Question about Jacuzzi Home
We have a Jacuzzi swp1 and swp2 it run's and will not fill up
    Top Expert:
  • Jacuzzi Master
  • 39,358 Answers
Worn or defective flapper at bottom of tank
Posted on Dec 15, 2016
Testimonial: "here do we get parts"
  • Anonymous Dec 15, 2016
    where do we get parts
Why would the jacuzzi perfecta toilet handle comes off and now won't fill, just keeps running
Handle retaining nut either came loose or broke off. Check the flapper valve, if its not completely closed water will keep running out, and fill valve will stay open trying to fill the tank.
Aug 30, 2014 | Jacuzzi Perfecta White Round 2-Piece...
I have a Jacuzzi Perfecta SWP2 toilet. It worked good for a while , now when you flush it you have to jiggle handle to make the flapper fall.Lowes doesnt have a replacement so they sold me a Fluidmast
If you have to jiggle it it usually means the chain is longer then it needs to be so its getting caught on something, the jiggling just loosens it. Look inside when you flush to see whats happening. Metal chains also get wound up when too long and the same thing happens.
Aug 17, 2014 | Home
Jacuzzi toilet
After flush the system must close the hole which lets water into the toilet. If it does not close after flush, it is continuously letting the water thru. Check if it closes after flush and allows tank to fill.
Jul 10, 2013 | Home
Why does black slimy film come out of my jacuzzi everytime I use it even though I clean it? and now my drain is clogged
black slime come from not using regularly..fill jacuzzi and pour a cup of dishwasher detergent and turn jacuzzi on for a while..
Nov 21, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi espirit less than 1 year old, toilet runs and occassionally makes whisting noise. Sometimes it does not run - there is no pattern to what causes it to run or not run. This started suddently,...
Your symptoms point to a faulty "fill valve" (the piece with the float adjustment), and is most commonly caused by small particles caught inside from normal use or a mineral build up. To save time and energy i recommend you replace it with a Lavelle "Quiet Fill" fill valve available at most hardware or plumbing stores or online. They come with very easy to follow install instructions.
Aug 08, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Jacuzzi jets
could be clogged with gunk, fill the tub up with as hot of water as you can and run some CLR or lime away and let it run for 15-20 mins and try that. alot of times the tubes create dips and soap scum and other "goodies" get clogged up in there and solidify and clogg up parts of the system
Jul 14, 2009 | Home
Do I have to clean my jacuzzi every day?
Just clean it once a week is fine.
Please rate!
Mar 17, 2009 | Whirlpool Home
Two person jacuzzi that hasn;t been used for several years. Iron
You are on the right track. Be sure and chlorinate and run the jets at the same time I would let it set for at least a couple of hours running the jet intermittantly and then drain and repeat.
Sound like you have Iron Bacteria. You may want ot contact a water profeessional who can recommend ways of getting rid of the iron.
Properly Chlorinating your well would be a good first step.
What part of the country are you in>
sanray
Dec 19, 2008 | Jacuzzi Signa 6 Whirlpool JAC-B540...
Home Logo
137 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
