Question about GPS
I lost all of my map s wear - GPS
What does 'unfortunately com.google.android.gms has stopped' mean?
This is a known fault
  • Google Play Services process com.google.android.gms has ... www.youtube.com/watch?v=FtzSuzmckxw
    • BY TROUBLESHOOTERRORS
    • 19 SEC
    • 22K VIEWS
    2014-08-31 · Sometimes, i am seeing this Sorry message 'The application Google Play Services (process com.google.android.gms) has stopped unexpectedly...
  • How To Fix: 'Unfortunately The Android Process Media Has ... www.youtube.com/watch?v=arKBbSUt-_Q
    • BY THEFRESHGAMEPLAYS
    • 6 MIN
    • 547K VIEWS
    2012-12-08 · ... 'Unfortunately The Android Process Media Has Stopped' ... Unfortunately app stopped android ... Unfortunately google play store has stopped ...
  • android - Unfortunately google maps has stopped - Stack ... stackoverflow.com/.../25640697/unfortunately-google-maps-has-stopped ... Unfortunately DemoGoogleMapsV2 has stopped. ... Unfortunately google maps has stopped. ... And in place of com.google.android.gms.maps.MapFragment use com.google ...
  • How to fix the process com.google.process.gapps has ... www.androidpit.com > Overview Ive seen a few people ask how to fix "the process com.google.process.gapps has stopped ... google.process.gapps has stopped" on Google, ... android.gms has stopped ...
  • "Unfortunately, Android Wear has stopped." - Google ... productforums.google.com/d/topic/android-wear/fqDZFs24e0A 2015-04-09 · ... but the watch always pop "unfortunately android wear has stopped ... android "unfortunately,MYQR has stopped" on my ... Google "Android clear ...
  • Apr 16, 2016 | Tablets & eReaders
    Where is map sensor located on a 94 Cadillac DeVille 4.9 engine
    Under hood, center, rear engine area, above valve cover, mounted in bracket.
    From autozone.com:
    Manifold Air Pressure Sensor
    Fig. MAP sensor specifications-note how altitude and pressure affect the voltage readings
    REMOVAL & INSTALLATION
    1. Remove the intake manifold top cover.
    2. Disconnect the crankcase breather tube from the throttle body.
    3. Remove the MAP sensor from the intake manifold.
    4. Detach the MAP sensor electrical connector.
    5. Inspect the MAP sensor grommet for wear or damage and replace as needed.
    To install:
    1. Installation is the reversal of the removal procedure.
    Feb 14, 2016 | Cadillac Cars & Trucks
    How to change map sensor on 2003 Cadillac Seville sls
    consult the owners manual or shop manual for that vehicle
    Nov 15, 2014 | 2003 Cadillac Seville SLS
    Citreon c2 vts rac codereader is po106 p 01/01 map/barc0 ckt range/performance fiited new map sensor still wont start
    what does the scan tool show.??
    ? still P0106, and did you reset it?
    did you try to start car with MAP disconnected, some do start in limphome mode. rich a a pig but starts.
    did you have key off when you fiddled the MAP connector,
    or better pull the battery neg, lug first?
    lost power to the mAP, check the power pin.
    lost ground to sensor.
    lost vacuum to the sensor (clogged paths)
    Bad MAP sensor Water/dirt intrusion affecting MAP sensor connector Intermittent open in the reference, ground, or signal wire for the MAP sensor Intermittent short in the reference, ground, or signal wire for the MAP sensor Ground problem due to corrosion causing intermittent signal problem A break in the flexible air intake duct between the MAF and the intake manifold Bad PCM
    (do not assume the PCM is bad until you've exhausted all other possibilities)
    May 23, 2014 | 2005 Citroen C2
    Lost north america map on nuvi1490
    Please see this link. We can help with that:
    http://www.sharc.net/gps_lost_map.htm
    Also connect your unit to the PC and log into your Garmin account and re-downoad the map.
    Jul 12, 2013 | Garmin nuvi 1490T GPS Receiver
    Update download for tom tom xxl 540s is too big for unit, lost all maps
    Theres good news for you, you can get a SD card for your tomtom, and all you have to do is to install or download your maps on the SD card then fix it into your tomtom and you will be able to view your maps from there. For the lost maps, connect your tomtom to your computer, be sure to have your drivers software, then you select your tomtom form your computer, then you install all lost maps back on it by restoring all old maps. But for large downloads, download all new maps on a SD card. That should do the job.
    Hope this information came in handy.
    Dec 21, 2010 | Tomtom XXL 540S GPS Receiver
    Lost map
    you tom tom should have come with a serial number and an activation code.
    Contact TomTom directly and you should be able to download the map through TomTom home...
    Also the TomTom home app (if ever synced & registered will have an backup of ownership to the device))
    Also the device it came with....
    Feb 23, 2010 | Tomtom ONE 3rd Edition GPS
    Lost the predownloaded Map
    If you delete maps without backing them up, there's nothing you can do, but you can put maps back on by connecting to TomTom Home if they have been saved, otherwise you'll need to download and install new maps here
    Nov 19, 2008 | Tomtom ONE 3rd Edition GPS
    Lost my icn 520 map cd
    Contact (I believe its Garmin for that model). I think you will have to buy another copy of their software. If your maps are more than a year old, they are due for an update anyways.
    Jerry G.
    Jun 27, 2008 | Navman iCN 520 GPS Receiver
    Updated to 2008 maps, now I lost my local roads and town maps
    Turn on the Garmin. Look for the little wrench on the screen and select it. Now look for Map, select Map. Now look for Map Detail. Verify that it is set to "Normal" or Higher to get more map details.
    Dec 30, 2007 | Garmin StreetPilot c550 GPS Receiver
    GPS Logo
    27 people viewed this question
    Top GPS Experts
    Will Halftowaite
    Are you a GPS Expert? Answer questions, earn points and help others
