Question about Locks & Locksmithing
We have a Browning Gun Safe will not open, does not beep when entering codes or nothing. Put new batteries still did not help. Just had it open last week.
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
ekoo
SOURCE: need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
Posted on Apr 09, 2009
  • 80 Answers
SOURCE: Sentry Safe A3750 won't open new batteries
http://www.sentrysafe.com
call them
mj
Posted on Sep 07, 2009
SOURCE: factory code will not open model # DA3831 safe
i am a locksmith that has worked on several of these. The safe is manufactuered with three types of lock mechanisms 1. combo dial 2. digital 3. advanced digital the advanced digital is what you have there are no green lights on it. look at the manual carefully there are 2 seperate sections on the digital key pads yours will be the second.
Posted on Dec 18, 2009
SOURCE: cant open Sandleford Garrison Safe N15115
I have a new N15115,ES20 electronic safe,it will not accept a change of password.when new password entered it only beeps once ???
Posted on Jun 28, 2011
I have bought a used red head safe. It's open but I can't get it to close. Also, I don't have a combination for it and I'd like to make up my own. Can you help me?
Most likely it will not close because the lock has been activated while the door was open. Probably need to take it to a locksmith.
Jan 03, 2017 | Home Security
Bought this gun safe in 1998. Has a combination lock. Have the combination but it will not open safe.
If it is an electronic combination lock the batteries are probably discharged. In that case there should be a key and somewhere to put it in order to open the cabinet and replace the batteries. Electronic locks usually beep when the numbers are entered followed by a different beep if successful.
If it is beeping nice and loudly it would suggest you have the wrong code.
If it is a mechanical lock it must either be the wrong combination or the lock is broken and you will need specialist help, perhaps from the manufacturer.
Feb 08, 2016 | Locks & Locksmithing
My safe, a Cathedral EA15 Will not lock. Any suggestions people?
Instructions
  1. 1
    Enter your code on the keypad located on the front of the safe. Some electronic digital safes require you to input a special character like "#" before and after your code. The safe should either beep, have a LED turn green, or display "OPEN" if you have correctly entered the code.
  2. 2
    Turn the handle to the right within five seconds of correctly entering the code. If you wait too long, the safe will lock and you will have to enter your code ag
Open the safe with a key. Use your emergency key that came with the safe to open it if you forgot the code or if the batteries have died. Remove the key cover from either the handle or the control panel to reveal the lock.
  1. 1
    Enter your code to open the safe.
  2. 2
    Place the electronic digital safe into code reset mode. On some models you need to hold the last digit of the code or press the "*" button to get into code reset mode. Other safes require you to open them and press a small red button on the inside of the door.
  3. 3
    Enter your new code on the keypad and press "#" to finish. Some safes may require you to press "*" or a letter to finish the code. If the safe requires it, enter the new code again to confirm that you entered it correctly.
  1. 1
    Use your code to open the electronic digital safe's door.
  2. 2
    Locate and remove the battery cover on the inside of the door.
  3. 3
    Replace the used batteries with new ones. For most safes, this will require two or four AA batteries.
  4. 4
    Test the batteries. Use your code while the door is open to test the batteries before closing the safe.
Feb 08, 2015 | Locks & Locksmithing
Sports afield 6040 executive vault how to reset combination
Spot Afield safes default code is 1,2,3,4,5,6. Open the safe door, with door open lock the handle. This will let you have assess to your things if you have trouble while setting the codes. To change the code, press the * 6 times. You should hear a single beep and one flash from the LED, then enter the default code 1,2,3,4,5,6. Again you should hear one beep and see one flash. Enter the new code you would like to use ...lets say 6,5,4,3,2,1. You should hear one beep and see one flash. Enter the new code again 6,5,4,3,2,1. The code should now be set to 6,5,4,3,2,1. Try the new code and see if it unlocks the door. Also try the old code to make sure it no longer works.. If at any time during the process you hear 3 beeps and flashes something went wrong. You will need to start over.
Good Luck!!
Jun 30, 2014 | Other Sports Afield Executive Gun Safe...
How do i onreset numbers on gun safe?
Make sure you do this with the door OPEN.
Make sure that you have a fresh battery in place.
Hold down the 0 until you hear a beep twice
Make sure that you have written down your new combination before you enter it, then enter your old combination. Wait for the two beeps.
Now enter your new combination and wait for the two beeps.
Enter your new combination again, waiting for the two beeps.
Wait for 15 seconds, then enter your combination; you should now be able to turn the handle which will show that your new combination worked.
May 06, 2014 | Home Security
How do you change the code on a Legacy Safe?
Wait for 15 seconds, then enter your combination; you should now be able to turn the handle.
May 04, 2014 | Home Security
Manual for stramm digital electronic safe manual
The Stramm safe we have is a small one that we use to store keys for our drivers. To change the combination, open the safe with the current combination. Sorry, can't help you if you don't know that. Inside the door is a plastic panel covering the batteries. Pinch the plastic catch at the top and open the panel. There is a small red button which you can press to change the combination. When you press it, you will hear a double beep. Enter your desired new combination. The trick is that the last digit must be either an "A" or a "B" which signals the end of your combination. For example, if you want your new combination to be 123456, you can't do that. The closest you can come is 123456A or 123456B. Hope this helps. Steve, Mbeya, Tanzania
Apr 06, 2013 | Safe International Digital Electronic Safe...
Can't turn off beep sound on keypad of my stack-on Security Safes Electronic Lock for a 16 gun safe
You can turn off the "Beep" sound of the keypad by entering the code 633.
To turn the "Beep" sound on, enter the code 66
Feb 17, 2013 | Stack-On Stack On 16 Gun Safe with...
Just put new batterys in safe . but safe will not stop bleeping what is the problem
Please follow these steps
Programming a user code
There are two ways to program a user code.
A 1. Press the Program key.
2. Enter the Factory Code. The green LED remains ON
while you enter the 5-digit user code of your choice.
After 5 digits are entered the green LED turns OFF.
(To enter a new User Code, repeat these steps.)
B 1. Press the red button inside the safe. The lock will
beep and the green LED will come on.
2. Enter a 5-digit user code.
Keep your new user code secure.
For your records, please copy it here:
____ ____ ____ ____ ____
Programming a password
2. Press it a second time.
3. Enter your 5-digit User Code. The green LED remains ON.
4. Enter the 5-digit Password of your choice (any combination
except 00000.) After 5 digits are entered, the green LED
turns OFF.
(To enter a new Password, repeat these steps. To erase the
Password, press Program twice, enter your User Code and then
enter 00000.)
Battery replacement
Below When old batteries are removed for replacement, your Password will be voided; only Factory and User Codes will work. To
reestablish your Password, follow the directions above under
Programming a Password.
Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four bit key to the right.
5. Open the door.
Signals
Your electronic-lock safe communicates by means of several
audio/visual signals.
Red (Error) LED + three beeps indicates
one of the following:
1. You have pressed Program key out of sequence
2. You have entered an invalid code or password.
3. You have let 5 seconds or more elapse between key entries.
Green (Proceed) LED + single beep occurs
1. After entering each digit of Factory or User Code, or
Password
2. After pressing Clear key
3. After pressing Program key
Green LED only
1. Comes on after you enter a valid code/password and
remains lit during the 4-second period in which the safe
can be opened.
2. Comes ON in the Program User Code mode after you enter
the Factory Code and remains lit until you have finished
entering a 5-digit User Code.
3. Comes ON in the Program Password mode after you have
entered your User Code and remains ON until you have
entered a 5-digit password.
Yellow LED
Indicates low battery and will typically not turn ON until
battery has been in use approximately two years or longer.
Your electronic lock automatically performs a low battery test
during each lock use.
If a �low battery� condition is detected the Yellow LED will
come ON and remain ON during each subsequent lock
operation. (The lock will continue to function in a Low Battery
state, until battery failure.) The Yellow LED will turn OFF only
after three consecutive Good Battery readings or after the low
batteries are replaced. (Note: If the new batteries are installed
in less than 60 seconds the Yellow LED may come ON and stay
ON during the first lock operation before it returns to OFF.)
NOTE: It is recommended you replace the batteries after two
years, or when the yellow LED remains on.
Jan 09, 2011 | Safe International Electronic Digital Safe...
Locks & Locksmithing Logo
140 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
