Question about Samsung Office Equipment & Supplies
Have a Samsung 65KS7500tv but cannot activate the multi room function, wondering if any one knows how to?
I have a red lock button showing in the corner and the machine will not do anything how do i sort this out
I'm wondering if you have activated the child safety lock by mistake? Here's the info from the manual:
If you want to activate or deactivate the Child Lock function, hold
down the Temp. and Rinse buttons at the same time for 3 seconds.
The "Child Lock " indicator will light up when this feature is activated.
When the Child Lock function is activated, only the
Power button works. The Child Lock function remains on even
after the power is turned on and off or after disconnecting and
reconnecting the power cord
I hope that sorts your problem out :-)
Nov 20, 2014 | Samsung Ecobubble WF80F5E5U4W White 600 mm...
How do i activate fake calls on my e1080
you don't have to activate fake calls you have to download the app and you can get it from umnet.com, getjar.com, there are two types of fake call apps, if you have a multi function phone then you can use the better one because it needs the app to be running at the time of call...rate my answer
Sep 25, 2011 | Samsung E200 Mobile Phone
I need instructions on how to pair my WEP200 to my new cell phone please.
1 Turn your bluetooth headset off. If it is on, press and hold multi-function button(for about 4 seconds) until the LED blinks twice. 2 Prepare your bluetooth enabled phone to be ready to go to search mode. 3 Turn your bluetooth headset on in pairing mode. (Press and hold the multi-function button for almost 9 seconds. The LED will be steadily LIT.) 4 Activate the Search option in your phone. You should see Samsung WEP200 in your phone's screen. Choose that and press OK 5 The phone will ask for a passkey. Press 0000. Then press OK. Give it a few seconds, your phone and bluetooth headset will be paired.
Mar 21, 2011 | Samsung WEP200 Headset
How do I activate the scanner on the SCX-4521F multi function printer?
Click this link http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=N0000191&model_name=SCX-4521F
Go to Scanning, then How to scan.
You have to configure the printer first to scan. Follow the steps and you should be all set
Feb 28, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I have a Samsung CLX-316N multi function colour laser printer. I am getting very poor print quality when trying to print photographs, using laser photo paper. The printed photos have vertical streaks of...
Dear This is the Quality issue.
can be solved by replacing black developer in imaging unit.(better solution)
Alternate is change the Imaging unit(costly solution).
Dec 06, 2010 | Samsung CLX 3160fn All-In-One Printer
I cannot connect the bluetooth headset to my iphone
Hello
Prepare your iphone to be ready to go to search mode.
You can see 1.Search 2. Wait for request. Don't press on Search yet. This needs to be done after the bluetooth headset is in pairing mode.
Activate the Search option in your phone. You should see Samsung WEP301 in your phone's screen. Choose that and press OK.
The phone will ask for a passkey. Press 0000. (That's four zeros.) Then press OK.
Enjoy the handsfree experience.
Nov 11, 2010 | Samsung WEP301 Bluetooth Headset
Multi Room Function on marantz SR-19
Hi..
Put a RCA (phono cable) splitter at the pre-out /main in.
That way you can go to both amps with the same signal
Jan 14, 2009 | Marantz SR-19 Receiver
Multi Room / Multi zone problems
As you may see from my posted response to a posting that correctly ID'd the solution, the answer to your problem is found on p. 47 of the manual (regarding how to adjust the multi volume levels as stated on p. 26).
Jun 20, 2008 | Denon AVR-3802 Receiver
Borther Fax FMC6550MC does not turn on or activate phone now
you might find that manual, through the Brother icon door here
better this case, than a functioning manual without a printer, no?
Mar 19, 2008 | Brother MFC 6550MC Laser Printer
AUX inputs
Turn the ignition key to on or accessory position, turn the stereo off, then hold the function key for a couple seconds, the stereo will turn on and you scroll through the menu with the left and right arrow buttons and change settings with the up and down buttons
Feb 25, 2007 | Pioneer DEH-P6800MP CD Player
24 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
