Question about Cell Phones
I have a Unisonic #9173X that intermittently loses its capability of sending out a tone when pressing a button! Currently, I press a button and SILENCE! Can this problem be fixed ONCE AND FOR ALL?
Radio Shack told me that I have a worn out keypad, but I want to take the phone to a service repr. to confirm the problem and get it fixed, IF feasible! Where is the nearest service center for Unisonic Telephones to ZIPCODE 94403? Thanks!
    Top Expert:
  • Cell Phones Master
  • 77,932 Answers
Any cell phone shop can repair this.
Posted on Dec 14, 2016
Good day! I have a Canon MX-328. I was expecting to receive a fax so I read the manual and I set my printer to Tel priority mode since we only have one phone line mostly for voice calls. According to...
You have explained your question with very good detail
Press the colour button, then hang up. Most faxes are capable of transmitting colour faxes, and you should press the colour because even if the sender sends a B&W Fax, it will Automatically receive it in B&W. If they send a colour fax and you hit the B&W Button, it will only receive in B&W.
I hope this helps, if so please rate this answer below Thank You for supporting the FixYa Community
Regards GM
Apr 25, 2011 | Canon PIXMA MX300 All-in-One Printer
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
How ican send a fax with samsung scx-4521f?
first you connect the telephone port to your machine and telephoe line.
.then load your fax document to ADF. then their is a button in your machine its name ON HOOK DIAL .press it then you can here some dial tone. press fax number if you wont to send. then you can here some ringing tone and press start button after fax tone coming.
Jan 12, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I have new canon pixma mx 328. how to do fax operations of sending and receiving
It is very easy
To Send Fax:
1. Place the documents facing down in the flatbed scanner glass or insert in the ADF unit with the documents facing up.
2. Press the Fax button
3. Key in the number of the receiver then press the black or color START button.
4. Listen to the dial tone and see in the lcd display the message "transmitted" to confirm that the documnets have been sent.
Using the phone is attached to your printer (documents is already load to the printer)
1. Call the number of the receiver.
2. Ask for a fax tone.
3. Once you heard the fax tone, press the Black or Color Start button
To Receive Fax (Set up first the number of calls before automatic giving fax tone to caller)
1. When someone is trying to send a fax to you, don't answer the ring on the phone, let the printer give the fax tone.
To receive the fax on the printer with the user's help.
1. When someone is calling, just press the Black or Color Start button.
To receive fax when you answer a phone
1. While the phone is lift up, press the Black or Color Start button to receive the fax.
Hope that information will guide you.
You can thank me by just rating this help.
Thank you for using Fixya.
Dec 14, 2010 | Canon PIXMA MX300 All-in-One Printer
Don't confuse the two. In most systems, the RECALL button gives you new dial tone on the line you're currently on, and the REDIAL function will dial the last number dialed or a saved number.
Since you're asking about a phone and did not list the SYSTEM, if you set has Last Number (LNR) or just redial, when you press the button, it will either try to use the last line dialed, or you may have to select an outside line and get a dial tone, then press the LNR button. It will dial out. If you press the RECALL button, it will drop your present call and give you new dial tone without having to hang up, pick up the handset, and select a line. You may actually have to press both buttons to effect a LNR sequence.
Aug 18, 2010 | NEC ETJ 16DD-1 Corded Phone (necetj16dd-1)
We have an old Unisonic model 9325 corded phone that has the capability to program phone numbers in it but cannot find the manual. Any way to get instructions on how to program with numbers?
I have an old Unisonic 9725, and the programming method for that phone may work for yours.
1. take handset 'off hook'
2. press: store
3. enter phone no.
4. press store
5. press memory button 1, 2, or 3...or 0-9
6. put handset back 'on-hook'
to use: take handset off hook, and press the memory number that applies.
Jul 03, 2010 | Unisonic (9742) Corded Phone
How to use the 5 button timer
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remianing time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Sep 26, 2009 | Stoves 720EF Electric Double Oven
dial the fax number .. when some one answer ask for a fax tone... then press the send button..
some fax machine when you call the number it automatic give you fax tone ,, after that press the send button..
Sep 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Sending a fax
First make sure that the fax button has been pushed and is llit...
The 2820 should have a handset. In order to use manual transmission (when you get to hear all the beeps and whistles) you will need to load the document then pick up the handset. then dial the number, when you hear the recieving fax tone then hit the start button.
The 2820 should also have a hook hold button pressing this will allow you to hear the dial tone and the numbers you dial along with the receiving fax tone. If you dont hear anything when you press this button then you may want to use the volume buttons to increase the volume.
Also remember that if you have not picked up the handset or pressed he hook/hold button the unit will use automatic mode, which is to say that all you will do is load the document, dial the number, and then press the start button.
May 19, 2008 | Brother IntelliFax-2820 Laser Fax
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
