Question about Boating
How to rebild the carborater on 1994 mercury mariner 60HP outboard motor.
captainjeffq
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
finish line
  • 207 Answers
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
Posted on Jun 27, 2009
  • 53 Answers
SOURCE: stearing on my 4yo 60hp mercury outboard will not
if you have "rotary" or "rack and pinion" steering. what your dealing with is rust. 2 things you can do to test the steering system. (1) tilt engine all the way down using the trim an tilt system. On the engine, you will see a steering rod that is parallel to the transom. One side of the rod is connected to the engine(ignore that connection), the other side curves down and connects to the steering cable. Disconnect steering rod from cable by unscrewing the nut counter clockwise. Once you disconnect the steering rod from cable. Push steering rod forward towards bow swinging it out of the way. Engine is now free from boat steering system. “Testing the engine steering tube“ all you have to do is manually turn the engine port and starboard using your hands. If your able to turn engine, the problem is the boat steering system. which you can fix. If you can' turn the engine then the job will require the engine to be removed from boat and transom bracket rebuilt. Take it to a repair shop.(2) with the engine still disconnected from the boat steering system. Get in the boat and turn the steering wheel. A good steering system you should be able to turn the wheel with just a finger. If wheel does not turn, you have one of two problems. Bad cable or bad steering helm. I always tell my customer to change both as a kit as a safety issue. if you are trying to save money. pull cable from helm, turn wheel if it turns easy replace cable (keep cable don't throw it away you have to get it matched) if wheel still stuck replace helm.
Posted on Nov 01, 2009
alicantecoli
  • 22326 Answers
SOURCE: mercury outboard 3.5 motor stalls
not sure here as i normally answer car questions but if this engine is of the new generation and its all electronic then it has to be plugged in to locate the fault .My outboard was playing up like this with loss of power and the dealer wanted a small fortune to repair the pump which feed the fuel injection system so i took it apart and made a new valve for it out of a piece of fishing hook plastic wrapper and a bit of copper wire hook type thing i made and that was about 5 yrs ago and its still running fine
Posted on Apr 13, 2012
  • 183 Answers
SOURCE: 45 hp mercury mariner outboard motor wont go into
will probably need a manual on your motor for this problem. perhaps careful disassembly will reveal the problem.
Posted on Jun 05, 2014
How to drain carb bowls on 1999 mercury 2strock 3cyl 60hp outboard
Hey Geoff,,, there is a "bolt" on the side of the float bowl,, unscrew and remove it,, gas should flow out, freely.,,while the "bolt" is out.. pump the bulb and this will help flush out some crud..BUT - For a complete cleaning,.. you need a qualified professional... its #25 on the diagram Parts for Mercury Marine 60 HP Bigfoot 3 Cylinder Carburetor
Jul 04, 2017 | Mercury Boating
Why does my mercury outboard idle perfectly but stall out under load?
Your carbs are probably dirty. Remove the carbs and clean out all jets and passages with carbcleaner and compressed air.
Nov 13, 2014 | Clymer Mercury/Mariner 75-275 Hp...
6fos 000292
only numbers matching yrs are a 60hp mariner 1983.
Jul 20, 2014 | Light Outboard Motor Boat Bass Fishing...
Serialog157765
1994 to 1998 Mercury or Mariner 20HP
Nov 08, 2011 | Light Outboard Motor Boat Bass Fishing...
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
Boating Logo
110 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
