Question about Panasonic Televison & Video
Have Panasonic The;37pw5 plasma tv . How do I get broadcast tv?
  • Coriander Dell Fina
    Coriander Dell Fina Dec 30, 2016
    Got a converter box and ant
    enna. Has great picture, but no sound. Rescanned channels. This may be reason for second box, as mentioned. Have an extra and will also check cables to be sure they work and are connected properly. No one else had a clue!
    Also checked Volume/mute... Still have to get the other part...
  • Panasonic Master
  • 5,429 Answers
You will need some sort of digital (ATSC) to analog (NTSC) OTA signal converter (set-top box) with an antenna. The Panasonic TH-37PW5 only has NTSC (in the US) or PAL (UK) tuners. There may be a few low power NTSC stations still broadcasting in the U.S. However, you need to be close to their transmitter to receive the signal. You can use one of the original converter that were available with the government coupon. There are some newer models available. Look at your choices carefully. You will need a converter with RF, composite video or component video output. Any model with only HDMI out will require an additional converter connected between the set-top box and the TV.
The specifications for the TH-37PW5 are available on page 38 of the manual. This is available from Panasonic here: ftp://ftp.panasonic.com/television/om/th-42pw5_en_om.pdf .
I hope this helps.
Posted on Dec 15, 2016
Have a Panasonic TH-37PX60U tv - can I hook it up to a HD Satellite receiver - have a Bell hd but don't get any reception
Your plasma tv will display HD content when you connect an HD source (Blu Ray Disk, Sony PS3 / PS4 or Xbox 360, HD Cable Box, HD satellite, etc) via the TV's HDMI1, HDMI2, Component1, Component2 jacks or if you connect a UHF/VHF TV antenna (not cable box, etc.) to the "Ant" connector *and* you're close enough to a broadcaster with HD content to view.
Using any other input will produce only the lesser quality SD video signals. Review the manual - linked below - to help you connect the components you have.
http://service.us.panasonic.com/OPERMANPDF/TH37PX60U.PDF
May 13, 2015 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Panasonic th 37pw5 tv
Sorry if this is late. I have the same issue and I have found I have to disconnect the receiver box before the pc function works. It is annoying to say the least
Feb 09, 2014 | Sony Computers & Internet
Background dark
Hello Roberto
Same with my Viera plasma. Some channels re-broadcast shows or movies that look darker. I believe it is the station that is doing that since they looker darker on my TV, yours, and on LCD TVs too. You could possibly brighten your display by choosing different settings in your menu... but what your TV is displaying is correct. It is the broadcaster that perhaps decreasing the signal... since other stations look fine I assume.
Jeff
Nov 02, 2013 | Panasonic VIERA Televison & Video
Can my Panasonic TC-P42X1 receive digital channels without an antenna connected? It sounds like a stupid question considering its a high-def TV, but I'm having troubles getting the TV to pick up...
No.Tv can't pick up any reception or receive any free AIR broadcasting tv channels at all if tv have no antena hook up to a tv.Buy a better antena design to used like a Digital atenna,will solved this problems.
Aug 21, 2011 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Panasonic TC P50S2 tv loses sound fairly often. use at&t uverse hd receiver and after rebooting the dvr/receiver, the muting problem is gone for between 1 day and and 2weeks. at&t says the tv...
Use the component connection not the HDMI. Some of the ATT boxes have issues with the HDMI ports. Uverse is only broadcast in 1080i not p so you will not lose any video quality.
Apr 27, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
How to convert from pal bg to pal I in panasonic th50pv30
Specifications for the Panasonic TH50PV30 Plasma. Broadcast Standards, PAL-I.DVB, AV-NTSC:PAL 50/60Hz, NTSC, M-NTSC. Picture size, 42" (106cm) Discontinued Model.
Should work, have a look in the intallation menu for the correct country that you want.
Hope this helps.
Mar 09, 2011 | Panasonic TH-50PV30 50 in. Plasma...
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Why is the screen orange on my plasma tv
Ur tv is missing a blue color.U tv might have a bad incomming broadcasting signal cable.Try watch a DVD movie,to make sure,if u have all three colors guns like R,G,B on the tv.If DVD movie have the same problems,than ur tv have a dying tv Tuner signal board,that take in the incomming broadcasting signal cable.
Mar 03, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Please can you advise me; will my panasonic TXP42C2B TV WORK IN THE USA
NO.
This plasma tv has the freeview tuner.
The USA TV needs ASTC tuner.
The electrical power in the USA is 110volts at 60Hz
The electrical power in UK is 240volts at 50Hz
The broadcast signal encoding in the USA is ASTC.
The broadcast signal encoding in UK is DVB-T.
Feb 15, 2011 | Televison & Video
No sound on two local channels..all others working fine
This problems useually not the tv.It is the tv stations itself have broadcasting signal problems.If tv have a problems all the tv channels would have no sound at all.
Jan 11, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Televison & Video Logo
51 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
