Question about Coffee Makers & Espresso Machines
Where to put new 4GB DDR3L for my n7010?
Took back off has 2 slots both full, so which gets changed top or bottom one?
4 Suggested Answers
SYSTEM ONE
  • 85 Answers
SOURCE: I put two 2GB RAM
ok i checked on your model and it says 2gb RAM max and so it is probably seeing both chips but only seeing 1gb each since that is what the slot is made for..
But to be totally sure you might wqant to check the bios and see what it says since some bios will sometimes give more details as to how many chips are installed.
or take out one chip and turn the computer back on and see if it shows 1gb or 2gb if it shows 1gb with one 2gb chip then you will know that the slot wont read more than 1gb.
Posted on Dec 04, 2008
Suzman
  • 642 Answers
SOURCE: WE DRAINED 2 1/2 LTRS OF OIL OUT DURING AN OIL
Let the vehicle idle for a couple minutes and everything should return to normal. The oil in the passageways, oil filter and oil cooler(if fitted) can take up to 1.5 litres depending on the engine. Some of it may have drained out. When starting up dont rev the engine. just let it idle. Once shut down leave it be for another couple minutes to allow oil in the head to drain to the sump before checking. The level should be between the 2 marks on the dipstick whether the engine is hot or cold.
2 litres does however seem a tad on the low side for a refill.
Posted on Nov 01, 2010
howard_compu
  • 211 Answers
SOURCE: i have an acer aspire
The machine came with Up to 512 MB of DDR2 533 MHz memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support), each 1 GB. If you have already or someone has increased the memory, you might have to remove a 512 chip to use a 1 GB chip.
Posted on Sep 08, 2011
Can I use Transcend 4GB DDR3 1600 RAM instead of 4GB DDR3L 1333 RAM in BiostarJ1900NH2 mother board
No, Biostar advertises that you should use low voltage memory on this board. My experience that when 1.5 volt memory is installed in a 1.35 volt system, it is not reliable. (Intermittent Crashes.)
Dec 13, 2015 | Transcend Computers & Internet
Can I use Transcend 4GB DDR3 1600 RAM instead of 4GB DDR3L 1333 RAM in biostar j1900NH2 mother board
Dec 13, 2015 | Biostar Computers & Internet
How I can use transcend 4GB ddr3 1600 RAM instead of 4gb ddr3L 1333 in biostar j1900NH2 mother board
You would have to increase the memory voltage, this is only possible on full blown gaming motherboards designed for overclocking the memory.
A j1900NH2 supports S states, but it does not support memory overclocking.
How do I add memory to my acer travelmate P256M?
You should check Internal memory (REM) installed, Internal memory type: probably DDR3L-SDRAM, Maximum internal memory: 16 GB, and number of memory slots available and occupied
Problem is tha compatibility of memory and parity requiremens Means if you have 4 Gb wirh 2 x 2 Gb, not all boards let yoi nstall an 8 gb Memory with an existing 2 Gb memory
The other issue if you have one 4 Gb DDR3L-SDRAM does your board accespt other specificacion of 4 Gb memory or must be the same.
You should check this info with someone who has the technical specificacions of your MB
Feb 10, 2015 | Acer Computers & Internet
Hi, got new kodak camera and 4gb memory sd inside. i only took 8 pictures so far and said internal memory full. i dont understand why? i want to keep 8 pictures and it should be plenty as using 4gb and...
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
Jan 27, 2011 | Kodak Cameras
My Nikon D50 wont accept a SDHC 4GB card
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
You don't really need that big a card. If you want more space (going on holiday?) just carry a couple of spare 1GB cards, and change them when they get full, like people used to put in a new film.
Nov 28, 2010 | Cameras
NEED TO KNOW HOW OR WHERE TO ADD THE MEMORY CARDS IN MY DELL DIMENSION E521...HOW DO I OPEN THE TOWER
Hi There,
Should be very straight forward.
You can find full instructions here;
http://support.dell.com/support/edocs/systems/dimE521/en/SM_EN/index.htm
(this includes opening the cover!).
This model has 4 DDR2 slots and supports a maximum to 4Gb of RAM.
Regards,
MC
Aug 25, 2009 | Dell Dimension E521 PC Desktop
Replacing door on electric whirlpool dryer
On the bottom right and left of the dryer cabinet are 2 metal clips.
They are about 3 inches from the floor.
The door panel has corresponding slots in it for these clips to go into.
Put the clips in the door panel slot first, then align the door panel with the cabinet and close it shut. Replace 2 screws in the top right and left inside panel.
Feb 11, 2009 | Whirlpool LER4634J Electric Dryer
Changing a belt
Take off the bottom plate, look in the bottom to see if there are any screw, could be 2 of them, then from the bottom there is a slot on each side of the top cover, using a flat screwdriver, insert blade into the slot and pry up to release the locking tabs. Belt # is 38528040. Put the bell over the brush roll, put belt thru opening and put atound the motor shaft, put back together.
Jan 22, 2008 | Vacuums
Change Belt
Turn the vac. over, remove the bottom plate covering the brush roll, then on the bottom of the top cover, on each side there should be 2 slots when you can put a flat blade scredriver, pry up to release the tabs holding the cover on. The know will come off also when you do this, just put it back on when the put the cover back on. Put the belt on the brush roll and feed it thru the opening and stretch to put over the motor shaft. The top cover, push down to lock it.
Dec 23, 2007 | Vacuums
Coffee Makers & Espresso Machines Logo
24 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
