Question about Grilling
Stove burners are slow down and proper heating, how do I clean the burners and pipe line which is connected to gas tank
frcs68
  • 1605 Answers
SOURCE: weber gas grill wont heat past 300 degrees
are the fire red , orange or blue?
must likely is the burner control.
check the air control at the back of the burner control, it should be open all the way.
it it is, then try another themostate.
Posted on Mar 24, 2009
bulldogchief
  • 388 Answers
SOURCE: Gas not getting to stove to ingnite
It sounds like you may be "vapor locking" the grill...after you are done cooking on the grill, how do you shut it off? Do you close the tank valve first then close the burner valves or do you turn off the burner valves then shut the gas off at the tank? If you turn the burners off before turning the gas off, you are creating a "vapor-lock" where air gets trapped in the line and you get the sputtering you are talking about.
Try this first, turn the gas on, then light the grill...once it is lit, turn off the gas and wait for the flame to fully extinguish then turn the burners off. Now try to light it again...if it is still sputtering, repeat the procedure above to purge the air out of the line.
If that procedure does not fix your issue after three tries, go get a new line and regulator and install then do that same procedure again. This should fix your issue once and for all.
If you experience any trouble with this, let me know here. Good Luck!
Posted on Oct 30, 2009
  • 332 Answers
SOURCE: My q grill is not heating properly.
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Posted on Mar 30, 2010
  • 512 Answers
SOURCE: Gas not getting to grill
Two things could be wrong. Tank valve could be bad, not allowing gas to flow. Or regulator could be bad not allowing gas to pass. Try taking the tank off and pushing a screwdriver into the end of it with the tank open, if gas doesn't come out tank valve is bad, valve has a spring in it to shut down if starts leaking. If tank valve is good regulator must be bad. I am leaning more towards to the tank valve.
Posted on Apr 07, 2010
  • 1015 Answers
SOURCE: The flow gas coming from the burner is very slow.
It could be a defective LP gas regulator or a restriction somewhere in the gas line for the bbq. This can also happen if the propane tank is overfilled.
First make sure that the LP tank is not overfilled. If you open the bleeder hole on the tank(small screw next to the valve) there should be no liquids coming out. If liquid propane is coming out then the tank is overfilled. Keep the bleeder screw loose until the liquid disappears then tighten. Re-connect the tank and see if that fixes the problem.
Then inspect all the gas lines on the bbq. Make sure that there are no kinks or crushed lines.
Then take a look at the gas regulator. Try turning on all the burners then give the regulator a couple good taps on the housing with something solid. See if the burner changes size. If it does and then goes back down it could be the gas regulator. Also take a look at the regulator housing. There should be a very small hole on the housing and it might be labled "vent". Make sure that this little hole is not plugged with any debris or that can cause a low pressure problem. You can use a sewing needle to gently poke out the hole. You will know if it worked because the burners will become much higher. And you could also try disconnecting the hose and regulator assembly from the bbq then turn on the LP tank slowly with the regulator connected. You should get plenty of gas flow from the end of the hose. Then use your hand to block and release the flow a couple times to try and clear any debris that might stuck in the regulator.BE VERY CAREFUL DOING THIS!!! MAKE SURE YOU ARE CLEAR OF ANY SOURCES OF IGNITION BEFORE TRYING TO CLEAR THE REGULATOR. Then reconnect the hose regulator and tank to see if the problem is fixed. If you are getting very low flow from the hose with the regulator disconnected then it is probably a defective regulator. They are pretty standard and you can purchase a new LP hose and regulator assembly from most home improvement stores.
If the regulator checks out good then I would think that there is a restriction in the main gas line for the bbq after the regulator. You will need you dis-assemble the main line and blow it out with some compressed air to clear the restriction.
Posted on Jul 04, 2010
We have a Rangemaster professional 110 and the inside ringof the wok burner will not light up.but the outside ring will lght up.
First, I'm not a Rangemaster Tech.
* call vendor for service. Gas leaks are hazardous and require a qualified tech to service.
*** The following is for information only.***
* I've always had problems servicing gas stove, heaters, boilers, etc. Lots of unique components that require special tools to service.
* I was surprised to find out that it's better to call on your local Gas Supplier for service. The not only check the supply line but also have a very good working experience with all types of gas fired equipment.
* Slow pilot lighting or burner fire usually means a clogged gas vent or valve. If other burners are working fine, then it's just that particular burner.
* If all burners have the same symptom then it could be a number of things.
* Check gas mains for pressure and flow (you need a gas meter for this but if you have another stove on the same line then it's probable that the mains are okay. Unless the connector or shutoff valve is not working properly (partial open).
* Check gas hose to stove for kinks. Replace if bent (re bending will crack a metal hose.)
* Check the gas regulator (again, need a gas meter)
* Check the feed and branches for gas. If pilot lights are not on then there is a good indication that your not getting gas to that section. (or the pilot is clogged) Clean, clear, or replace pipes/parts.
* Check valve on each burner. This is the most used item on the stove. Expect it to wear out. Replace as needed.
* Final, Be safe; Call your Gas company or MFR tech for service.
Aloha, ukeboy57
Mar 12, 2018 | Rangemaster Kitchen Ranges
All 4 rings get extremely hot immediately and don't cool down.
Appliance Science: The hot physics of induction cooktops ...
www.cnet.com > Appliances
CNETJan 12, 2015 - Induction cooktops don't heat up themselves: they create heat in the base of the cookware. ... the cookware, and so react quicker when you turn the dial up or down. ... US consumers don't like them because they grew up on gas rings. ...pans, they don't get hot when you put them on an induction cooktop.
4 Lessons I Learned From My Electric Stove - Life in the ...
www.thekitchn.com/why-im-grateful-fo...
Apartment Therapy's The KitchnFeb 24, 2015 - Electric stoves don't have a lot of redeeming qualities. ... "low" burners rather than wait for the front burner to sufficiently cool down. ... burner for all my cooking, as I did when I cooked on a gas stove. ..... I was used to looking at the size of the flame to gauge how hot it really was, I never looked at the dials.
Moving From Gas to an Electric Stove: What I've Learned So ...
How to Fix Problems With Burners on an Electric Stove ...homeguides.sfgate.com > Landlords & Tenants > Landlord ProblemsElectric stoves rely on electrical resistance to heat up the burners on the cooktop, which means they function much in the same way as electric heaters. ... When one of the burners stops working, you can usually trace the problem to the burner switch, theburner receptacle or the ...Electric Range Stove Repair: How To Repair Burner ...? 6:52https://www.youtube.com/watch?v=ndQU7RtqfRwJan 31, 2012 - Uploaded by applianceassistantHow to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... How To Test Stove ...Fixing Electric Stove Burners that Don't Heat Up Properly ...? 2:34https://www.youtube.com/watch?v=GfqaPcha__o
Dec 15, 2015 | Kitchen Ranges
My reliance sta-kleen 502 is leaking. The water is dripping on top of the pilot light, extinguishing the flame . Please advise me with step by step instructions to diagnose and attempt fix this myself....
If you have a leaking water heater there is a serious problem.
http://waterheatertimer.org/Water-heater-leaking.html
Page shows how to limp along on a leaking water heater if your water heater needs replacement.
One of three things is causing the water:
1) Loose water connection on top of tank that is dripping down inside tank >> check pipes on top of tank.
2) The vent is clogged or not working correctly causing condensation inside flue pipe.
Condensation water is dripping back down inside tank.
Problem means possible CO poisoning if gas is not venting.
Look at vent pipe to see if joints are corroded.
Use long fireplace match > light match and put into draft hood at top of tank and see if smoke goes up.
Put hand at draft hood opening when water heater turns on to see if vent gas enters home.
Do same test when furnace turns on to see if furnace vent is pushing back into water heater.
Does water heater vent inside same pipe as furnace? You may need to set up separate vent for water heater if furnace gasses are pushing back into home.
Check furnace vent for obstructions.
Look at vent stack top of home to see if hood is in place.
Check if bird nest is built inside warm vent pipe.
Improper flue is top priority for getting fixed so vent gasses properly escape home.
You may have to call a plumber.
Professional plumbing forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
3) Your water heater is rusted out.
A rusted tank has to be replaced.
It cannot be repaired.
However, before replacing tank, you do not want a tank failure where tank ruptures and water runs inside home until water is shut off.
This will cause major damage.
Protect yourself first.
Turn off water valve above tank.
Move gas knob to 'pilot' so burner is not heating water.
Open tub spout on hot side to relieve pressure on tank so it will not rupture.
Now you're protected.
Link above shows how to limp along on failed tank until you can replace heater.
You need a new gas water heater from Lowes or Home Depot
Look at label on side of you tank for gallons and btu's of your water heater.
Measure height to flue pipe so you get same height water heater, so pipes don't have to be changed.
You need a pipe wrench and teflon tape which will be wrapped on each pipe thread when pipes are reassembled.
Step1) Drain water heater using valve at bottom of tank.
http://waterheatertimer.org/Water-heater-will-not-drain.html
2) Turn off gas valve going into heater.
When gas valve is perpendicular to gas line, then gas is off.
Dissemble gas line to water heater.
3) Disconnect flue pipe and support flue pipe with wire so it doesn't not fall down. Flue pipe joints should be held together at each joint with 3 screws.
4) Turn off water. Shut off valve is on COLD side.
Disconnect water pipes.
5) Move old water heater out of way.
6) Set new water heater in place. Put water heater in drip pan.
7) Connect water pipes >> cold goes to side marked cold.
Hot to hot.
Buy new flexible water connector pipes at home center for easy installation of water pipes.
8) Connect gas line exactly as it was connected before.
Home center sells flexible gas line connector for easy installation of gas line.
To test for gas leak after installation, mix liquid soap with water and put around gas line joints to see if there are bubbles.
Natural gas has less pressure than water lines, so gas pipes are easy to seal with ordinary wrench.
9) install TP pipe that runs to floor. Use old one off old heater.
10) Fill tank completely with water until water is coming out of tub spout.
11) Turn on gas, and light pilot as shown in manual.
New gas heater sometimes have small water leak when first fired up, so ignore a bit of water.
12) Save water heater manual like it is gold, and read everything in manual.
Dec 18, 2010 | Water Heaters
Need to know where the termostat goes in the waterheter?
The thermostat probe on most residential water heaters is part of the gas valve. The thermostat is a non replaceable part of the gas vale and if your t-stat is bad you will need to replace the gas valve also.
This is generally not a very hard job just start off by shutting gas supply valve to off position.Disconnect main gas line to burner,line to pilot light, and thermocouple from gas valve. Remove pipe fitting from gas valve and use large pipe wrench to loosen gas valve.
Before you loosen gas valve you will need to shut water supply off and drain water from tank.MOST WATER HEATER GAS VALVES ARE PRETTY STANDARD ITEMS AVAILABLE AT MOST HARDWARE STORES. Just make sure you purchase valve for the type of fuel you have,such as l.p. or natural gas.Remove gas valve by turning counterclockwise. Use teflon tape or pipe joint compound on all threaded connections for reassembly. Hook up gas line,burner supply line,pilot and thermocouple lines. Refill tank and check and check for leaks. Light pilot and turn gas control to on. Set to desired heat setting . Also check all gas fitting for leaks. Good luck. Thanks
Dec 17, 2010 | Water Heaters
Looking for the operating manual for a WFS43W-1 stove / oven from white westinghouse. Anyone can help me?
First, I'm Not a westinghouse tech.
Aloha, ukeboy57
Jul 12, 2010 | Kitchen Ranges
Coleman 425 2-burner white gas stove pops out flame on low heat
There is water in your fuel. Drain the tank and flush it out with denatured alcohol. Refill with fresh fuel.
Jun 21, 2009 | Coleman Sport & Outdoor - Others
Kenmore Gas Stove gas takes a long time before it will come out
First, I'm not a Kenmore Tech.
Aloha, ukeboy57
PS check youtube for: "Sears Kenmore Gas Oven Problems"
Feb 21, 2018 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Stove burners won't ignoite
remove a burner cover and while observing the burner turn on the ignitor listen to it click for that burner ; you should see a tiny lightning bolt like flash if you do not tun off the burner clean the area and, try again oil and grease coat the burner gas plate and isolates the ground that the spark needs to be able to "jump" to
Apr 26, 2009 | KitchenAid KGRT607 Gas Kitchen Range
What is the use of holes in stove pipe line.
No these are airflow holes and gas can not leak from them because they are not connected to the stoves gas line in any way!
The gas does not come out these holes! the air goes in these holes! from the draw of the gas!
Please rate this FREE response!
THANK YOU!
Jan 16, 2009 | Crock Pots & Slow Cookers
Burners and oven will not heat
Something is stopping the gas flow. Turn off gas. Disconnect line from the stove have someone turn on and off the the gas just for a second.(make sure no flame in room). See if gas is available.If not it is the gas line leading into the house somewhere,not the stove.  Follow the piping to the first thng it comes to. Disconnect that line and see if it is open from there back to the connection. If you finally get to the valve,which I dont think you will . You will have to disassemble  or replace it.
Dec 10, 2008 | Tappan 30IN ELEC IGNa Oven
Grilling Logo
76 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
