Question about Bose Audio Players & Recorders
My Bose media center displays the Adaptiq A/B: N/A code constantly. Pressing Last button, right of the Zero button does NOT solve the problem.
2 Suggested Answers
  • 14 Answers
SOURCE: The Media Center system doesn't work
Unplug the media center power at the rear power plug. Leave off for 20 seconds. Remove the AdaptIQ headsets plugged into the AUX input. Power the system back up but leave alone for about 10 minutes. After 10 minutes come back and press the "open/close" button the wait 30 seconds or more for the tray to open. Be patient, the media center is processing a huge amount of data and needs time to respond to your commands. It is important to leave the media center undisturbed for approximately 10 minutes after running AdaptIQ setup. After about ten minutes, power down the power back up. You should be ready to go after that.
Posted on Dec 24, 2007
Software update failed 100 call bose
Hi Brian,
Did you get this sorted as I'm having the same issues?
Regards,
G
Apr 11, 2013 | Bose Av 38 Media Center Dvd Player...
Bose Lifestyle 235 system: setup button not working
Contact the authorised service center for Bose at your town.
May 02, 2012 | Bose Lifestyle 235 Theater System
Adaptiq A/B: N/A
Hey thanks.my Bose system screen only says Adaptiq A/B:N/A it works fine but it wont go away. I thought I tried hitting all the buttons but I guess I missed one. As the first guy here says you hit the previous button next to 0 or (zero) and wallah. Problem solved. Thanks a ton.
Jan 08, 2012 | Bose Audio Players & Recorders
Got error 10 and dont know what to do
from REalMacoi your problem seems to be related with the AdaptIQ failing to do an active equalisation. HAve you connected the AdaptIq sense headphones on the AUX (left and right coz it will still fail if only one cable is connected) Also make sure tha the sense headphone cable is in the correct color orientation and none is connected to the black jack just below the red one. Try this procedure and if the system still shows error 10 do the following in sequence...
1. Turn off the media center via the"ALL OFF" button in the tray (no DVD disc inside the tray)
2. Turn off the bass module by the power switch underneath the bass module (certain versions may not apply)
3. Unplug the power adaptor of the media center and remove the power adaptor connection from the wall socket.
4. Unplug the bass module (if this has not yet been done
5. Disconnect all speaker wires (satellite speakers I mean)
6. Disconnet the data cable linking the bass module and the media center
7. Allow 10seconds to pass
After 10seconds then connect the following again in this sequence
1. Connect the media center and the bass module data cable first
2. Connect the satellite speaker cables.
3. Connect the media center adaptor (DO NOT TURN ON YET!)
4. Lastly connect the bass module power cable (DO NOT TURN ON YET!)
Once verything is connected, press power "ON" button o nthe RF remote and the media center should turn on. Only the you should switch the bass module power "ON" so that a fresh handshake is achieved.
This ERROR 10 occurs when either the ADAPTIQ process is interrrupted, the data calbe link between the bass module and the media center is loose or when the power connection is interrupted.
If all still fails, then there is a problem with the DSP board of the bass module and would require servicing.
I do hope I was able to help you
Sep 21, 2010 | Bose Lifestyle 28 System
Code 10
Hi, your problem seems to be related with the AdaptIQ failing to do an active equalisation. HAve you connected the AdaptIq sense headphones on the AUX (left and right coz it will still fail if only one cable is connected) Also make sure tha the sense headphone cable is in the correct color orientation and none is connected to the black jack just below the red one. Try this procedure and if the system still shows error 10 do the following in sequence...
Apr 03, 2009 | Bose Lifestyle 18 System
I have a lifestyle 18 bose system which only plays region 2 DVDs. How can I get it to play region 1 as well?
Hi, check below the media center/DVD player as to what region your system was fixed into (indicated by a number inside a globe). This is located underneath the unit just beside the serial number. FI the system indicates that your system indeed is set to region-2 then proceed as follows. IF it marks a different number region, then bring the unit to the Bose service center.
Steps in UNLOCKING REGION CODE of media center:
1. Load a DVD and wait for the display to show "REGION CODE ERROR, CONTACT BOSE"
2. Once this comes out, press eject button on your remote control but do not remove DVD disc
3. Press the following button commands in sequence (make sure they are in sequence and are pressed by looking into the media center display where a small green dot should blink indicating that each command is received).
4. First you need to initiate the system region change on the remote control:
a.while the tray is out and the DVD is still in the tray, press and release "RIGHT" arrow button
b. then press and release "UP" arrow button
c. after, press and release "SHUFFLE" button
d. then press and release "STOP" (black square symbol) button
e. lastly, press and release "MUTE" button and system should go on mute (indicated in the LCD display
After this, you now can change the region code by doing the following button press on your remote control:
1. While the DVD tray is out still and the DVD disc is in the tray, press and release "STOP" button (black square mark)
2. Press and release "SHUFFLE" button
3. Press and release number "0" button on numeric keypad
4. Lastly, press and release "ENTER" button on your remote control and the DVD tray should go back inside the DVD. The disc then should start loading and playing resumes.
5. Allow the DVD disc to run for a few minutes (if you want enjoy a full movie) to keep the region change resident before switching off again.
Now enjoy your Bose Lfiestyle DVD System REGION FREE!!!
Do note, this does not apply to Bose DVD system that are locked to region-1
Glad to be of service always!
Mar 03, 2009 | Bose Lifestyle 18 System
Bose 321 System Stuck on Hotel Mode!
Hey, try this out
-Press Enter and On/Off on the media center , on standby mode
-now hold the enter button pressed and start pressing the On/Off button. You should see a setting display on the player. The setting on display should change from video....till...Hotel Control -ON
- on that position, press the Volume 'minus' button on the media center. It should change to Hotel Control - Off.
Thanks
Brigade
Sep 25, 2008 | Bose 3·2·1 II System
The Media Center system doesn't work and the AdaptiQ CD (2) is in the Media Center. We can't put out the CD. There's standing on the display Bose lifestyle. Has someone the solution to the problem?
Dec 23, 2007 | Bose Lifestyle 38 System
Media center not working
hi
can you please help me.How can I solve this problem.
Dec 22, 2007 | Bose Lifestyle 38 System
Display Stuck
press the "Previous" or "Last" key that is right of the number "0"
Aug 26, 2007 | Bose Lifestyle 48 System
55 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
