SOURCE: Can I print in Dos Programme with USB Printer
Assuming the printer can understand DOS coded printouts (which most should be able to), you can do it like this: Go to Control Panel | Printers | ML 2010 and share the printer. Then go to a command prompt Start | Run | type cmd Assuming that you share it with the share name "MYPRINTER" and the computer is called "MYCOMPUTER", then type NET USE LPT2: \\MYCOMPUTER\MYPRINTER /PERSISTENT:YES at a command prompt. Now you can print to LPT2: and the output will go to the USB-connected printer. To find your computer name, right click on the My Computer icon (either on your desktop or the start menu) and choose properties. The window that opens will have a Computer Name tab.
SOURCE: Samsung ML 2010 won't paper feed
Lift up the front of the machine a couple of inches. I put a small bo under it. The paper then feeds slightly downhill.
Worked for me.
SOURCE: Faint vertical lines on Samsung ML-2010
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
it is the clutch relay and or driver on the board HVPS Q6 and or Q7. The clutch will not allow the gear to release. I have seen this and is most common problem.
Streak www.streak.asia
