Question about Sharp Televison & Video
I have a Sharp 60" TV with no sound or picture; but on Netflix it's ok; which circuit board do I need to replace?
SOURCE: Purchasing an internal circuit board part for a sharp LC 20S1E LCD TV
send me the model and serial number and i will be able to advise you
Lou Margo
Allied Electronics
loumargo@verizon.net
Posted on Dec 24, 2007
  • 298 Answers
SOURCE: Replacement circuit board for my Sharp 36r-S50
Yes, you can find replacement circuit board and any other accessories at Andrews Electronics.com.
  1. Go to the Order Parts menu
  2. Type in your model number with NO DASHES.
  3. Locate the part you are looking for in the listing that shows up. If your part is not listed, email quotes@andrewselectronics.com to request the part you are looking for.
Or I will be happy to assist you if you reply here as well.
Posted on Mar 13, 2008
dsacco86
  • 1077 Answers
SOURCE: Sharp 42' LC-62C42U main circuit board needs replacement
I would recommend Shopjimmy.com.
Parts are at reasonable prices. Compare with the prices at Partstore.com and you'll see what I mean.
Posted on Aug 07, 2009
  • 6 Answers
SOURCE: HPT5054 50 in. HDTV-Ready Plasma Television: Samsung HPT5054X/XAA - No picture, Sound OK, Have ...
It's not the x main. 90% of the time it's a y buffer that goes out. It's usually the top buffer. 3/4 of the time the buffer takes out the y main board too. You cannot just replace the y-main or buffer because it will just burn out the other within seconds. Also about 1/4 of the time it'll take out the top transformer on the power supply too. The solution? First disconnect the power to the y main board. turn on the television and check the voltages coming off of it. Careful it's high voltage 208V! Remember it's DC too. Then disconnect the buffers from the y main board. You can try powering the y-main up to see if the little LED lights up. This does not indicate it's working though but it'll tell you if it is possible to fix. The fixes for these boards is only for electronics guys. It usually involves replacing 1-3 capacitors and 1-4 FET's. Since a bad buffer can take out a good y main in seconds it's usually recommended that one replace all 3 boards at the same time. It's a $250 fix. How do I know all this? I've now repaired 5 of these televisions. I owned one and spent close to 600 repairing it. I bought misc parts and broken sets online for months before I had 2 different repair guys walk me through the process of repairing them. I had so much cash tied up in parts that I bought 3 more dead sets and repaired them to justify all my spending. I've never had an x board fail. I've had EVERY top buffer fail. I've had all but 1 y-mains fail. and 1 lower buffer fail. I've also had the y buffer fry it's top chip, blow a capacitor and FET on the y-main, and fry the top transformer on the power supply before my eyes. It only took 5 seconds. Replacement of the 3 y boards will almost always fix the sound but no picture problem. Hope this helps!
Posted on May 26, 2010
mikedenney
  • 150 Answers
SOURCE: I just got this Vizio
Before you go to any more trouble troubleshooting potential hardware and/or connection issues, look at this page of reviews on Dell's site, taking special care to read 'Review 8' by an owner named 'Milwsport'.
Posted on Feb 27, 2011
Testimonial: "thanks for the quick informative response!"
My 60 inches.TV have audio but no pictures
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 31, 2016 | Sharp Aquos Televison & Video
My sharp aquos LC-60E79U has no picture. Perhaps I have a backlight problem?
. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Oct 13, 2016 | SHARP ELECTRONICS DE AQUOS LC-60E79U 60"...
Sharp Aquos LC60LE632U 60" TV 1080p. LCD HDTV. Great picture. Except, there is one green line, running vertical down the far right of the screen. I'm suspecting that it may be the TCON Board.
I had a similar problem with my Sharp Aquos 60" LED and it was the T-Con Board. Simple to replace and can be purchased in the neighborhood of 40.00. If you have sound and a picture, T-Con Board replacement should be your fix. Great videos on youtube if you need assistance. I would highly recommend that you watch the videos prior to proceeding. I am NOT a TV repairman, just a do-it-your-selfer....
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Mar 31, 2016 | Sharp Televison & Video
Sharp TV (LC-40LE550U) without picture, but sound is fine. Very weak image with flash light. TV can be turned on with remote with green indicator.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 29, 2016 | Sharp LC-40LE550U 40" LED TV 1920x1080, 60...
Sharp 60uq17u no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Feb 15, 2016 | Sharp Q Series LC-60UQ17U 60" LED TV...
How do I replace a broken circuit board on a Sharp LC-60E78UN TV?
You can either remove the power supply and check and replace caps and most likely the transformer (pop sound). Or a replacement can be found on eBay, amazon, etc... One model TV can have numerous diff power supply models from revisions and improvements. If you replace the board make sure you look match serial numbers on board to the new board. The back of the TV will come off very easy. Lay TV face down on a flat surface(making sure nothing is touching the LCD) remove screws. (Make sure cable coax slides free, some have a retainer but to remove) once the back is off the layout should be so simple, you should have no problem identifying parts.
Sep 12, 2015 | Sharp AQUOS LC-60E78UN 60" LCD TV...
Can't get sound on my 60" Sharp Aquos TV. Picture is great, but no sound using TV control or cable box control
Check its speaker/s first. If found good, check and replace damaged component/s at its audio output section circuit, or, replace the sound board as card basis. Gopakumar Gopalan Google
Feb 27, 2014 | Sharp Aquos Televison & Video
Picture and sound go out on my 60" sharp aquos tv
Check its sound settings first. If it is OK, check its speaker. If you wish to get more details about these type of faults, check this link. Pull up older posts there.
Mar 20, 2013 | Sharp Televison & Video
Half a screen on my sharp aqous
There's a circuit board under a metal cover that needs to be replaced. This board conrtols the picture.
Aug 28, 2012 | Sharp 60" Aquos LED Smart TV - LC60LE640U
My Sharp TV will only hear sound. No picture or images even from the tv menu setup option. Model# LC-19SB25U. About 1.5 yrs old. Converter box ok.
In most cases, you can reset the TV by leaving it unplugged for 30mins.
If this doesn't work, I believe the circuit board that supplies power to the screen maybe bad. They call this board a backlight inverter board. It would most likely cost more to repair than replace the TV .
May 27, 2009 | iLO 3200 32 in. LCD Television
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
