Question about Binatone Lands Phones
Hi. We have just got binatone 3865 TAM. The answerphone cuts in but doesn't record the message. Then shows as no messages received. Any ideas please? Answerphone is turned on. Thanks, Sue
  • 7 Answers
SOURCE: NEED TO RECORD NEW ANSWERPHONE MESSAGE ON ONETEL OT150
To record a new OGM, on the Onetel OT150
Press "menu" on the base unit, then "up" once to record OGM 1 or twice to record OGM 2.
Press "OK" The existing OGM will begin to play. Whilst this is playing press and hold "MEMO"
Record your message, speaking close to the base unit. Press "stop" (square) when finished.
If you decided you don't like your message then, repeat the process above but when it tells you to record your own message press "stop" (Square) and the default will be reset.
Posted on Jan 13, 2009
richa33
  • 71 Answers
SOURCE: I need to programme my answerphone for binatone ma760
Generally, Answering manchine have serveral function. Like . Record anoucement, record message, playback message, delete message, answer machine on or off, answer machine remote access. Normally , the key laid out is simular too.
The following manual for your reference.
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
Posted on Jan 21, 2009
wayneard
  • 1901 Answers
SOURCE: Lost operating manual but need to change answerphone message
Here is a link for your manual:
http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf
Changing the message is on Page 27.
After opening this link, Save a copy to your computer for future use.
Thanks for using Fixya.
Posted on May 21, 2009
  • 945 Answers
SOURCE: How to listen to messages on the Binatone veva
At last your manual.
Read to the bottom of the page as there are a couple of things that will interest you.
http://www.howtomendit.com/answers.php?id=118475
Posted on Nov 16, 2009
MNfisherman
  • 11896 Answers
SOURCE: have lost manual for Binatone Veva 1210 twin phine
You can go to this site, and download your manual:
http://www.binatonetelecom.com/support/user-guides
Posted on Nov 17, 2009
Testimonial: "many thanks, job done!!"
Tam full?
What model Telephone Answering Machine (TAM)?
May 09, 2013 | Binatone Lands Phones
Cant get remote access working Binatone Symphony 2210 cordless ph
If you have set up the TAM settings correctly then it seems to be a fault with the machine. I've set up my TAM settings with new pin and I still can't remotely access the messages.
Make sure you are pressing the * key before you enter the default code (as far as I can recall).
Apr 05, 2010 | Lands Phones
Cannot set up voicemail on a Binatone 1210 DECT
Please follow the below mentioned process:
1)press menu
2)press up/down to tam
3)press ok
4)It will say play(press ok to play messages), or press up/down till delete all
5)press ok it will say confirm
6)press ok this will delete all messages. If you want to record your own message follow steps 1 to 3 then 4)up/down till ANS MODE press ok,
7)scroll up/down it will say, ANS ONLY or ANS + REC,
8)select ANS + REC, press ok,
9)it will now say PERSONALIS(your own personal message) or PREDIFINED(standard answerphone message), select PERSONALIS press ok 8)now it will say PLAY MSG scroll up/down it will also say RECORD MSG, press ok hold phone to your ear till you hear a beep, record your personal message then press ok, if you go back to step
10) you can hear your message.
In normal mode, Press and hold 0 key to turn on/off answerphone and your personal message will be on.
To delete messages press 2 key for 2 seconds as messages are played press 6 to delete, you can delete messages before or as they are playing without listening to whole message.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Sep 17, 2009 | Lands Phones
Binatone e920 quad phone with answer phone - can't record ogm.
Have had the same issue with a single handset. Finally located our manual:
1. Press and hold MEMO (FAST FORWARD) button until you hear a beep.
2. Record your memo, speaking from approx 15cm away.
3. As soon as you have finished speaking, press ON-OFF/STOP button to stop recording.
Hope this helps :)
Aug 13, 2009 | Lands Phones
How to set the answer machine for a 3410 Binatone speak easey com
Here's you manual:
http://www.binatoneonline.com/manual.aspx
Click icon under download....then save..remember where it saves it. Usually when the machine will not record messages there are only a few things that can be wrong....check the Telephone Answering Machine(TAM) section.
You might need to erase all the data and/or change to the correct mode for the phone to function properly. Obviously having the manual will help! :-)
Apr 30, 2009 | Lands Phones
Recording a greeting
You need to be in Tam fax mode firstly.
1, {#} {0} {0} {1}:= “TAM/FAX” (default)
2,
Press {RECORD} repeatedly to display “TAM GREETING”.
3,
Press {SET}. A long beep will sound.
Speak clearly about 20 cm ( 8 inches ) away from the microphone.
The display will show the remaining
recording time.
5 When finished recording, press {STOP}.
The unit will repeat your message.
To erase and start again
Tam/fax mode again.
2 Press {ERASE} repeatedly to display “TAM GREETING”.
3 Press {SET}.
To cancel erasing, press {STOP}.
4 Press {SET}.
should be good now.
Regards
Richard.
Apr 24, 2009 | Panasonic KX-FPG376 Plain Paper Thermal...
One tel magma 300 - can't change message on answerphone
1) Press the 'tape' symbol to access the answering machine mode.
2) Press 9 then 1 for 'answer and record'.
3) Whe you hear a 'beep' speak your message. Whilst recording the display shows REC OGM1 or REC OGM2
4) Press 5 to stop recording. Your message is played back to you
5) Press 'tape' symbol to exit.
To check your Out Going Message (OGM)
1) Press 'tape' symbol
2) Press 6 then 2 and the message is played back.
Jan 26, 2009 | GE 29888GE1 Digital Answering Machine
Jan 20, 2009 | Lands Phones
BINATONE CORDLESS PHONE MA 760
you have to press the answer machine button (3rd on the left with an R on it) then the display should say 'msg play' so press the down button scroll to OGM REC. record ya message after the tone then press ok when done. then scroll down the menus again (press the answer machine button (3rd on the left with an R on it) then the display should say 'msg play' so press the down button) scroll to TAM ON, press ok and thats the answering machine.
Mar 21, 2008 | Lands Phones
Lands Phones Logo
Top Binatone Lands Phones Experts
ray gallant
AJMAL KHAN
Are you a Binatone Lands Phone Expert? Answer questions, earn points and help others
