My machine comes up water fault e5 wat can I do starts to wash than after washing a few minutes to go to rinse stops and puts up e5 water fault call customer service
SOURCE: Washer not completing cycle
I HAD THE SAME PROBLEM ON A 4 MONTH OLD MACHINE AND I CALLED A SERVICE PERSON. HE SAID THAT I CAN THROW IT AWAY. THIS IS A PROBLEM THAT NOBODY CAN FIX.
Posted on Feb 15, 2007
Jimster
  • 240 Answers
SOURCE: hotpoint wma10 washing machine wont stop filling up
You may have a problem with the pressure dome hose (has a cut or kink in it) or it may be a problem with the main control board. Sometimes that small hose inside the machine can get a cut or come loose. That sends pressure to the board and its valve to let the machine know that it has the right amount of water in it. If it has a hole or is blocked, that signal wont ever come on, and you have overfilling.
Posted on Sep 07, 2007
SOURCE: Washing machine wont stop filling up
check hose to water level switch, if it has had an out of balance situation it can loosen or detach hose. replace hose firmly back on switch or replace hose if that doesn't work.
Posted on May 29, 2008
SOURCE: Washing machine problem
my w830 is doing exactly the same thing.
I am usually pretty good at fixing these sort of things so if/when I solve it I will post back here.
I think it is a motor fault - most likely the motor brushes are worn out.
Posted on Aug 07, 2008
  • 4 Answers
SOURCE: I have Model WF-S6607?WF-S6607TC. Washing Machine.
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
Posted on Sep 09, 2009
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
Year old Bosch SHU33A0UC won't start. Lights on
Light's on mean you have power.
Initiate the self test program by doing the following -
ON/OFF button.
RINSE & HOLD = NTC (temperature sensor) fault – note circulation motor stops shortly after it started
during an NTC fault
where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150ºF) and water won’t stop
Let me know what you figure out. I can repair these boards most of the time.
Dec 18, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Moffatt washer is washing and draining but not spinning out the clothes
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 03, 2009 | Washing Machines
Washer stop in middle of rinse cycle
Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
E5 comes up when running wash cycle
in this case e5 means too much water in the machine when it is supposed to rinse.
these machines have either a solenoid opperated drain valve or a drain pump.
could be a kinked or pluged drain hose. check this by removing the drain hose (probably red) from the drain it attaches to (probably under a sink)
put the hose in the sink or bucket and wait for it to drain, drain should be fairly powerful (hold the hose and be careful the water is hot)
if the hose is not kinked and little or no water comes out you have likley have an obstructed drain valve or a broken pump or solenoid.
at this point i would call in the pros, or you can try to fix it yourself then curse and wish you had called the pros.
good luck
Aug 19, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
4E code keeps apearing
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 29, 2009 | Washing Machines
Asko Quattro 6661 water inlet fault
I had the same problem with my unit. The manual tells you to disconnect the water intake at the machine and clean the screen. This wasn't my problem because as you said the problem doesn't occur until the Rinse cycle which means there is water supply to start the Wash cycle.
From the back of the unit, remove the three screws and take of the lid. You'll notice that there are three separate motors do pump water inside the machine at the water intake. When standing in front of the machine, the motor on the right controls the rinse cycle. I connected an AC volt meter to that pump and started the rinse cycle. 240v showed up at the pump, but the water flow was poor. I simply squished up and down the rubber hose connecting this motor to the detergent unit and was unable to free the clog and water began to flow.
Jan 07, 2009 | Asko W6661 Front Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
Oct 04, 2007 | Bosch WFE 2021 Front Load All-in-One...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
