Question about LG Televison & Video
LG Television No Picture No Back ligt Good Sound
    Top Expert:
  • LG Master
  • 75,311 Answers
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Dec 15, 2016
3 Suggested Answers
  • 608 Answers
SOURCE: my lg 42" television which is only 18 months old
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk.
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found online. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Posted on Dec 18, 2010
aymantn
  • 109 Answers
SOURCE: Our LG LCD television screen is red. No picture,
Look at this
Posted on Oct 23, 2012
LG LCD 42" sound but no picture
From this web site it says:
http://www.ehow.com/about_5379235_lg-television-problems.html
Powering Off
  • Many LG LCD television owners report having a problem with their televisions where the screen powers on, but then lasts only a few seconds or a few minutes before powering itself off again. The problem usually occurs with brand new televisions, and in this case is inside the television itself. If your television is powering off unexpectedly, contact LG so it can be serviced.
Read more: http://www.ehow.com/about_5379235_lg-television-problems.html#ixzz2qeK8T3SU
Jan 17, 2014 | LG 42LC2RR 42 in. HD-Ready LCD TV
Has sound but no picture
The problem is from the t-com board of the television, that is why you are having sound but no picture.
The solution is simple, just have the t-com board replaced and your television will be in good condition once again.
Take care
Oct 09, 2010 | LG 42PC3D 42 in. Plasma Television
LG LCD TV/DVD - I have full picture and sound with
is a mute function enable or a defective control board. Needs to be checked. send to repair store.
Jan 16, 2010 | LG 42LB1DRA 42 in. LCD Television
No picture. Lamp ligt is on. is it the lamp that
Look at the venting grills to see if you can see the whit lights inside. If the screen is black then, there are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 18, 2009 | Sony KDF-E55A20 55 in. LCD Television
LG 42PC3D Plasma: No picture, good sound
One of the SUS panels will be defect.On these panels you will find several fuses,the panel with the broken fuse must be replaced.
Sus panels are the panels with the big cooling blocks.
Jul 20, 2009 | LG 42PC3D 42 in. Plasma Television
Sound but no Picture
Same problem...not solutions so far from what i can see. just a popping type sound...picture GONE...sound still there....had it for 2 years and 3 months....warrenty was for 2 years...eh hem...it figures.
Aug 27, 2008 | LG 42PC3D 42 in. Plasma Television
LG LCD TV no sound
LG tv flatron no sound, picture everything else is fine but no sound what can be done to fix it
Jun 16, 2008 | LG 42LB1DRA 42 in. LCD Television
LG RU-42PX10 42 in. HDTV
Try to replace the YSUS board first. If not fix then try to replace the ZSUS board.
Good luck
Apr 20, 2008 | LG RU-42PX10 42 in. HD-Ready Plasma...
Televison & Video Logo
22 people viewed this question
Computer Repairing
Computer Repairing
