Giga works s750 5 out of 7 speakers no longer work. Trouble shoted so speaker and wires are ok. Anything in where plug in. Any other suggestions
techman
  • 3130 Answers
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Posted on Jun 04, 2006
Open SKy
  • 620 Answers
SOURCE: My iPod stopped playing through speakers- but only at work...
Esmurfette
First things First!
1) check on other speakers to see if your iPod work fine
2) check connector for loosing electric connectivity.
3) check with your headphones to see if your iPod play music well.
4) Check, power on the computer spk. you got. or the input that is working right.
Good Luck
Posted on Feb 01, 2008
japacheco83
  • 15 Answers
SOURCE: Phones ear speaker stopped working?
I guess this is a common problem huh. No worries!
First: Click on your music button and play a song as you would normally do on your phone (make sure your speaker is on during this point).
Second: Click on the speaker button so you can listen to your music through your ear piece (as your music is still playing). If you don't hear your music through your ear piece wait until you hear it. It shouldn't take more than a minute. (Your music should be playing throughout this whole process)
Follow these steps every time you come across this problem.
If this solution resolved your problem, please leave a comment and a good rate. Thank you!
Posted on Mar 15, 2008
  • 319 Answers
SOURCE: both left and right speakers play audio for right speaker
I think you mean the left channel is out but when you use test tone, the sound comes from left and right channels through the right channel speaker. If this is case, the switching IC is malfuncting. Unit needs service
Posted on May 01, 2008
  • 1138 Answers
SOURCE: peavey minx 110 no sound from main speaker but
Inside the headphone jack is a built in switching mechanism. It is there to cut off the sound to the speaker when you are using headphones to practice quietly. For some reason or another it seems as if this is no longer working correctly. One of the causes of this can be bad solder joints on the circuit board where this jack is located. Another cause is a failure of the jack itself. If you are capable, Take the circuit board out and have a look. Hope this helps.
Posted on Oct 27, 2009
The speakers no longer work. They were working 2
selectbanker, As a test only try this. Remove green plug from rear of pc. Find old am/fm stereo transistor radio or even a portable cd player and connect the green plug to your "new" audio source. Can you hear anything coming out of the monitor's speakers? Also try a set of stereo headphones in the green audio "out" jack to see if sound is coming out of the pc. Narrow down where loss of signal occurs first. 12fixlouie
Apr 07, 2010 | HP Compaq WF1907 Monitor
I have older 15
If the speakers measure zero ohms, then the coil is shot. A speaker will not work if it has zero ohms. Replace the speaker. ALL speakers should read 4ohm, 8ohm or above. Zero means the coil wire is shoted. That there is no continuity.
Mar 31, 2010 | Orion Xtreme XTR15 Car Speaker
There is no headphone plugged in the tv speakers wont work
Hello
I had the same problem with my computer, where there was no sound because it showed that there was earphones plugged in.
The problem was the the earphone unit on my front USB pannel was a bit worn out, so it shoted out. I just took it to a repair shop and an hour later all was fixed up perfectly for very cheap.You should maybe try it. Please rate if this worked for you.
Best regards
Sep 26, 2009 | Bose Cinemate Digital Home Theater System...
No sound from speakers
Believe it or not, not all speaker plugs, even if they are of the same size are NOT made the same.Some times the "male" PLUG pushes into the "female" socket in such a way that it makes NO connection or does not make the right connection causing the headphones not to work.
TEST: play music that u can hear through the internal laptop speakers, and while the music is playing, plug in the headphones.
The internal speakers SHOULD cut out, and under normal conditions the music should pass through the headphones.
If the speakers cut out and the headphones don't work, your plug is damaged.
If the speakers DON'T cut out after u plug in the headphones, your plug is open.
Depending on the audio circuit, your audio amp. inside the laptop is going to get damaged.
It depends on the WAY the audio circuit was made.
May 15, 2008 | Audio Players & Recorders
Speaker errror message
The usual fix for "Speaker err" message is to simply unplug the sub-woofer power cord to reset the speaker diagram, plug it back in and remember to "match the negatives to negative, positives to positives" and never try to replace the original speakers with anything but equivilent speakers, adding on more speakers can cause the "Speaker err" message and an inoperative system.
Jan 21, 2008 | Audio Players & Recorders
Insignia NS-R2000 receiver
Check the impedance ratings of your speakers. Sherwood, the actual manufacturer of the NS-R2000 receiver, suggests that you use speakers with an eight ohm impedance if you have only one pair attached. If you have two pairs of speakers attached, the impedance rating of each pair should be sixteen ohms.
This is because Sherwood wired the receiver such that an additional pair of speakers is placed in a parallel circuit to the first set. When this is done, the impedance (resistance) of the load seen by the amplifier drops. As resistance drops, you get closer to a short circuit (no appreciable resistance).
Many other receivers wire the speakers in series, which causes the impedance to go up.
Personal experience seems to suggest that the amplifier is OK with a four ohm load on it. It does run warmer with a four ohm load, which is what you'd expect. It's when you have multiple sets of four ohm rated speakers that you will get into trouble, as this means the receiver only sees a two ohm load. This will cause overheating and shutdown.
At this point the power transistors in the amplifier may have been damaged. It may require repair. Fortunately, replacement parts are readily available (though not from Sherwood or Insignia). If it continues to shut down, stop using it. You could end up burning out your speakers.
Jan 09, 2008 | Yamaha RX-V2400 Receiver
Speaker problems
Hello there
Happy Holidays!
well, I suggest 2 things here, you can replace the speakers for a new pair, or see if connector or inside of the failing speakers, to see if the positive cable is connected, or the negative, from that you also check the wire connector end, if is in good condition too.
Dec 23, 2007 | Packard Bell Speaker Computer Speakers
Computer speakers
Are you sure your in the right slot with the speaker wire at the back of your PC it is the green imput. Make sure that the speakers are pluged in if there is a plug for them.
Sorry for sounding a bit basic I'm sure you have already checked these but sometimes people forget.
The volume may be turned off on the status bar at the bottom left of you destop. This is a small speaker double click it and check that the volume is not turned off.
there is no drivers ar anything for the actual speakers unless there is a problem with the sound card in your Dell.
Will you just check that all the wiring is correct and I will guide you through the trouble shooting to see is there anything wrong in the drivers if everthing is ok wiring wise.
Sean
Dec 11, 2007 | HP JBL Platinum Computer Speakers
My right control speaker doesn't work.
your speaker control cable is not working right try to push the cable in to the speaker a litte bit and then try.
May 13, 2007 | Harman Kardon HK595 Computer Speakers
Front two speakers not working at all
Hit the the speakers A/B/Off button on the receiver. If you plugged the front channels speaker wire next to the center channel on the back of the receiver make sure its showing B. If you plugged them in the banana plug part, make sure its showing A.
Apr 12, 2007 | Audio Players & Recorders
41 people viewed this question
 Grubhead
Grubhead
