Question about Pool & Spa
I just bought a used older garden leisure spa, it won;t turn off. The manual says push button once for low pump, twice for high pump and a third time for off. I only get low and high pump speeds.
    Scholar:
    New Friend:
  • 66 Answers
This can be normal depending in the settings. It may continue to run for upto 15 minutes, its just looking to satisfy it's heat or filter cycle.
Posted on Feb 12, 2017
  • 30 Answers
SOURCE: High speed spa pump shuts off
Pump speed Selector Switch Contact Probably Missing, Checkout
Posted on Feb 01, 2009
The motor may have a thermal cutoff if the motor draws too much current. Do you have a sufficient large gauge circuit supplying the motore? If not the actual voltage at the motor may drop, causing it to draw more current to make up for the loss of voltage, thereby tripping the motor's protective breaker. I assume the motor will start again after serveral minutes of cooling down.
Curtis
Posted on Apr 19, 2009
  • 323 Answers
SOURCE: The blower on my spa will not turn on
If you've made no changes to the wiring from when it worked correctly, then it can only be the switch. Get a new one, switch off the breakers, and wire it in according to the instruction that come with it.
Posted on May 28, 2009
  • 93 Answers
SOURCE: Just set up a used heritage hot tub. Temp is up to
make sure timer is not set on it will not turn off push all tabs on timer in that will solve problem
Posted on Jun 20, 2009
MNfisherman
  • 11896 Answers
SOURCE: I have a VITA Spa
Is there a type of resistor on the motor? Or anything between the wire and the motor? If not, then disconnect the speed selector switch, hook an ohmmeter up to it on the rx1 position and test the switch in all positions. If you don't get a reading on high, then the swith is bad, If you do get a good reading on high, then the pump could be bad.
You can also test the pump as well.
Posted on Oct 20, 2010
Trying to set my garden leisure spa on sleep so it circulates less. Currently it turn on every hour and runs for 7 minutes.My electric bill is out the roof.
there is a thing called a switch that you can activate to turn it off unless you are using it
That saves about 85% of the power bill
retime the timer to run at longer periods for less time or fit your own timer in the lead to the pump
Apr 20, 2017 | Leisure Pool & Spa
Why won't one of the spa motors start at low speed?
bad two speed relay on that motor
Oct 10, 2015 | Pool & Spa
Garden leisure spa
check to make sure you are getting 220 to it if not the check breacker
Sep 07, 2013 | Pool & Spa
Spa pumps makes alot of noise when set on low. Sounds better when set on high, but will lock up when switching between the two. Garden leisure spa.
Either have the motor rebuilt or replace it. At some point in time you had a pump seal leak which lead to the berrings going out. If you replace the motor be sure to replace the seal as well.
Aug 01, 2013 | Pool & Spa
Garden leisure spa
pump is going out
Pool & Spa Logo
395 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
