Question about Coffee Makers & Espresso Machines
Why does my cusinart dcc 1000 coffee maker keep blowing thermal fuses?
My coffee maker quit working, both thermal fuses were blown, replaced same, brewed one pot of coffee and same thing happened. I need to know what's causing it.
SOURCE: Is their anyway to turn the beeps off when the pot of coffee is done?
Disconnect the beeper.
Posted on Jul 25, 2007
SOURCE: One year old coffee maker won't brew
This is my second dcc-2000 with the same problem. I tossed the first one and in less than a year the second one exhibits the same issue. I called the Customer Service (1-800-726-0190). The rep told me to unplug the unit for at least 2 hours adding that this would let the system "reset itself". He then instructed me to run vinegar and water through it to clean the pumping system. I am doubtful about this solution but the rep assured me it would be replaced if I still have problems. It's worth calling CS to get it replaced, however, it seems that this model is flawed by design.
Posted on Aug 21, 2008
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: question about cuisinart's DCC-1200 1-4 cup mode
The 1-4 cup setting actually loops the water through the heating element twice. It's a good wrokaround for people who like extremely hot coffee, but not for iced coffee fans like me.
-Tha Mp3 Doctor
Posted on Jan 09, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: The ''clean'' light is on my cusinart coffee maker
Let a half caraffe worth of distilled white vinegar sit in the water reservoir for about an hour. After the hour, turn the coffeemaker on and let it brew the vinegar until a small amount of vinegar appears in the caraffe. turn the coffeemaker off and let it sit for an additional 20 minutes. Then turn the coffeemaker back on and let it brew the rest of the vinegar. Then run a full caraffe of plain water to flush the vinegar out. If the self-clean light remians on - unplug the coffeemaker for 20 minutes or longer - if you unplug it for any less than 15 minutes, the coffeemaker will not reset itself. You should be good after that - as long as you do some sort of vinegar/water cleaning once a month henceforth.
-Tha Mp3 Doctor
Posted on Mar 14, 2009
DCC-1150 Coffee Maker does not have power
Talked to Cuisinart tech support and they told me to unplug and leave it for 2 hours... that resets it to the factory defaults.
It looks like a thermal fuse might have blown inside your appliance.
If a thermal fuse has failed, there is probably another problem inside.
If the appliance is 4 months old, still cover under manufacturers warranty, Call the Cuisinart customer service to ask them where to find an authorized service center.
Hope this works for you.
Mar 12, 2008 | Cuisinart DCC-1200 Coffee Maker
I have had the machine for two years and it just died. None of the dials or toggle switches work, the digital clock display is dead, the coffee maker will not receive power. I have tried different...
The thermal fuse is probably open, it is usually welded to the heating element and tied into the on/off switch, and usually involves the replacement of the bottom section. The thermal fuse prevents the coffee machine from over heating.
May 04, 2011 | Cuisinart DCC-1200 Coffee Maker
I have a cusinart DCC-1200 Series, So how do I keep my coffee hot all day long ?
Brewed coffee has a palatable life-span of maybe an hour before it loses flavor. I don't recommend keeping it any longer. The thermos should keep your coffee hot enough to drink for some time. If you really want to drink from that same pot all day long, I'd probably just reheat a cup at a time in a microwave.
Sep 30, 2010 | Cuisinart DCC-1200 Coffee Maker
Our Model DCC-2200 started boiling and then smoking from the plate.The unit is approximately 2 years old.
The thermostat that controls plate temperature has stuck closed. Stop running the machine until this problem is repaired. A thermal safety fuse should have blown (stopping any further heating).
Feb 02, 2010 | Cuisinart DCC-2200 14-Cup Coffee Maker
Where is thermal fuse in cuisinart dcc-1200 it needs replacement
The Cuisinart DCC-1200 doesn't appear to use a thermal fuse but instead seems to use a NTC Thermistor. Like thermal fuses this is clipped onto the bottom heating element and has two yellow fine lines leading to the control board. It should measure ~220k Ohms at room temp and drop its resistance to <20K ohms as water boils. This Thermistor looks and behaves a lot like a Vishay NTCLG100E22245B [220KOhmn] which is available through DigiKey [BC2467 part number; $0.52]
Dec 21, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart dcc 1200 will not brew
I'lm not sure of the model, but it is a Cusinart Coffee Maker with a Glass Pot. It gets power on all lights except the ON/OFF switch, and it willl not brew. Any suggestions, or should I trash it and get a new Coffee Maker. This one is approx. 1 year old. Thanks for your advise.
May 20, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee Makers & Espresso Machines Logo
29 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
