Question about Kenmore 22422 Top Load Washer
Kenmore series 80 washer only works right on hevy duty load
It clicks and dims the power in the house on all the cycles besides heavy duty?
  • lhottle Jan 22, 2008
    I have a similar problem the washer was working fine then it stopped all of the sudden during a wash cycle. When I pull the knob to run it the machine will buzz and flicker the power and tripm breakers.
Washer makes a rattling noise when it is on the spin cycle.
how do i open it?
how do i fix it?
Posted on Mar 15, 2008
    Problem Solver:
  • 19 Answers
Posted on Jan 30, 2008
Why does it work in all cycles except heavy duty?
I think I answered this before. Get an electrician to check the motor windings etc to see if there is a problem under load.
Feb 17, 2016 | Washing Machines
Kitchenaid dishwasher lights on dimly. Does not cycle. Heavy Duty will grind away for a minute or so but then quits.
You need to check the power connection located under the unit. Make sure all of your connections are tite and secure. Also you need to make sure that there is also enough of wiring tied together to give you enough current to operating the unit. Also need to make sure at your electrical panel you have a at very least a 15amp breaker.
Aug 23, 2014 | Dishwashers
I have a Whirlpool Duet Dryer that is locked on the heavy duty cycle, I cant switch to another setting, it wont cancel out. I've tried unplugging it for some time to reset it. It is still stuck o
when you unplug it you're resetting the computer board just like your house computer does,so if it helped by unplugging it i would have to say the board is bad and needs to be time send the model number off of the machine
Feb 02, 2018 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
When running it will cycle and dim lights. Sounds like it bogging down. Is this a thermostat issue?
When you say, "Dimming the lights"-- are you talking about the lights on the unit?- or on the House wiring circuit?
Tell me more about what else is running on this circuit?-- Like another fan-- or several lights?
Tell me more about your term: "Sounds like it is bogging down"-- Was the unit reunning fine, and THEN started to Bog Down?-- Or does it bog down right from the starting up on the unit?
Can you read the name plate on the unit?-- How many amps does it draw?
Are you running it right from a receptacle?--- or from an extension cord?-
is the cord a nice heavy duty cord?
It sounds like you are not giving the unit sufficient amps for the work it needs to do.
Tell me more-- let's see if we can fix this dehumidifier! :-)
Mack B
Jul 04, 2011 | LG LHD65EBL Dehumidifier
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
I have a 200 lc hitachi excavator replaced starter 3 weeks ago now machine is clicking the cylanoid beside the batterys and wont roll over
check battery connections at the terminals and at the ground point poor connections will kill starters and Oh so much more good luck
Oct 05, 2009 | Heavy Duty Associated Equipment 6002B...
Kenmore series 80 washer only works on heavy duty cycle.
bad transmission,,check voltage...below 110 with load and water pressure switch or hose defective..
Dec 24, 2008 | Kenmore 24902 Top Load Washer
GWL15 no hot water on Regular or Heavy Duty Cycles
should you select a 40* wash it would not be right if the machine filled with hot water, as the water in the house tank is a lot more than 40* ( around 65* i think?) this would just damage the clothes and i am sure you would just complain again at that.
if the machine works fine then there is no problem
Oct 10, 2007 | Fisher and Paykel GWL11 Top Load Washer
Kenmore 22422 Top Load Washer Logo
147 people viewed this question
Sal De
 Brian Main
Brian Main
