Question about Saws
Item # 98199 10 sliding compound miter saw. need a set of brushes for it
2 Suggested Answers
  • 288 Answers
SOURCE: Need to calibrate my dw708 sliding compound miter
i use a framing square off of the back fence with the blade down. when it is square, i check the other side of the fence and loosen the screws on the plate with the degree increments and set it to zero
Posted on Dec 23, 2009
Kobalt SM2505LW 10 sliding compound miter saw makes grinding noise and slow saw stop
a bearing ,brushes or brake broke more likely the brake mechanism if blade coasts
Jul 07, 2016 | Saws
Hitachi c12rsh brake
There are a few things that can cause this:
1) Check the brushes - make sure they are not severely worn and make sure they travel freely down the brush tube & contact the armature well.
2) If the brushes are OK the problem is most likely the switch. Tools with a brake have a 2 pole switch - one set will be normally open and one set will be normally closed (Most switches have a diagram printed on them) Disconnect the leads (keeping track of where you removed them) and using a continuity tester check the switch - you should get a reading between the normally closed contacts and lose it when you pull the trigger. Most likely you will find you are not getting a reading on the normally closed side and that would be your culprit. Hitachi C12RSH 12 Sliding Dual Compound Miter Saw Parts
Mar 16, 2015 | Hitachi C12RSH 12" Sliding Compound Miter...
Braking on miter saw not working
Try fitting a new set of brushes first otherwise it could be that it needs a new field coil.
Dec 27, 2013 | Hitachi C10FSH 10" Dual Bevel Slide...
Dewalt 12 inch compound sliding miter saw
This saw has locking indexing to set bevels for 52 degree crown molding the other common crown angle is 45 degrees, the bevel setting needs to be other than where the locking indexs are for the 52 degree crown. Problem is that the bevel lock does not securely hold at the bevel angle required. Is their an adjustment to get this lock to hold tighter.
Jan 04, 2012 | Dewalt 12" Beveling Sliding Compound Miter...
How do you change the brushes
You have two, 1/2 inch flat head screw things on the right side of the motor, pull them out, the carbon should be at least 1/4 inch long, min, brushes can be bought at the hardware store. The electric brakes on those saws eat them brushes up. Check it out.
Jul 12, 2010 | Dewalt DW712 Factory Reconditioned Heavy...
I have a Hitachi C8FB2 compound miter saw that the electrical break has stopped working on. The bushings are still good but I see and hear a electrical arc were the bushings touch the shaft. What can I do...
there is always going to be some sparking between the BRUSHES and the commutator. if it is excessive and loud or is really heating up the housing, there could be a crack in one of the brushes, the brush might be chipped or unevenly worn, or the brush holder itself may be burned cracked, or otherwise need to be replaced. they may LOOK okay but need to be pulled out to really know for sure sometimes. there is a small set screw in the housing that holds the brushholder in place.
while this could be the problem with the electric brake, it is more likely that there is a wiring connection loose, broken or burned inside the motor housing. it could be the switch but i dont believe the brake circuit runs through the switch on this model.
Dec 13, 2009 | Hitachi C8FSHE 8-1/2-Inch Sliding Compound...
My saw sparks more than normal at the brushes. I need help solving this problem
I would get an airhose and blow the motor clean of any sawdust first and then i would check the brushes and brush springs. just a few ideas. Jeepfxr
Nov 30, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
Need to calibrate my dw708 sliding compound miter saw. How to adjust the slides for a true cut. The blade is square.
Nov 21, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
Saws Logo
105 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
