I have a Trane XB80 model tde080A945M0 it starts to glow/ingnites then turns off, but it continues to run but blows cold air
  • Heating & Co... Master
  • 3,087 Answers
Clean the flame sensor , then check out the pressure switch.
Posted on Dec 16, 2016
Trane XB80, no heating, limit circuit open
Sometimes these can be reset by gently taping them on the floor. Can be caused by not changing your furnace filter.
May 18, 2014 | Trane American Standard Trane American...
Ac
You would need to find out if the compressor continues to run when the cold air stops.
Jul 17, 2013 | 2000 GMC Sierra
I have a trane xe 800 its blowing air but not cold air, i felt the copper/bronze tube running into the unit it is luke warm also no chill at all. where should i start checking to get my house cold again.
Hello, if the pipe with insulation is luke warm then either the unit is empty of refrigerant due to leak or the compressor is not running at all. Start by going tje the outdoor unitnand checking if the compressor is running, if it is then the unit has no refrigerant, if the compressor is not running then either a bad capaitor orbthe compressor itself might be bad.
Jul 20, 2011 | Heating & Cooling
Trane XR80 blows cold air. Inducer motor comes on, glow bar glows for few seconds than goes out and inducer motor shuts off. Immidiatly after the main blower comes on and blows cold air. Will blow until...
I know that it's easy to spend someone elses money but in my experience when you get one actig that erratic it's usually the control board. I would check all the wiring including thermostat. You never know you might get lucky. I hope this helps you. Thanks
Nov 29, 2010 | Heating & Cooling
I have a trane xb80 furnace and the red light flashes 5 times what is the problem?
On the back of the door panel or in the manual if you have one, the codes for the flashing lights should be there.5 flashes should be a code for one of the limit switches being tripped.I assume your furnace isn't running. I do not Know what 5 flashes is on a trane unit,but if you find the code chart,should be inside the door panel and replie I can help you. Doug
Nov 27, 2010 | Heating & Cooling
My trane XE80 will only blow cold air. The fan
It sounds like the problem is a tripped limit switch. Look in the burner compartment and on the blower assembly for a switch that looks like the one below. It will be about the same size round as a quarter. Press the red button on any of the switches you find, then re-try furnace.
Mar 23, 2010 | Heating & Cooling
Furnace blows cold air, ignitor won't glow.
ok this is going to sound funny but it seems as though the polarity is reversed going into your furnance. to correct this proiblem you first need to unplug the unit and where the cord goes into the furnance at that connection disconnect the two wires. Once theses are disconnected switch the wires .All you are doing is reversing the way the electricity flows into the circut board. I would wager that is the problem
Apr 13, 2009 | Heating & Cooling
Central heat/air unit for home blows cold air
sounds like your drain is stop up in wich is filling your air swich up with water the causes a miss fire the indoor motor will run untill you turn it off when this happens
Jan 13, 2009 | Omega Trane Furnace Draft Inducer Blower...
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
