I cleaned out the parts that unscrew for the red handle mini butane gas powered iron it was empty then I filled it up, then lit it and the flame was as a regular lighter not a touch, how do I fix it?
  • 11 Answers
SOURCE: poor gas flow. Burners will not stay lit. Gas
Try taking a large hammer or set of vice grips and banging pretty heftily on the tubes feeding the burners. These are usually build ups of Carbon. If not, then make sure your connections are good (sort of move them around to see if they are loose), and make sure your propane is not getting too close to empty (you can shake it around and feel/hear the propane).
Posted on Aug 10, 2009
SOURCE: Dunill lighter - how do I fill it with butane?
  1. Ignore that other load of tosh.
  2. Do not refill your lighter immediately after using it. You should allow enough time for the lighter to cool off.
  3. The flame height adjuster on the bottom of the lighter should be set to minimum by turning CLOCKWISE with a small screw driver. The smaller, usually Phillips head, screw is for dismantling the lighter and should not be touched. The adjusting screw is a larger screw with a standard (slot) head. Some lighters come with a key to turn the adjusting screw. Some models have an adjusting wheel that requires no screwdriver. Please DO NOT FORCE the adjusting screw. If it is hard to turn in one direction this most likely means that the adjustment screw is already at the (-) or (+) limit. Try turning the other direction.
  4. Push the refilling valve with a screwdriver to let out the air inside until no hissing sound is heard. Hold the lighter away from your face. Air inside the fuel tank prevents butane gas from being injected into the tank and causes the lighter to malfunction.
  5. ALWAYS refill the lighter in an upside down position to avoid injecting air into the lighter.
  6. Shake the butane gas refill can, press the stem of the refill can directly onto the refill valve on the bottom of the lighter. Keep them in a straight position and let the gas go into the lighter for about 5 seconds. Repeat for a shorter period if needed.
  7. Allow 3-4 minutes to let gas and lighter components reach room temperature.
  8. Turn the flame adjuster counter clockwise to reach the desired flame height.
  9. Hold the lighter away from your face and body and ignite it carefully. If there is no flame, repeat the refilling process.
  10. If you experience gas leakage with a hissing sound while refilling the lighter, either you are not holding the lighter and gas can in a straight position or the stem of the gas can is not suitable for the lighter. In this case you need to use an adaptor which is usually supplied with the gas can.
  11. Premium butane is required to ensure optimum performance of your lighter. Lighters require the cleanest butane available at a pressure of 45 psi. Recommended using Premium Triple Refined Butane Gas that are packaged in 10-13 oz. cans with a metal fill tip nozzle. Non-premium butane with plastic fill tip nozzles are not recommended as they may cause inconsistent ignition and performance. Impurity of the gas can cause clogging of the burner valve or malfunctioning.
    WARNING: PLEASE, ALWAYS KEEP YOUR LIGHTER AWAY FROM THE REACH OF CHILDREN. USE COMMON SENSE IN HANDLING YOUR LIGHTER.
    Troubleshooting: If you are having problems with your lighter, make sure that:
    You are holding the lighter upside down while refilling. If you did not hold the lighter upside down, there will be air inside the butane tank. You will need to let the air out and try refilling again.
    The flame height is properly adjusted.
    You are not using cheap or incorrect fuel.
    There is no dirt or debris in the lighter. Try blowing forcefully into the top part of the unlit lighter.
Posted on Sep 18, 2009
  • 7 Answers
SOURCE: gas handle (right side) of a Red Mini Racer
@ www.funcreation.net
type in mini racer ,red in the search box and browse to all the parts you need
Posted on May 19, 2010
  • 1514 Answers
SOURCE: Bought mini butane soldering iron
When you fill the soldering iron with butane you must have it turned so the butane can is held upside down. Liquid butane must be able to flow into the iron. It's most likely that you held it upright and even though gas butane would have flowed in it would not be enough to light it. Only fill it outdoors.
Posted on Oct 05, 2010
jakirk
  • 103 Answers
SOURCE: several new torch lighter, filled
adjust the fuel output , it is easiest to do by holding the button down while lighting the flame with a seperate lighter and then setting the flame on the lighter that does not ignite proper, also take into account that the temperature of the lighter by being held in your hand for a while or by being in your pocket can have a great effect on the pressure of the buttane being expelled.
Posted on Jan 21, 2011
Express soldering iron normally has a blue flame , but today when I lit the gas it just gives off a large non directed yellow flame?
could be low on gas if propane or if not its the porcelan blocks however not sure we are speaking of the same iron
Mar 16, 2016 | Blue Flame Heating & Cooling
Weller Pyropen WPA2 extinguishes itself after a few minutes.
Gas (condensation really) may be freezing and constricting flow. Try warming the tip a bit with a hair dryer see if it goes longer.
Jan 11, 2014 | Weller WPA2 Pyropen Professional Self...
Wfg361lvd
If you have a standing pilot (always lit), the adjustment screw is normally located behind the burner control knobs.
Dec 22, 2012 | Whirlpool WFG361LVD - 5.0 Cu Ft,...
Misplaced Manual, what butane container to get.
Any butane will work, but the big name-brands are usually filtered better and less likely to cause problems. The biggest issue is the nozzle -- there are a lot of different sizes. Any Weller butane can will fit perfectly (usually cheapest at the local Sears store), but any can with multiple adapters will also work.
If you have an old can that fits, save the nozzle when it's empty. It should fit a different can if you can't find a can that fits the tool.
Jun 04, 2012 | Weller WPA2 Pyropen Professional Self...
Hi i have an old weller soldering iron and it wont light up, do i have to have the 2 slide controls in a certain position
A soldering iron is composed of a heated metal tip and an insulated handle. Heating is often achieved electrically, by passing an electric current (supplied through an electrical cord or battery cables) through the resistive material of a heating element. Another heating method includes combustion of a suitable gas, which can either be delivered through a tank mounted on the iron (flameless), or through an external flame.
Mar 24, 2011 | Milwaukee Tool Weller Pyropen Jr Cordless...
Bought mini butane soldering iron today filled with butane and used it. It was getting low so i put more butane in it and now i can light it. please help
Oct 05, 2010 | Radio Shack Welding Tools
What power source do i connect my hot devil soldering iron too
That would be a butane source, that unit runs off butane gas.
check out www.hotdevil.com.au
Aug 10, 2010 | Welding Tools
Torch has excessive gas flow at the lowest setting.
With empty tank you can try to unscrew the black parts and clean or tighten the regulating lever.
Jun 18, 2010 | Radio Shack Mini Butane GasPowered Iron
Dec 15, 2008 | HHP 12V Cigarette Lighter Adapter (for the...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
