Question about GPS
LMF-400 Frozen screen displaying-"ERROR" "Reprogram correct SW version All buttons inoperative?
Connected to NMEA2000 via GPS HDS8
  • 790 Answers
SOURCE: motorola v6
re format your v6 to software...
Posted on Sep 14, 2007
  • 93 Answers
SOURCE: Motorola L7 No disply
Hello, your firmware became corrupt. You need to go to a service center and have the device flashed. It should take only 15 min to flash and should be covered under warranty by the provider or manufacture. If you have no service center near by or its not covered under warranty for whatever reason, check my profile and im sure we can help you.
Posted on Jan 24, 2008
  • 6 Answers
SOURCE: remote appears frozen
I got the same issue with mine, and hooking to the computer and upgrading the firmware worked for me. I first had to take the bateries out and let it sit for 24 hours so it would loose the codes inside. No problems after that.
Posted on Jan 31, 2008
  • 2130 Answers
SOURCE: My Garmin Nuvi670 (brand New
This is not correct. This indicates that there is a problem with the satellite receiver. There should always be a number assigned to the GPS S/W version. If it returns a value of 0.0 this is a problem. If your unit is new, take it back to the store or call Garmin.
- Jim
Posted on Nov 01, 2008
SOURCE: buttons and screen not responding on via michelin x-950t sat nav
stick a pin in the reset hole in the back.that should fix the problem.
Posted on Mar 10, 2009
Lowrance gps problems
The device may need updating,
They were a similar issue with tomtom and the units needed a simple update to allow them to find the GPS.
Jul 31, 2014 | Lowrance Insight USA HDS8
My Finedrive 400 GPS displays the following error message Error Wrong file version Data File az bin 1=aze2 if I manage to get out of that screen the home screen comes on and if I select the...
i would download the latest firmware update from the makers website for your model ok then test it sound like corepted system file so redo it thx nick
Mar 17, 2008 | GPS
The GPS antennas are sealed so I don't see why they would ask if you sprayed the hose at won't matter. I did some fishing this past year in the Keys on a boat with the same system you have and I scrubbed the GPS antenna and sprayed it directly with water and it did not have water intrusion.
Do you know which GPS antenna you have? Also, do you have any other equipment that may be interfaced to the MFD? I am assuming that you have a NMEA2000 antenna (model GP330B). If this is the case I would first check the NMEA2000 backbone. If you don't know what that is look for some cables all plugging together via Tees. there will be 2 cables per tee and the tees plug together. Make sure that there is a terminator at the end of the tee block. If you have the NMEA2000 antenna the other terminator should be in the antenna itself.
Do you have the engine interface wired to the MFD? If so, unhook that wire. I have seen some really weird things happen if the engines are sending some information back to the display.
We have installed many of these systems and the only failures I have seen are people damaging the radar antennas. The systems we have installed have been bulletproof for the most part.
Aug 24, 2010 | Furuno NavNet 3D Hub
Nuvi is frozen on warning screen. Won't reset by hoding power but
If you haven't already done so, I would suggest you connect to, register your device, and download/install the WebUpdater.
Then connect your unit to your computer using the USB cable that was included. This will start your unit in a very different mode (it will appear as a storage device to your computer), which WebUpdater will recognize. WebUpdater will check the current release level of your unit's software and let you update it to the latest version. The update process may well cure the problem when next you start the unit in GPS mode.
Good luck.
Jan 25, 2010 | Garmin nuvi 255W GPS Receiver
Buttons and screen not responding on via michelin x-950t sat nav
Mar 01, 2009 | SNK ViaMichelin Handheld GPS Receiver
Frozen tomtom
You can get your original splash scren from here. You can also download free splash screens created by user through TomTom HOME.
To correct your device, try:
1. Hit the reset button on the back of the device - inside the serial connector.
2. Make sure the device is off and connect it to your computer via USB dock and connect the charging cable (green light should be on)
3. Hold down the power button until the device restarts.
4. The device should automatically connect to your computer.
5. Run TomTom HOME and check for any updates.
6. If there is no new application, try: <-- that will show you how to remove and then reinstall the application.
Dec 22, 2008 | Tomtom GO 510 GPS Receiver
Raymarine C120
You need to download the latest software version from which turns on nmea2k.
Jul 24, 2008 | Raymarine C120 System Pack C120 Raystar...
GPS Error Message on Start Up Model GM-7-1
sounds like your firmware or sd card is corrupt, unfortunately this is common on these. I created a dvd with the map and program data to reload everything in your unit, it also updates the map data to the last version issued. you can find it in ebay by searching for finedrive 400 map...
Jun 01, 2008 | Fine Digital FineDrive 400 GPS Receiver
By David707,
Since posting ma last re: Screen Freezing on external charge; I did manage to get the system back to some normality by pressing the Reset button located underneath the GPS Antenna flap. However this is likely to delete personally stored data on the system.
I should also state that the same problem occurs when I connect the 610 t my PC via the USB connection (another way to externally charge the battery).
A more satisfactory answer required though.
Dec 28, 2007 | Garmin nuvi 260W GPS Receiver
GPS Logo
37 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
