Question about Home
I am looking for a manual for a wood stove manufactured by a company called Heritage Stove Company LTD. for a stove I found lately a model #24 built and tested in Aug. 15, 1980?
  • 41 Answers
SOURCE: GE TrueTemp Gas Stove
Not sure that I can help but will give it a go. Often the igniter plastic covering comes off the wiring from the heat of the oven and the igniter arcs on a metal surface on the oven. I had this problem with a gas oven I had. Check along the igniter wiring to see if it is arcing. Best way to find it is to firstly locate the wiring then ignite the oven WITHOUT THE GAS ON. If it is arcing you should be able to see a little flash. Check to make sure it is flashing at the right spot first near the pilot. Easiest way to rectify this problem is to wind electrical tape around the igniter providing you can get to the wire. If you have to pull out the igniter you can buy a plastic product called Heatshrink from places like Tandy or Electrical Hardware Stores. Just put some Heatshrink or Electricians Tape around it and it should solve the problem. Only other thing it could be is the igniter needs replacing. Hope this helps.
Posted on Feb 28, 2008
SOURCE: GE Profile JGB916
LP or natural? Are the valves set correctly for such and the regulator value changed if a different gas is used than what the manufacturer set the stove up as?
Good Luck...
Posted on Jul 08, 2008
  • 1136 Answers
SOURCE: can fix Gas leak smell in GE Eterna stove: Model EGR3000EH1BB
If it was used with LP and you are using it with natural, did you change everthing back over to natural gas settings? Orfices, regulator cap, and oven orfice?
It could be a pressure issue.
Please let me know if I can assist you further.
Posted on May 30, 2009
  • 1326 Answers
SOURCE: I need to ge my stove lit
Does it have electronic ignition (clicking sound when starting) if it doesnt and you have an older model you may need to re light the pilot? Also make sure your getting gas to the unit (you will hear a hissing sound when the burners are turned on) try using a match to light the burner
Posted on Aug 06, 2009
  • 108 Answers
SOURCE: I'm looking for the phone number for the company
Remote receivers are always a problem...I would get rid of can work it manually with the on/off knob by jumpering the 2 contacts that the remote was using...or you can run 2 new wires from the same contacts and install either a switch on the wall or a thermostat...if the wires are burnt I would also check and make sure the Vent/chimney is functioning properly and not plugged before putting it back into operation
Posted on Oct 25, 2009
I need a operating manual for a Triumph wood stove?
Hello, Kay -
Clarification: You are referring to a Triumph wood burning stove manufactured by Victoria 05 Ltd., headquartered in Bulgaria. If so, I found this web page on the Triumph model wood burning stove:
When you scroll down the page, you will see the link for the PDF format Instruction Manual. You will need Adobe Reader software (free) to download, save, and print the manual.
Best wishes
Dec 20, 2017 | Home
Does anyone have any information on the Pine Ridge 500 wood stove? I'd like to know who the manufacturer is and what the EPA specs are.
PDF]installation and operation manual - Wood Pellet Stoves ...
Services) and the listing mark is Warnock Hersey. Testing: In accordance ... The assembled pellet stove model Advantage II-T C FS and. Advantage II-T C INS ...
[PDF]INSTRUCTION MANUAL - Ignite Dealer Portal - Regency ...
Tested by Warnock Hersey ... LISTED FACTORY BUILT FIREPLACE ACCESSORY HEARTH STOVE ... it is important that you read this manual throughout.
Nov 01, 2015 | Home
I need to build a hearth for my Waterford 106 Wood Burning stove. How big should it be? Especially, what did Waterford recommend when it built this stove?
Anyone heard of a Waterford 103? ' Forums Home
Nov 28, 2007 - Hello, I'm new here and I have a stove in my house that arrived with no... Does anyone know anything about this stove? Coal? Wood? Age? Make? ... The 103 was a wood-burning "Fireplace Stove" from the mid-80's. Installing an insert without using 6" flue liner tube because of ...
Sep 23, 2014
Looks like it's officially 24/7 burning time...
Dec 10, 2009
More results from
Wood Stove Hearth on Pinterest ' Corner Wood Stove ...
Pinterestfrom My Paradissi ... decorating around a wood stove ' Cosy wood burning stove fireplace: how to decorate around it. love the ... 893 106 ... wood burning stove hearth ideas ' old wood stove on brick hearth by Brian Powell - Stocksy United . .... Corner Wood Stove Surrounds ' How to Build a Hearth for a Wood Burning Stove.Missing: waterford
Oct 21, 2015 | Home
Troubadour wood stove
Look up companies locally that can cut glass for CERAMIC glass only and get a rope gasket from a local stove company along with stove cement. Not the best solution and I can't guarantee it won't break again but that is the type of glass that would be utilized on a wood stove since the manufacturer is no longer in business.
You can also search on the internet for replacement parts for that manufacturer. It would be aftermarket but at least it would be the whole door.
Your other option is to replace the wood stove that takes the same size flue pipe as the Troubadour wood stove you have. Sorry not great answers but when these manufactures go under for a while its like trying to find parts for a studebaker. Sometimes you just have to make do.
Mar 16, 2014 | Home
I have a new Buck STove Hybrid (coal and wood). The brick liners in the ceiling are loose and frequently are dislodged when feeding wood. Why is it designed this way.
I would suggest contacting the manufacturer at this link in order to get an answer to your question. Each stove manufacturer has their own way lining the stoves. Make sure you have your model number and serial number of your specific stove prior to calling the manufacturer so they can give you an informed answer. Good luck.
Do you have questions or comments
Jan 09, 2014 | Buck Stove Home
I need a manual for Monarch 24PY-2SW Kitchen Heater
Sorry this item is not in my area of expertise.
Nov 28, 2011 | Office Equipment & Supplies
Find spare and repair manual for intrepid wood stove
Alex, I don't know how old your Vermont Castings Intrepid wood stove is, but the only available Owner's Manual is for their fairly new model Intrepid II wood stove.
A little quick history. Vermont Castings was an independent company 10 years ago, that was bought up by Majestic (FMC) Fireplace Company of Canada. About 5 years ago, Majestic went belly up and the VC line was purchased by Monesson Hearth Products. There have been some improvements to their wood stoves in the past couple of years, so as to meet the new EPA Requirements. So, this manual may show some things your stove doesn't have.
Hope this helps you. Please let me know. Thanks.
Jun 02, 2011 | Heating & Cooling
Is it possible to install a wood stove in a room with carpet floors
Yes, but you need to put down ceramic tile down around the wood stove. Go to your local wood stove dealer and ask for there recommendations. It can be done.
Feb 14, 2011 | Heating & Cooling
How do we install a burner on a fireplace?
Thinking of adding a fireplace or wood stove to your home? If so, proper installation and maintenance is absolutely critical to ensuring the fire stays inside your freestanding fireplace or wood stove and doesn't venture outside of it.
If your manufactured home already has a fireplace or wood stove, it's a good idea to go look over these safety guidelines to confirm that it was installed correctly. If you plan to install a fireplace or wood stove, follow these safety guidelines carefully.
First, don't try to tackle this project yourself. While installation manuals usually provide all the instructions necessary for a manufactured home owner to install a wood-burning fireplace or wood stove, the consequences of a mistake are so disastrous, it's a task best left to experts.
It's a good idea to first check with your insurance company for their guidelines before installing these items. Your insurance policy may not cover damages if a fireplace or wood stove was not professionally installed. Plus, the manufacturer's warranty on the fireplace or wood stove may not apply unless the unit is installed by a professional.
Also can check this ARTICLE for other details.
Hope helps.
Jun 02, 2010 | Heating & Cooling
Home Logo
24 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
