain't your Plug Wire or Magneto!
Checking Spark the "normal" way: Grab the Plug with a pair of insulated pliers, hold the plug end against the cylinder head, and pull your rope. Any Spark? What color?
3. STILL no fire. It leaves: Magneto and Plug Wire.
Luckily, they are both in the same place! Tear your blower down, and check to see if the Magneto has slipped out of place (gap is WAY out), or if the Plug Wire has worn to the point it is grounding you out. While you are there, check your Kill Switch wire, to see if she is grounding you out then and there.
4. STILL no fire. That means: Magneto Failing, or Magneto JUNK.
Buy another one, replace it! (Or steal one from another junk Blower/Weedeater. These things are fairly standard, and easy!)
Or, Bad Plug Wire. Meaning she has failed out on you.
Wait......that means: Replace your Magneto! Lucky the things are built together right?
Apr 22, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Does timing have to be adjusted ? (1989 7- 1/2 Hp Snow Blower)
hello it sound's like you need to ajust you carb. air flow . your gas mix is to rich. and it has a magneto .? you say. they have no setting . they are held in place with a keypin or can be called a wedge pin. and the fly wheel has a notch cut in ti so it can only go on one way. so try rebulding you carb. and that hould fix it. well "GOOD LUCK". let me know if this help's you . and THANK YOU . for using FIXYA.COM
Jan 03, 2009 | 2000 Jeep Grand Cherokee
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
