Question about Miscellaneous
Fuel point bzlance - Miscellaneous
Trying to check my Kroger fuel points but get too many pop ups and no information. Web site is useless.
There is often a small link at the bottom of the screen saying 'Send Feedback'. and here you go, there is. I get no pop ups :>)
I found this about Fuel Points.
How do I keep track of my fuel points?
Your current fuel points balance is located at the bottom of your Kroger receipt. You may also
Customer Service
Dec 04, 2016 | Cars & Trucks
Kroger fuel points.
points have an expiration date if not used link shows how to track your points
Kroger
Sep 01, 2016 | Cars & Trucks
How to cut the gas valve off on Yamaha warrior
Hi Anonymous, if you have a carburetor the petcock/fuel valve is located on the bottom rear of the left side of the fuel tank. With the long end of the lever pointing straight back the fuel valve is in the off position and no fuel will flow to the carburetor, with it pointing straight down the valve allows fuel flow from the gas tank to the carburetor, with it pointing straight forward it is in reserve mode and you have roughly 1/2 to 1 gallon of fuel left in the gas tank. If you are fuel injected there is a low fuel warning light either on the dash or speedometer. If you have a fuel gauge refuel before it hits empty just like your car. Good luck and have a nice day.
Nov 15, 2015 | Yamaha Motorcycles
1969 MGB-How to change fuel filters on duel carb MGB
Many back then only had a little screen at the fuel pump, others had a single inline with the gas line at the firewall, many were added by owners or mechanics just before the carbs. The main problem with fuel delivery is the points getting stuck on the fuel pump. If its not clicking audibly when you first turn the key, tap the pump lightly to loosen the points. Yes, there are points in the fuel pump. about 2 clicks a second to fill empty carbs.
Oct 26, 2013 | Toys
Taurus will not start when pointed uphill but will start when pointed down hill
When you pointed uphill the vehicle or downhill how much fuel do you have in the tank? If is low,surely one reason is the fuel capacity in the tank and it is not enough for the fuel pump pick up to reach.
Jan 02, 2013 | 2003 Ford Taurus
How do you switch fuel to reserve on a Harley davidson sportster
Hi Anonymous, if you have a carbuerator the petcock/fuel valve is located on bottom rear of the left side of the fuel tank. With the long end of the lever pointing straight back the fuel valve is in the off position and no fuel will flow to the carbuerator, with it pointing straight down the valve allows fuel flow from the gas tank to the carbuerator, with it pointing straight forward it is in reserve mode and you have roughly 1/2 to 1 gallon of fuel left in the gas tank. If you are fuel injected the is a low fuel warning light either on the dash or speedometer. If you have a fuel gauge refuel before it hits empty just like your car. Good luck and have nice day.
Oct 31, 2012 | Harley Davidson Motorcycles
Where is the fuel shut off valve on a 2004 RK fltr
Oct 05, 2012 | 2004 Harley Davidson FLHR - FLHRI Road...
Which way to turn the gas shutoff valve for reserve on 92 harley fatboy
Sep 22, 2012 | 1979 Harley Davidson XLS 1000
2007 sportster gas reserve location
May 13, 2012 | 2007 Harley Davidson XL 883 Sportster
Will not run. Cleaned carbs - new points -condensers - fuelled - started once then died.checked fuel tap and filter. Fuel not getting through? Plugs dry.
Try re-installing the points , it is common for points to short. Pull a plug and check for spark first (both sets of points). You can check for fuel in the carbs by opening up a bowl drain screw and seeing if fuel comes out. If you have spark and fuel in the bowls you may need a carburetor cleaning. Poor spark can also be caused by bad spark plug caps on the wires. Typically you can unscrew the cap from the end of the wire. If it OHMs out higher or lower than 5000 replace them . You can get NGK caps for about $5 each.
Sep 22, 2010 | 1977 kawasaki Z 650
Miscellaneous Logo
18 people viewed this question
Top Miscellaneous Experts
steve cannon
Level 1 Expert
Philippe Dekyvere
Level 1 Expert
bill tarkulich
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
