Question about Dryers
A week ago we bought a Kenmore Model #88042 dryer. Why does not the book that comes with the dryer say that condensation is very prominent, and the lint does not all go into the lint filer, but all over the inside, especially the door. When the door is opened the lint comes flying out. What is the problem?
  • 5,911 Answers
If you experience heavy condensation inside the dryer, and have lint accumulating inside the drum, you have a clog somewhere in your exhaust ducting. Since this is a recently purchased (new?) dryer, I'm assuming the clog is EXTERNAL to the dryer.
A quick test that you can try to determine where the problem may be is to remove the exhaust ducting from the back of the dryer and attempt to dry a normal load of wash. If the air flow from the back of the dryer is forceful and warm (about 140 degrees F), and the clothes dry normally, the problem isn't the dryer. The problem is in the ducting from the point where it leaves the dryer to where it exits your home. If this is the case, you will need to inspect the entire length of the ventilation to ensure there are no kinks, clogs, sags, or significant bends that can cause choke points for lint to accumulate. If left in this condition, the dryer will eventually overheat to the point of failure.
If the air is weak and hardly moving at all, you will need to inspect your air blower assembly inside the dryer to ensure the fan is not obstructed and the ducting is not clogged.
If you have any questions, please let me know. I hope this helps you.
Posted on Jul 20, 2009
    President:
  • 1,776 Answers
Check out how you have the dryer vented to the outside. When venting the dryer to the outside, you should use a rigid metal vent pipe, since this is the safest and most efficient way to vent the dryer, Back pressure is the enemy when venting the dryer. Check to make sure that your vent hose is not collapsed or kinked and make sure that you go outside and make sure that the vent hood flapper on the outside of the house is not stuck closed. I think it is a venting problem because of the condensation that you mentioned. The air inside the drum is saturated with water vapor from the warm wet clothes, and the way that water vapor is supposed to be gotten rid of is through the dryer vent. So please check these things out and I sure hope it helped you. Good luck and good drying.
When push start button it not come on only beeps kenmore model 88042
Most dryers are belt driven to rotate the tumbler. Some models have a switch that forbids the motor to start if belt has snapped. Check to see if your belt is trashed and needs replaced.
Dec 13, 2017 | Kenmore Dryers
Kenmore dryer 88042 will not turn
broken belt, bad bearing
Jan 13, 2015 | Kenmore Dryers
Kenmore 88042 dryer beeps non stop
What is the complete model number of your unit?
Dec 01, 2012 | Dryers
How do you replace the drive belt in a kenmore dryer model 88042
Pull the fron off. Remove tub, should have a spring loaded idler pulley next to the motor. Make sure that it is not broke and spins freely. Also check tub support rolers on each side. They shoule spin freely. If ok, put belt around tub, install tu. Put belt around spring loaded pulley. May need a hand holding tub while you install pulley. Put front on. Make sure the fron of cover fits inside the tub seal. Good luck. email me with issues, bobby.crochet@lyondellbasell,com.
May 14, 2011 | Kenmore Dryers
I have model 417 88042 700 Kenmore Electric Dryer. When trying to start a drying cycle it goes automatically to COOL DOWN mode, every time...
The front electric panel is out. I have the same problem. The part costs around $161.00 and about $100 for labor to fix it. Sorry for the bad news.
Mar 05, 2010 | Kenmore Dryers
New Condenser Dryer creating sauna in utilty room
Howdy: All dryers need a escape vent do to heat. Please read your manual and see what needs to be done. Good luck - Doug
Dec 09, 2009 | Dryers
How to get more volume on dryer buzzer
How can I change the tally.erp9 words font.It's automatic change i am in trouble please help me
Aug 19, 2009 | Kenmore Dryers
3 beep-tones
I am having this same problem, and it seems quite intermittant. I have finally narrowed it down to an electrical issue, somewhere on the control circuit board (which I have sitting in front of me right now.) I'm going to see if I can buy a new one, and for how much, before calling out the repairman.
Mar 16, 2009 | Frigidaire FEQ332E Electric Dryer
Dryers Logo
266 people viewed this question
Top Dryers Experts
