Water in the bottom of the lint trap
There is a small amount of water in the lint trap area which is enough to drip onto the top of the washing machine below
onthejob5130
  • 640 Answers
SOURCE: cleaning the lint trap of my Affinity washing machine
no lint trap...the best you can do is give it a hot wash bleach with a cold rinse,,,onthejob
Posted on Jan 31, 2009
  • 1170 Answers
SOURCE: My Kenmore top loading washing machine is leaking
This symptom usually indicates that you have a failed inlet solenoid water valve assembly. Completely unplug the washer from the electrical supply and see if the water stops filling. If it does, then you likely have a control board failure. This is rare but possible. If the water continues to fill with the washer unplugged from electricity, I recommend shutting off the hot and cold water supply faucets behind the washer. It is likely that the water will stop filling the washer. This would indicate that you have a failed water valve assembly.
Posted on Jul 11, 2009
SOURCE: LG WM2355C water leaking under machine after washing finished.
I had this same problem and it was not the supply connections or filters! Under the machine is a rubber bellows. The bellows had sprung a leak. The part was about $10 from Sears and I repaired it in about 30 minutes. The machine is heavy so be careful. Get a friend to make sure the machine won't rock or tip when you're making the repair.
Posted on Sep 16, 2009
pride applia
  • 232 Answers
SOURCE: How do I remove the lint trap holder. I have lint
you have to remove the top then the control pannel then the entire front. are you ready for this?
Posted on Jan 08, 2010
Testimonial: "Even though it was not what I wanted to hear, I do appreciate the incredible help. You guys are the best!"
erpaalai
  • 999 Answers
SOURCE: washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Eric
Posted on Mar 14, 2010
What is a Drip Irrigation System?
According to Wikipedia "Drip irrigation, also known as trickle irrigation or micro irrigation or localized irrigation, is an irrigation method that saves water and fertilizer by allowing water to drip slowly to the roots of plants, either onto the soil surface or directly onto the root zone, through a network of valves, pipes, tubing, and emitters. It is done through narrow tubes that deliver water directly to the base of the plant."
Sep 10, 2013 | Garden
After every wash the lent stays on the clothes
here are a few suggestions Two things that come to mind...1) Your wash time is too long. Unlike front loaders, top loaders clean quickly. No need to use the longest wash setting unless the item is really dirty.
2) You are overloading the machine. Items should move freely and circulate from top-to-bottom several times during the wash.
3) try using more detergent, One of the things good detergent does is keep lint (and dirt) suspended in the water and off your clothes. 4)http://www.ehow.com/how_2083872_clean-washing-machine-lint-trap.html
check that link for lint traps in washers
Jul 21, 2011 | Washing Machines
How do you clean the lint catcher
if washer having difficulties draining the water, check out the DRAIN MOTOR PUMP , IT COULD BE CLOGGED with LINT & debris, locate at bottom side is a small motor where 2 hoses are connected , AJ
Nov 22, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Lint is massing toward the bottom of the lint trap
please check your exhaust vent, where the dryer air comes out of the house, this particular pattern is very indicitive of a slow moving exhaust, you may need to clean the duct between the machine and exhaust as well
Oct 22, 2009 | Kenmore 62602 Electric Dryer
My Miele Touchtronic W1119 shows the error message Drain/Intake Fault. The intake and filters are fine. What's going on?There is no water standing in the drum. How can I reset this?
Hello Buvamo,
You may want to check the water valve and make sure it is all the way up where the intake line is.
The other area to check for water not draining is the lint trap. While the intake/drain fault is on the door will not open for the lint trap.
There is a release lever at the bottom of the machine (Orange in color) that is below and behind the trap door. Just pull down on the lever and that will open the trap door. You may want to put a towel under there as it will leak once the door is opened. inspect and clean the trap and try running cycle again
Sep 13, 2009 | Miele Touchtronic W1119 Large Capacity...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water backing up in the drain pipe
many washers have a lint trap just before the pump
the traps get full of socks, lint, or other small items
those that dont have traps, should.
examine the hose between pump and trap and drum, for trapped small items
to see the hose and trap
kenmore whirlpool & heaps of others
Unplug washer
turn off taps
  • remove trims from edge of control panel
  • remove screws from under bottom edge of trims
  • raise slide forward and flip control panel over, hinged at top, do not dislodge air hose to level control
  • remove brass body clips under control panel, not position for reinstall
  • lift body 1/2inch (locator studs at bottom) and remove, top front and both sides come away as one piece
motor pump gearbox tub suspension is now exposed
reassemble in reverse order
Dec 05, 2007 | Kenmore 3.2 cu. ft. Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
