Question about Whirlpool Dryers
I have a whirpool dryer lg9481xww1. recently replaced thermal fuse, it was bad. now dryer beeps. i have replaced control board with a used one . still beeps any suggestions
  • 156 Answers
SOURCE: replaced the thermal fuse in
you have a dead short in the plug are wireing to the dryer
Posted on Mar 19, 2008
  • 184 Answers
SOURCE: Maytag Neptune gas dryer beeps.
NO RESETS OTHER THAN TO UNPLUG THE DRYER FOR 5 MINUTES, THEN RECONNECT POWER. ON ANY ELECTRONIC CONTROL, THIS WILL RESET THE CONTROL'S MICROCOMPUTER. IF THAT DOESN'T SOLVE THE PROBLEM, THE TOUCH SWITCH MAY BE FAULTY.
Posted on Apr 22, 2008
  • 417 Answers
SOURCE: Dryer keeps burning out thermal fuse and thermostats
If the thermal fuse and thermostat are bad,something is causing them to overhea,t before tackling the heating element, you should check all connections to the stat and fuse as a loose connexion could be the cause of the over heating.
Posted on Dec 11, 2008
dniro592006
  • 121 Answers
SOURCE: LG DLE7177 Thermal fuse
Thermo Fuse is normally followed by the power source or on
the circuit board, Follow power source and you will find fuse.
Posted on Apr 02, 2009
jumptrout51
  • 3361 Answers
SOURCE: My whirlpool dryer won't start.
Check your door switch for continuity. If no continuity,replace it.
Posted on Aug 13, 2009
I have changed the thermal device and still not heat
There are several devices in your system. You replaced the the thermal cut out designed to interrupt power when the temperature reaches 250 deg F. A thermal fuse is also installed which "blows" at 390 deg F. A third control device is the thermister which signals the control board to control air temperature. When it fails the system is designed to generate signal such as beep-beep-beep. To test the heater itself you can disconnect one end and measure resistance to determine that the heater is not burned out. Also you can read the voltage applied across the heater (if there is voltage but no heat the heater need replacing)
The control board gets a signal from the sequencing system. The manufacturer will provide a schematic for your machine if you ask.
Nov 30, 2014 | Dryers
Thermal fuse failure
If the relay sticks, that will cause overheating and the thermal fuse to blow.
Feb 27, 2017 | Whirlpool Dryers
Electric Whirpool Ultimate Care II Dryer, runs but no heat.
Hi
I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if it is bad then it should be replaced, as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 14, 2011 | Washing Machines
My dryer will not work. everytime I press a button it just beeps
If the beep sound comes from the inside of the unit then it is the thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset. If the fuse tests fine then it is the main board that has gone bad & you will have to replace it to solve this issue.
Hope this will help....
Dec 31, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
+I can select a drying cycle, panel lights go on, but when I close the door and push start I get a series of beeps and the cycle will not begin.
Hi
The issue seems to be either with the Thermal fuse which is located inside the rear panel to the exhaust duct or the control board itself has gone bad. You can take a voltmeter and check the thermal fuse for continuity, if it is open then replace the fuse else the control should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Dec 08, 2010 | Kenmore Elite HE4 Electric Dryer
I have a whirpool duet. The lights on the front panel light up, but the dryer will not start. I just hear a click and then nothing ????
Remove bottom panel and check the thermal fuse just behind the ducting. If this is blown it's a inexpensive fix. If it's good you may have a bad control board. Remove control board an inspect the back side of it for burning.
Rich
Western Appliance Repair
Appliance Repair Meridian
Oct 09, 2010 | Whirlpool Dryers
DRYER HAS POWER; WILL BEEP, BUT NOTHING ELSE WORKS. NO AIR, NO HEAT, NO SPIN. WILL NOT START AT ALL IF IT STARTED, THEN SHUTDOWN, I WOULD SUSPECT SAFETY SHUTDOWN, BUT NOTHING STARTS. FILTER IS...
Your thermal limit is probably blowna2b9c08.jpgBe sure to clean the area of lint and fluff. This video is of an older version of what you have
I have a service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 31, 2010 | Kenmore Dryers
Replace thermal fuse and door latch and still does not run. Power on and beeps once.
Was the thermal fuse blown?
Look at the led indicators on the front of the dryer are any of them lit but very dim? If so it will be a loose connection on the flat cable assemblies 4 each from the interface panel (one with the lights and knob) to the control board located on the top left side of the dryer. If that does not work then Interface board then control board in that order.
If the led indicator appear normal then id look at the control board.
Oct 27, 2009 | Whirlpool GEW9250 Electric Dryer
Whirpool dryer won't heat up
You need to replace the thermal fuse and the timer. A bad timer will over draw a thermal fuse and cause it to blow.
Please remember to unplug the dryer before servicing
Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
My Whirpool GEQ9800PW1 will not heat
just set your ohm meter on continuity where it will beep when you touch the meter leads and then test the parts all should beep
Dec 15, 2008 | Whirlpool GEQ9800P Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
