Question about Cell Phones
Settings as an app - Cell Phones
How do I update the Google play store app
  1. Turn the phone off, wait a bit, and turn it back on. Do this outside or near a window for best results.
  2. Check your phone Settings. Is Wi-Fi enabled? Is Data enabled? If you don't have at least one of these enabled, you won't receive updates. If you only have Wi-Fi enabled, you will only receive updates when you are connected to the internet via Wi-Fi.
  3. Check Apps in your phone Settings. Make sure the Google Play Store app is enabled.
  4. Check the settings within the App itself. You can set the app to update automatically.
  • Launch the Play Store app.
  • In the upper left corner, touch the three horizontal bars next to Google Play.
  • Touch Settings (near the bottom).
  • Touch Auto-update apps and select one of the choices. I have mine set to "Auto-update apps over Wi-Fi only."
If none of this works, contact your provider.
I hope this helps!
Mar 29, 2015 | Tablets & eReaders
How do i delete my facebook account off my phone
The best advice that I can give you is to actually DELETE the "Facebook" app from your phone. If You have the "Facebook" mobile app installed on your phone, here/s how to DELETE/REMOVE it.
1. Tap on APPS.
2. When you find SETTINGS Tap on SETTINGS (You are NOT looking for Google Settings, You are looking for the actual system settings which is labeled as SETTINGS in your APPS menu).
3. Tap SETTINGS
4. Scroll down until you see APPS
5. Tap on APPS.
6. Scroll through the list of apps until you find the Facebook Mobile App.
7. Tap on CLEAR CACHE
8. If there are options to CLEAR any other files then be sure to click on those options as well
9. FINALLY click UNINSTALL APP
10. When the app finishes the uninstall process RESTART YOUR PHONE.
NEXT TIME YOU GO THROUGH THE APPS THAT YOU HAVE INSTALLED ON YOUR PHONE, THE "FACEBOOK MOBILE APP" SHOULD NOT SHOW UP IN YOUR LIST OF APPS THAT YOU CURRENTLY HAVE INSTALLED ON YOUR PHONE.
Jul 08, 2014 | Motorola Mobility Droid RAZR HD
Apps utorrent, viber and tango cannot open
  1. Press your device's Home button.
  2. Press your device's Menu button.
  3. Tap Settings (or System Settings).
  4. Tap Application Manager (or Apps).
  5. Scroll to find the app you want to clean up, then tap the app icon.
  6. Tap Force Stop.
  7. Tap Clear Cache. Try using the app again to see if it's working fine.
  8. Still experiencing a problem? Go through steps 1-6, and then tap Clear Data.
    • Clearing the app data will remove any custom options and settings.
Dec 02, 2013 | Polaroid 8-Inch Android 4.0 4 GB Internet...
How do I get privacy off my facebook page I don't remember putting it there
Every Facebook account has access to the website's app ecosystem, which allows users to play games, and use third-party tools from within the Facebook environment.
When you sign up to use most apps, you also subscribe to updates and notifications from the app's creator.
If you want to completely get rid of pop-up notifications on your Facebook page, you can remove the app from your account settings.
Go to facebook.com in a Web browser, and log in with your username and password.
Click on the "Account" button in the upper-right corner of the page, and choose "Privacy Settings" from the drop-down menu that appears.
Click on the "Edit your settings" link in the section of the page labeled "Apps and Websites."
Press the "Edit Settings" button next to the "Apps you use" section.
Click on the "Edit Settings" button for the app that you want to remove.
Press "Remove App," then click "Remove" to confirm your decision.
Facebook will now remove the app from your list, and stop displaying pop-up notifications from it on your page.
http://www.facebook.com/help/?page=964
Adding & Displaying Apps
Sep 11, 2013 | Anonymizer Privacy Manager (1235215SF)
What does code 912 mean? i get this when downloading apps from apps store
There are a few reasons why you would get a 912 error when downloading apps.
  • Downloading apps directly to an SD card
  • Play Store (app store) needs to be updated
  • Bad cache
The following methods could help solve the problem
Clear Cache and Reboot
  • Go to Setting >> Go to Application Setting (In some devices application setting is named as apps).
  • Go to, All the apps > >Find the Google Play Store >> Clear Data and Cache
  • Once you have clear everything, Next you need to Force Stop the application
  • Also, try to clear Cache and data of Download Manager and Google Service Framework.
  • Now, Restart your device and try to download the app.
Unmount SD Card
  • Go to Setting >> Storage >> Scroll down and select "Unmount SD card"
  • Open Google Play Store >> Download the app again that was giving you the error message
  • After successful installation, Go back to Settings >> Storage >> tap on "mount SD card"
  • If above steps didn't work, also try removing your SD card before installing.
Move app to phone
  • Go to Settings >> Go to Apps >> Select, All the apps
  • Scroll down and select the app that was giving you the error during update
  • Select "Move to phone"
  • Open Google Play Store and update the app
  • After successful installation, you can move the app back to SD card
Feb 01, 2018 | Tablets & eReaders
Im frOm philippines 26 F.. how can i remove my social extras to my facebook account i try all block all the APP. but when i back to my facebook account the Social Extras still there.. and i used also a mac...
1. Go to your Facebook privacy settings or click here: https://www.facebook.com/#!/settings/?tab=privacy
2. At the bottom of the Privacy Settings page there should be a small section called "Apps and Websites". Click on the link that says Edit Your Settings.
3. Choose "turn off all platform apps" or, if you want to remove apps one by one, click on Edit Settings in the Apps You Use section.
4. Click the "x" next to any Apps that you don't want anymore. This is how you remove Facebook Apps individually.
I hope this solves your problem! Good luck!
Aug 01, 2011 | Facebook Social Network
Cancellazione areyouinterested
On your home page of facebook
-Click on Account
-Click on Privacy Settings
-Scroll down the page
-On the Bottom of the Privacy Settings page there should be a Label called Apps and Websites
-Click on the Edit your Settings link below Apps and Websites
-On the label Apps you Use click on the Edit Settings link
-From here you can delete or manage the options of any app that you would like, including the areyouinterested app
Apr 25, 2011 | SNAP Interactive Are YOU Interested
How to remove facemood from facebook
-Click on Account
-From here you can delete or manage the options of any app that you would like, including the facemood app
Apr 01, 2011 | Facebook Apps
How do i unsubscribe to are you interested
-Click on Account
Feb 02, 2011 | Facebook Apps
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
