Question about Belling Ovens
How can I clean the inside glass of my Belling Format oven?
    Master:
  • 502 Answers
I have used SOS pads to clean glass with tough stains on it.
Posted on Dec 14, 2016
How can I clean the inside of the glass on a Lamont 3400 oven door
Hello, Johnny -
The instructions I found for cleaning the glass inside an oven door are generic and not just for a Lamona brand oven. (You did mean "Lamona" and not "Lamont", didn't you?)
See the instructions here:
https://www.mom4real.com/how-to-clean-in-between-glass-on-your/
Read through the instructions, in full, first.
This is a link to other instructions in video format:
https://www.todayshomeowner.com/video/how-to-clean-inside-the-glass-on-an-oven-door/
Best wishes.
Mar 07, 2018 | Ovens
How do I get the glass off the door of my Belling Format oven, I want to clean it and can't get to it.
The glass window in the oven is not intended to be removed and cleaned. It is a sealed double pane unit.
Dec 14, 2016 | Belling Ovens
I wish to remove oven door from oven on a Belling BI60MFB to re glue fascia glass .Can't see clearly how to detach.
Having searched it looks like a pull down oven door. It is normally a case of locking the hinge. How to fix your oven door glass Oven Door Glue has a video which shows several common types of hinge, and how to remove the door.
Nov 07, 2016 | Belling Ovens
Replacement user manual for Belling Format 645 cr double oven electric cooker
http://www.manualsonline.com/mdownloads/ff2c5d47-49a9-4d8c-9232-8033f1e3e147.pdf
Apr 13, 2014 | Belling XOU482 Electric Double Oven
Belling format 630ss Fan oven heater dead. Do i replace from inside or at the back?
It is usually normal to be able to replace the element from inside the oven compartment, it should be located behind a removeable cover at the rear of the oven.
Dec 12, 2010 | Ovens
How do I change the oven element on a belling format 800 oven
1, If your Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
Jan 03, 2010 | Belling XOU492 Electric Double Oven
I was wondering can i buy glass for the oven door seperate?
Providing the oven is not more than 10 years old, then there,sholud be no prob obtaining a new door glass.
Go to: www.belling.co.uk
Then click on: www.4belling.co.uk/spares
Pleas leave a rating for my suggested solution.
Thanks.
Feb 17, 2009 | Belling Ovens
My belling oven door
get these instructions and look at door removal
http://rapidshare.com/files/369550394/BellingFormulaMultifunctionDoubleOven.pdf.html
if the glass has come away from the metal inside doror its was originally secured by a silicone sealant/adhesive. Try Toolstation 59104
Jan 29, 2009 | Belling XOU487 Electric Double Oven
Belling Format cooker
I found the following information useful, although it wasn't a belling cooker the controls appeared to be the same. Go down to the electronic timer section. http://www.prestigeappliances.com.au/owner's-manual.shtml
Oct 29, 2007 | Belling XOU482 Electric Double Oven
Ovens Logo
Top Belling Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
