Question about Sharp Office Equipment & Supplies
How do I print A2 envelope using Sharp M2300N printer
  • 4402 Answers
SOURCE: printer will not print labels or envelopes????
you need word or Avery label software
then you select the type of labels you have in the options and print
Posted on Dec 13, 2007
  • 3 Answers
SOURCE: Printing envelopes
You will probably have to change your paper settings on the printer itself to proceed without an error. In the additional settings>Paper Size> change it from Ltr to Envelope.
Posted on Jan 09, 2008
SOURCE: HP 5610 Envelope Printing Problem
Had this same problem. Went to Microsoft Office site and downloaded Service Pack 3 for Word 2000 and Security update #KB934392 and the printer started printing on the correct side again.
Posted on Mar 10, 2008
  • 3422 Answers
Try this one.Make sure the HP paper size setting needs to be "plain paper," not "automatic.
Posted on Aug 17, 2008
SOURCE: Printer Error When Printing Envelopes
I had the same problem with my 7260 and I finally changed the paper type from automatic to plain paper. Go to either Properties or Preferences in your printer set up window. Somehow this turns off some sort of sensor. It might work for you, too. To the person who is using the Hallmark program, that is where I first encountered the problem, I then tried to print an envelope from Word and the same error message came up. I found this solution online from someone using a three in one printer/fax/copier so I tried it and it worked for me, too! I hope this helps......
Posted on Dec 05, 2008
Hi there, my name is Lisa and I'd be happy to help. I have checked the specifications for the Officejet 7210, and from what I can see, 9x4 envelope printing is not supported. Here are the 4 supported envelope sizes:
U.S. 10: 105 x 241 mm (4.125 x 9.5 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches)
I hope this explains what the 9x4 isn't working.
Feel fee to take a look at the specifications using the following link:
Printer Specifications for HP Officejet 7200 All in One Printer Series
I hope this helps.
I work on behalf of HP.
Jul 14, 2015 | HP Officejet 7210 All-In-One InkJet...
Sharp MX-3501N will not accept envelopes
here is a walkthrough for printing on envelopes. basically you have to set the machine for envelopes then set your print job for envelopes.
How To Print on Envelopes or Labels on Sharp Printer
Copier Collin Houston TX Copier and Imaging Expert
Jun 30, 2014 | Sharp MX-3501N All-In-One Printer
How to print on transparency film on sharp ms 311ON
Firstly, make sure that you have copier safe transparencies.
Then follow the instructions below, except choose transparency instead of envelopes/labels. and make sure you choose the correct type from the print driver as well. They must match for it to pull the paper in.
Dec 06, 2013 | Sharp "MX-3110N Color Copier, Printer,...
Sharp wont let me print 6 3/4 envelopes. how to do it?
The error code says tray is empty, but envelopes are in there...The options in size on the printer are COM-10, Monarch,DL, and C5, none of which work for the size of envelopes I am using. :(
Aug 16, 2012 | Sharp Office Equipment & Supplies
Print 4.374 x 5.75 sharp 2300
Envelopes must be run from the bypass tray at the side of the machine. touch the paper trays on the touch screen. Set the bypass to envelope and com10. when you go to print, make sure the paper type is set to envelope under printer preferances.
Aug 03, 2012 | Sharp MX-2300N Color Copier
How do I print envelopes in the printer Samsung SCX 4824fn? thanks
• Successful printing on envelopes depends upon the
quality of the envelopes. When selecting envelopes,
consider the following factors:
- Weight: The weight of the envelope paper should
not exceed 90 g/m2 or jamming may occur.
- Construction: Prior to printing, envelopes should
lie flat with less than 6 mm curl, and should not
contain air.
- Condition: Envelopes should not be wrinkled,
nicked, or otherwise damaged.
- Temperature: You should use envelopes that are
compatible with the heat and pressure of the
machine during operation.
• Use only well-constructed envelopes with sharp and
well creased folds.
• Do not use stamped envelopes.
• Do not use envelopes with clasps, snaps, windows,
coated lining, self-adhesive seals, or other synthetic
• Do not use damaged or poorly made envelopes.
• Be sure the seam at both ends of the envelope
extends all the way to the corner of the envelope.
Envelopes with a peel-off adhesive strip or with
more than one flap that folds over to seal must use
adhesives compatible with the machine's fusing
temperature for 0.1 second. Check your machine's
specification to view the fusing temperature, see
page 82. The extra flaps and strips might cause
wrinkling, creasing, or jams, and may even damage
the fuser.
• For the best print quality, position margins no closer
than 15 mm from the edges of the envelope.
• Avoid printing over the area where the envelope's
seams meet.
Place the side to be printed facing up.
Envelope Preprinted paper Transparency
Punched paper Card stock Letterhead paper
open the direct paper try on top of your A4 paper try by pushing it!
Apr 22, 2011 | Samsung SCX-4828FN All-In-One Laser...
I dont know how to print using the HP4 using small short envelops
1. Prepare your laser printer bypushing the "On" switch and allowing it time to warm up. 2. Determine which envelope youwill be using. Look on the box of envelopes for the if you are unsure.3. Open your word processingsoftware. The more powerful office applications may make your task simpler, buteven Windows Notepad will work for this job. 4. Select "Page Setup." This is usually found underthe "File" pull-down menu. 5. Find the of the envelope you are using under the paper option. The s are usually designated by both a code such as A2 orNo. 10 and the actual dimensions in either inches or millimeters. 6. Enter the information that you want to print on yourenvelope. Choose your font and letter . 7. Determine the correct way to load envelopes into your laserprinter. This can be found in the manual that came with your printer. Load theenvelope. 8. Open "Page Setup" and confirm that you have thecorrect envelope selected. Also check the paper orientation. If yourenvelope is loaded with the short side going in first, select"Portrait." Select "Landscape" if your envelope is loadedwith the top going in first. 9. Select "Print" from the "File" pull downmenu. Click "OK" to accept the options. Enjoy your professionallooking envelope.
Nov 20, 2010 | HP : HP4P Laserjet Printer
Envelopes keep getting stuck
Open Ms word >> click on tools >>click on letter and mailing >> click on envelop and labels >>click on feed >> click on envelop option >> can change the size from the drop down option.
This will resolve your issue.
Aug 17, 2009 | HP Photosmart 7850 InkJet Printer
How to print an envelop
nstructions Use the following steps to ensure that you are ready to print envelopes. Your printer can have either a single envelope or multiple envelopes loaded and ready for printing.
  • If you are printing a single envelope, you can use the single envelope slot and leave your paper in the lower (IN) tray. This allows you to print the envelope and then a letter.
  • If you are printing a stack of envelopes, use the lower (IN) tray for loading the stack of envelopes.
To Load a Single Envelope
  1. Do not remove the paper from the lower (IN) tray. Be sure the card guide is in the down position, before using the single envelope slot.
  2. Remove a single envelope from its packaging.
  3. Slide the envelope evenly into the single envelope slot. The single envelope slot is located on the right side of the upper (OUT) tray. The envelope should be loaded with the address side down (flap side up).
  4. Make sure the creased flap edge of the envelope aligns with the right side of the single envelope slot.
  5. Slide the envelope through the slot until it stops. Make sure the envelope is not bent and is straight in the envelope slot.
    NOTE: To minimize print skew, use envelopes with rectangular flaps rather than triangular flaps.
To Load Multiple Envelopes
  1. Slide the paper width adjuster to its leftmost position.
  2. Pull out the paper length adjuster and remove any paper from the IN tray.
  3. Remove up to 20 envelopes from their packing and tap the short edge of the envelopes on a flat surface to even the stack.
  4. Slide the envelopes evenly into the IN tray, address side down (flap side up).
  5. Slide the paper width adjuster to the right until it gently touches the left edge of the envelope stack.
  6. For size Invitation A2 and C6 Envelopes, press the inside of the paper length adjuster handle to release and lower it.
  7. For all sizes of envelopes, push the paper length adjuster in toward the envelopes until it stops. Make sure the envelopes are flat in the lower tray and not bent.
Set up the Printer Properties
  1. Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
  2. Select the Paper or Setup tab depending on the version of the printer driver software.
  3. In the Paper Options section, select the desired envelope size from the Paper Size drop-down box.
  4. Click OK.
Print Print the envelope from your chosen program. From most applications, just select the File menu, then choose Print. After Printing the Envelopes Reset the printer and the printer properties for the kind of printing you will be doing next.
  1. Remove any remaining envelopes from the lower (IN) tray.
  2. Slide the paper width adjuster to its leftmost position.
  3. Load the desired paper into the lower (IN) tray.
  4. On the computer, Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
  5. Select the Paper or Setup tab depending on the version of the printer driver software.
  6. In the Paper Options section, select the desired paper size from the Paper Size drop-down box.
  7. Click OK.
Jan 19, 2009 | HP LaserJet 1600 Printer
you sure you have the model correct???
as far as I know Sharp DM-3551 is multi-task machine but, it is not capable of printing envelops.
Oct 17, 2008 | Sharp DM-3551 All-In-One Printer
29 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
