Have a raychem Quickstat thermostat for in floor heating & have 230v coming in but no display on thermostat.
  • Joe Judkiewicz Dec 14, 2016
    No battery, have another thermostat in kitchen for other half of floor heat. Tried switching thermostats & no display on the switched thermostat that was working properly.
    Top Expert:
  • Heating & Co... Master
  • 78,010 Answers
Most thermostats like this use batteries to run the LCD display, are you sure it doesn't just have batteries that are dead?
Posted on Dec 14, 2016
My thermostat won't turn on for boiler system
Do the thermostats have batteries? could be batteries are dead.
Sep 22, 2017 | Thermostats Heating & Cooling
My Quickstat has stopped working completely. not a gfi reset issue, but zero display. there is still power to unit. Im guessing that I need to replace unit.
Raychem QuickStat-TC Installation & Operation Manual > Brands > Raychem Manuals > Thermostat
View and Download Raychem QuickStat-TC installation & operation manual online.QuickStat-TC Thermostat. QuickStat-TC Thermostat pdf manual download.
Raychem - QUICKSTAT-TC, Programmable, Thermostats ... > ... > Floor Warming > Thermostats > Programmable
$144.29 - ‎In stock
Raychem QUICKSTAT-TC Programmable Thermostat Programmable Thermostat, 120/240V, 16A, GFCI, 4 Programmable Events per Day.Missing: tyco ‎working
Raychem Quickstat Floor Heating Thermostat Installation ...
Dec 26, 2015 | Raychem by Tyco QuickStat-TC Thermostat
Favorit 84470VI
Heater, 230V./2000W.-d.32mm.
The heating element, which is encased inside a tube, is used to heat the washing water. The heating element is not activated during the drying phase. Inserted into the delivery side of the washing pump and coupled with the duct which directs water to the upper spray arm.
Built-in safety devices: Two thermostats
First thermostat: auto-reset bi-metal thermostat calibrated to 98°C and connected in series to one branch of the heating element.
Second thermostat: manual-reset fuse calibrated to 206°C and connected in series to the second branch of the heating element. If this fuse intervenes, the heating element is disconnected definitively.
25966855-vhkvuwxe0dpywjiqbdtoypy4-4-0.jpg Dado
Nov 18, 2015 | AEG Dishwashers
Nuheat thermostat keeps rebooting
replace the thermistat module..sounds like it has a bug in the firmware
Jan 08, 2014 | Nuheat Harmony Thermostat
Rear Floor Vent heat only
Sounds like your heater coolant hose door flap is broken or loose. May want to check behind the heater controls, if your components are mechanically operated. If electronically, may need to perform more troubleshooting before replacing this component.
Jun 17, 2017 | 2004 Ford Econoline
I have a white-rodgers type #1F86-241 thermostat. Not sure if my problem is thermostat or not but this is what I have. currently have two zones first floor and second floor. Second floor is problem. I...
From what you're saying I would reccomend that you start with a new thermostat. I think that will take care of your problem, but I've always started troubleshooting by doing the easiest and least expensive first. Hope this help. Thanks
Nov 21, 2010 | Heating & Cooling
Compressor will not start, GSC14-14 SEER
Control wires come from the thermostat to power the contactor coil. At the thermostat the red wire must power (switch) the yellow wire to make the contactor pull in to run the outside unit, Check power with a ac volt meter between the red wire and the yellow wire, with the heat/cool switch turned to off. If you do not have 24 volts ac, your wire may have an open from the thermostat to the outside unit, your transformer may be bad and not supplying power, or your contactor coil may be open
Jun 23, 2009 | Goodman CKL30AR30 Air Conditioner
Slow heating
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
thanks and please do not forget to accept the solution
Apr 03, 2009 | Maytag MGR5770 Gas Kitchen Range
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
