I have a dell computer, black screen with dot
I have a dell computer, when i turn it on it only gives me a black screen with a dot on the top right, and it shows the dell logo in the center of the screen. help!
    President:
  • 1,996 Answers
You are having a boot problem. Sometimes there are beep codes or error lights that can help you to diagnose the cause. Go to support.dell.com and enter your system service tag #, then search troubleshooting for boot problem or startup problem or no boot and follow the advice for your operating system...
Here's a more general startup troubleshooter that may help you.
Otherwise, give us more info about your computer, including model # and OS and we'll try to help you sort it out...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 20, 2009
Why my dell 4700c desk top. have dotted horizontal lines on start up?
Try securing the connection between the computer and the display. Try pushing the connector into the ports on both ends. If there are screws on the connectors, make sure they all of them are tightened.
Apr 25, 2014 | Dell Dimension Computers & Internet
Dell Inspiron 3520
What you have is a cracked screen. The LCD panel is cracked and is leaking fluids to the rest of your screen, those dots will spread too. This happens when u pick up the computer from the screen. You could try finding a replacement laptop screen, or get a new computer. They aren't that expensive. Make sure you save your hard drive tho!
Jun 30, 2013 | Computers & Internet
It turned on and said touch dot several times now the screen is off center
Turn off Garmin. Pres top left screen and hold. While holding, turn unit on but keep holding corner. Once the black dot shows up again, use the eraser part of a pencil to chase the dot. That would give exact measurements. Your fingers may be wet or too large and are offsetting the screen area readings. Good Luck
Dec 02, 2012 | Garmin Nuvi 1300 GPS Receiver
Dell Desktop monitor has flashing dots, black and white, all over the screen.
Check have you installed graphics driver properly in order to as per your monitor and as per your system or not.
Jun 20, 2012 | Dell U2410 24 inch Monitor
Bright star pattern dots on screen
dust on the optical lens possibly or a defective light engine.
May 28, 2010 | Mitsubishi WD-73733 73" HDTV
Are Dell monitors not compatible with older HP Pavilion Computer? I tried to connect my HP CPU to a Dell monitor and it will not recognize it at all.
It shouldn't make any difference which monitor you are connecting to any computer. In fact, I am running a 19" HP Flat Panel on my Dell Dimension 2400 right now. It is NOT a wide screen monitor as the Dell built in graphics card will not support the RESOLUTION RATIO required for the wide screen. Check what setting is "native resolution" for your monitor and see if your graphics card will support it. If not, using your old monitor, try different resolution settings. Right click on your desk top, click on properties and that should bring up the display properties box. Try a lower setting as larger settings are the ones that will give you a black screen. It will probably give you a smaller picture on your old monitor, or perhaps smaller or larger icons on the desk top. Accept the new settings, turn off your computer and switch monitors, and turn your computer back on. If you get a picture, but it does not fill the whole screen or the icons seem too large or small, then go back into properties from the desktop and try a different resolution ratio until the picture seems correct.
Jul 18, 2009 | Dell Computers & Internet
Black dotted line on monitor
Hi , Do not panic ,It is to do with the display driver which you need to reinstall.
Jan 11, 2009 | Dell Inspiron E1505 Notebook
Screen half black
its a hardware problem. if the computer is still under warranty, call DELL to have them replace the lcd
Oct 23, 2008 | Dell Inspiron 6000 Notebook
Partial Screen Display
Problem in the LCD back panel board. check the interface unit or ADC unit, also check the video clock pulse. one section is not working.....
Oct 09, 2007 | Dell E173FP 17" LCD Monitor
Dell E171FPb monitor turns on, but that's it
Hi Letneper,
Hope this will give you hints. Some monitors have standby mode or screen saver feature and or self test feature when not connected to video input of your PC or CPU. Except this problem did not occur at first use. You can turn this off like other monitors manually at OSD (on-screen display) settings if available. No more no less if it works fine with PC or CPU on then there's nothing to worry.
Best regards,
Rosener Guyano
Sep 04, 2007 | Dell E171FPb 17" Flat Panel LCD Monitor
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
