Question about Viper Vehicle Parts & Accessories
Need to disarm the alarm because the remote is not
Need to disarm my car alarm because the remote is not working and I can't find the valet to disarm it that way. I bought the car used few years ago and I wasn't even aware that there's such thing.
The type of alarm is a viper alarm esp 100
I have an 02 WRX my alarm keepes going off and i cant start my car and it keeps honking and honkin this viper system cam with the car n there is no button to press my blue button is flashing n my car is honking loud ! help! RPN 473V
Posted on Oct 10, 2009
My security system won't disarm on my 1999 chevy blazer
Is this an aftermarket alarm? If so, first locate the valet switch. It should be a black push button. Next, turn the ignition on, press and release the valet switch. This should disarm you aftermarket alarm. This is the most common manual disarm procedure for Directed (avital, python, Automate, Viper) and Audiovox (prestige, pursuit, code).
If this is the factory alarm and, you don't have the remote. Unlock the vehicle using your key in the driver's door.
Aug 16, 2012 | Vehicle Parts & Accessories
Viper alarm(car) when replace batt(car)alarm goes off like crazy
should be able to close everything on car and just hit the unlock button should disarm if not you may have to hold the valet switch to reet
May 10, 2012 | Nissan Vehicle Parts & Accessories
What is the valet button located inside of glove compartment used for
It is used for programing the alarm, it is used to disarm the alarm without the remote, [in case remote is damaged] and it is used to put alarm system into valet mode, [service mode] valet mode is only really needed if the alarm has been programed for passive arming, [alarm arms itself].
Your main use for the valet switch, [if programed for active arming instead of passive arming] is to have a way to disarm the alarm if the remote does not work.
Apr 22, 2012 | 1997 Cadillac DeVille
How to disable or reset a Prestige car alarm. Purchased a used car with an after market Prestige alarm installed. Alarm somehow tripped and shut off the ability to start the car. I can't find a valet...
The valet switch,on the newer Prestige alarms, is a push button LED or, it's incorporated into the antenna. In both cases, turn the key to the on position, then press and release the valet switch. The alarm will respond with two chirps confirming that it is disarmed. You may now start the vehicle. After you successfully disarmed the alarm, turn the key to on position, press and hold the valet switch for approximately 5 seconds, the LED will come on solid. Turn the key off.The alarm is now in valet. You can take it out of valet in the same manner.
Oct 28, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
I have a viper alarm on my car that wont shut off nor i cant start the car..and i have tried the button under my dash, how Can i shut it off??
was it a professional or shade tree install? the following is off vipers website:
disarming without a remote control
This feature allows you to disarm the security system without the
Remote Control should it be lost, damaged, or disabled. In order to
disarm the system without a remote remote control, you must have
the vehicle’s ignition key and know where the Valet button is
located. Be sure to check with the installer for the location and the
number of presses of the Valet button required to disarm the system.
To disarm the security system,
turn the ignition to the ON position.
Press the Valet button the
preset number of times (one to
five times) within 15 seconds. After five seconds the system will
disarm. If the system does not disarm, you may have waited too long;
turn the ignition off and on and try again.
if that doesn't work try this other
valet mode
You can prevent your security system from automatically arming
and triggering by using Valet Mode. This is very useful when
washing the vehicle or having it serviced. In Valet Mode, the
security system will not arm, even with the Remote Control, but
all convenience functions (door locks, trunk release, etc.) will
continue to work normally.
To enter or exit Valet Mode:
1. Turn the ignition on.
2. Turn the ignition off.
3. Press and release the Valet
button within 10 seconds.
The status LED will light solidly if you are entering Valet Mode,
and it will go out if you are exiting Valet Mode.
May 08, 2010 | 1994 Honda Civic
How do I disarm a audiovox prestige car alarm?
Locate the valet/override switch (button), (if you can't locate it, try tracing the wires under the dash from the main unit, usually a black and gray or black and red set of wires). Turn key to "RUN" position then press the button, the alarm's LED should light up solid at this time indicating valet mode as been set.
Jun 14, 2009 | APS20B Prestige Keyless Remote Alarm
I cant disarm my alarm
Get inside the car, turn the key to the on position, the alarm is going to sound so do not panic when the alarm sounds press the valet button one time and the alarm should stop. To place the alarm in valet mode cycle the key with the door open on then off then press the valet button one time and the alarm should go into valet mode meaning the alarm light will be on steady.
Feb 03, 2009 | Viper Security and Remote Start System...
Need to turn the valet switch off On 1999 Nissan Maxima
Look for alarm Brain box and look for wires coming out black and red going to valet switch. to turn valet on turn ignition in ON position and press-switch or flip depending on the type of switch. If it a basic alarm just disconnect the main wiring harness to alarm box- unplug and the car should start. Good luck and thanks for using FIX YA
Jan 26, 2009 | 1994 Nissan Maxima
Uniden vs1100xr car alarm will not arm or disarm,have found valet mode button which sets & resets ok but remote just flashes led no chirps or lights flashing
I had the same problem with my vs1100xr. The remotes for these (and other) unidens have a rolling code. Seems to me that either the remote runs out of new codes and cycles back to the beginning, or the alarm base unit somehow loses track of the codes. Either way, the alarm base unit stops accepting the codes of your remote, and so needs to be purged of its code tracking memory - reset, if you like. This is essentially the procedure for training the alarm base unit to recognise new remote (and forgetting old remotes).
This procedure is:-
1) Disarm alarm, or if in valet mode, take it out of valet mode (push valet button 3 times)
2) Turn the ignition on and off 2 times within 15 seconds.
3) Put the alarm into valet mode (push valet button 3 times) within 15 seconds of completing step 2. Alarm should beep, and remote training has started.
4) Within 15 seconds of completing step 3, push the button (#1) of the first remote you wish to use for the alarm. Alarm should beep, indicating acceptance of remote. Repeat for other remotes you wish to use - up to 4 in total. (Once the first remote has been accepted, you have all the time in the world to make the alarm learn other remotes)
5) Turn ignition on and off to end remote learning mode. Alarm should beep 2 times. New remotes have now been learned and previous remotes forgotten.
Some of these details may vary from country to country - who knows. If this doesn't work, I suggest that you contact Uniden in your country to obtain the procedure. Took me a few tries to get the timing right, what with the valet button hard to get at and having only 15 seconds between steps.
Sep 28, 2008 | Car Audio & Video
Car remote alarm system
THE VALET SWITCH SOULD BE IN THE DRIVERS KICK PANEL OR AROUND THE LOWER SIDE OF THE STEERING WHEEL
Apr 16, 2008 | Car Audio & Video
Vehicle Parts & Accessories Logo
1,796 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
