Question about Casio Watches
I cannot reset hours or minutes on my Casio 3191 after battery replaced. Suggestions?
When I press the button to switch from seconds to hours or minute nothing happens
  • Casio Master
  • 18,424 Answers
My father in law has an old Casio model 548 wrist watch. It's stuck in military time and he wants to reset the time to a 12 hour option and move into daylight savings time. Can you help?
from the user manual press the button closest to the seconds display on watch . bottom right button in normal time display to switch between am / pm time or 24 hundred military time.
http://mygshock.com/casio-manual/548/
enlarge the internet browser display to read which button to press to change the time or date.
press button B top left button to go into change mode
press button C bottom left button to move to seconds or minutes or hours .
press button A bottom right button to advance the time
press button b top left button to go back to normal time display
Jun 01, 2018 | Casio Watches
How to reset time
Diplodocs - CASIO: 1506 references - Your user manual immediately available! Your CASIO has four push button and one for winding button. the first button has mark of LIGHT , the below button is MODE ,,upper right START/STOP,,, lower is LAP/RESET. the center button is what they called it a CROWN to set crown is just pull it and you can set the hour and minute. the LIGHT button is the set button also, just press it for 15 seconds if dial flashes, then go to MODE button and choose what going to set, the START/STOP -- LAP/RESET is the scroll button you going up and down the number or on /off ,some model of Casio Edifice, the set is in the MODE button just press it long and if flashes it ok. and follow procedure what i said before. setting cannot damage the watch. Feel free to ask question regarding your to watch so i can assist.. Hope this may help;
Regards,
VOTIT
Aug 21, 2008 | Casio Edifice EFA109-7AV Wrist Watch
How to change from 12hour format to 24hour format on Casio watch la670w?
How to Set Casio Watch
specifically step 6 below for your answer
Setting Instructions for Electronic Watches
Casio electronic watches feature many different modes ranging from timekeeping to stopwatch. The M button controls the modes. Here is how to set time on a digital watch such as models 1632 and 1813:
  1. Press the M button to get into the Timekeeping mode.
  2. Select the seconds digits by holding the A button down until the seconds digits flash on the display.
  3. As the digits flash, press the C button, which will reset the seconds to 00. On some watches such as GW-500A, a stop/start button is used instead of a C button.
  4. Press the M button and change the selection in the order of seconds, hour, minutes, year, month and day. Proceed in that sequence to change information to the current time and date.
  5. As the sequence progress, digits flash when selected. Press the C or stop/start button, to increase a selected number or the B button to decrease it. Hold down either button to increase the speed of the selection change. All time and date functions are set this way.
  6. Press L when any digit is selected to switch between 12-hour and 24-hour formats.
Jul 08, 2015 | Casio Watches
How do I re-set my CLOK TCR338 to not read in military time?
heres an answer another question had that might assist u in some way:
According to the instructions that we received with our clock. You should be able to get the Instruction manual from prodinfo@gpx.com. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
Dec 05, 2014 | Watches
How can i change the time
Note how the buttons around the outside edge of the watch match up to the compass directions on the outer ring of the watch face. Use the butttons on the NW, NE, SE, and SW positions.
  1. To enter time setting mode, press and hold NW until the Seconds start to flash. (You can exit time setting mode at any point by pressing NW twice)
  2. Release NW and press SE to reset the Seconds to 00.
  3. Press SW and the Hours will start to flash.
  4. Set the hour by pressing NE (down) or SE (up) Press the lower button to move up and the upper button to move down.
  5. When the hour is correct, press SW and the Minutes will flash.
  6. Set the minutes by pressing NE (down) or SE (up)
  7. When the minurtes are correct, press SW and the 12/24hr setting will flash.
  8. Switch between 12hr mode and 24 hour mode by pressing SE.
  9. Press SW and the Year will flash.
  10. Set the year by pressing NE (down) or SE (up)
  11. When the year is correct, press SW and the Month will flash.
  12. Set the month by pressing NE (down) or SE (up)
  13. When the month is correct, press SW and the Day will flash.
  14. Set the day by pressing NE (down) or SE )
  15. When the day is correct, press SW and the seconds will flash again.
  16. Exit time setting mode by pressing NW twice.
This is a complex watch. You can download a manual here http://www.casio.com/products/archive/Watches/PRO_TREK/SPF40-1V/
Apr 02, 2014 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
I am unable to set time in watch Nako NA-823A
NAKO NA-823A Instructions
Turn Alarm on or off:
-Press the S and D buttons simultaneously
Display Date:
-Press the D button
Set time and date:
-Press the M button to switch modes in this sequence: stop watch>set alarm>set time>time.
-The S button will allow you to select seconds, minutes then hour, then day, month and weekday.
-Use the D button to clear seconds to zero, or move minutes and hours and date up by a single increment.
-Press and hold D for two seconds to move minutes and hours rapidly.
-Press and hold D while pressing and holding S moves through AM/PM and 24 hour (H) modes.
Use stopwatch:
-Press the M button until you arrive at the stopwatch.
-Press D to start and stop
-Press S to clear.
Display alarm time:
-Press the S button while time is displayed.
Jan 14, 2013 | Watches
-Press the S and D buttons simultaneously.
Display Date:
-Press the D button.
Set time and date:
Use stopwatch:
-Press S to clear.
Display alarm time:
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
    Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Aug 21, 2010 | Casio Watches
Cant set it
    Setting the Time
  1. G-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left button until the seconds unit blinks on the display. Reset the seconds to "00" by pressing the lower right button.
    Push the lower left button to switch to the hours unit, which will start blinking. Advance the hour by pressing the lower right button. If you hold down the lower right button, it will advance the hour unit at a higher rate of speed. Once the hour is set, press the lower left button to switch to the minutes unit. As with the hours unit, pressing the lower right button will advance the minutes and holding it down will advance the minutes rapidly.
    Once the time is set, press the upper left button to save the setting.
  2. Backlight
  3. The backlight on a G-Shock watch has a manual control and an automatic function that will light the face of the watch whenever the alarm, countdown alarm or hourly alarm ring. To use the manual backlight, press the button on the bottom of timepiece. The light will glow for approximately 2 seconds before going out.
    The automatic function is set by pressing and holding the lower right button. When the automatic function is set, an indicator icon will display on the watch face above the seconds unit. You can turn off the automatic backlight function by pressing and holding the lower right button until the icon disappears.
    Note that backlight causes a drain on the battery, and overuse of the backlight will greatly reduce battery life.
  4. Setting the Alarm
  5. The G-Shock has an alarm that emits an audible tone for approximately 20 seconds when it turns on. To set the alarm, press the lower left button until "AL" displays in the upper left corner of the timepiece. Press and hold the upper left button until the hours unit starts to blink. Adjust the hour by pressing the lower right button. As when setting the time, you can advance the hour at a higher rate of speed by holding down the lower right button.
    Once the hour unit is set, press the lower left button to advance to the minutes. Use the lower right button to set the minutes. Follow these same instructions to set the month and day you want the alarm set.
    When the alarm time and date are entered, press the upper left button to save the setting. Push the lower left button three times to return the G-Shock to "Timekeeping" mode.
Aug 19, 2010 | Casio G-Shock G 520D 4AVDR Cockpit Series...
I cant figure out how to work it my casio gshock
    Setting the Time
  2. Backlight
Aug 14, 2010 | Casio Watches
Watches Logo
357 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
