Question about GPS
How do I remove a vantage point ptw 13 from the wall?
PROBLEM WITH YOUR TEAM RE
You need to send this information to TRACPHONE not here! Check the TRACPHONE website or call them. You won't get any help here. This is not a TRACPHONE website.
Mar 01, 2015 | Computers & Internet
My warn vantage 3000 will not spool in. solenoid clicks but motor does not turn. winch operates on out. use for snowplow, only a month old
If motor runs in one direction motor is not burned out.
Solenoid clicks, solenoid is ok.
Most likely points on solenoid on one side. If you can get to it, then look at the points.
To check , reverse battery terminals then click. the reverse should work and the other not. This will prove the points are bad on one side. .
In that case, you have to take it apart put in new points or get new switch.
Feb 15, 2015 | Vantage 3000 Winch-ATV
I have a 24 foot long wall ,13 feet of which is straight but i have to put a 30 degree bend on the last 11 feet.can you tell me the method to get the measurements.
a douple of ways, 1. if you know were the final position were you want the wall to finish,put a stake at the 13 ft mark and another were the 11ft finishes then use a string line..or cut a 30 degree angle on a seraight piece of wood,hold that against the wall with the point of angle at end of wall and once again use stakes and string to mark it out
Aug 18, 2011 | Sonin InchMate Pro Calculator
Why is my gps not connecting to my pc? It's my first gps Triton 500, and I just loaded VantagePoint. Then,following the installation directions, I turn the gps on and click on Connect to PC. It just...
Vantage Point and your computer are expecting to see a internal files the sends the ID of the unit. This file must be missing. The unit needs to be reflashed.
Dec 26, 2010 | Magellan Triton 500 Handheld GPS Receiver
I cannot connect my magellan triton 300 to my computer, it always say "usb device not recognize
It sounds like you do not have the drivers install for your Triton, to install the drivers you will need to install the Vantage Point software that can with your unit or you can download the newest version of Vantage Point from the following link; http://www.magellangps.com/products/map.asp?tab=0&PRODID=1903
I hope this helps!
Nov 06, 2009 | Magellan Triton 300 Handheld GPS Receiver
Triton 400 will not load maps.
OK .. you could have many possible causes. The most likely is that the magellan drivers are not installed on your computer. If you installed Vantage Point you will find them under the c:\magellan drivers folder.
Now without Vantage Point being on just connect the GPS to the computer and turn it on. Then open up the device manager on your computer and you will see a PORT COM(number). Click on the properties and see if the device driver is enabled and working.
If it is not.. then uninstall the present driver and reinstall from your computer by pointing to the c:\magellan drivers folder.
JG
Sep 21, 2009 | Magellan Triton 400 Handheld GPS Receiver
Unable to create DirectX device. Vantage Point will be closed.
Answer .. remove NET FRAME and reinstall the VP. XP with SP3 has exhibited this problem.
Aug 01, 2009 | Magellan Triton 400 Handheld GPS Receiver
GPS Logo
32 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
