Question about Hardware & Accessories
How do I setup the timer? I want it to go on at 5:00 pm and turn off at 10:00 pm. (Model)Brinks type 42-1015
    Master:
  • 504 Answers
Read the manual that came with it.
Posted on Mar 09, 2017
SOURCE: Woods Model 59200V Indoor Mechanical Timer. Not working
book says peg should be down for on and peg should be up for stop. How the hell does one pull the peg up...it is blocked and can only be pushed down...now what I am missing?
Posted on Dec 19, 2009
agent91
  • 2100 Answers
SOURCE: I want to know if
Most of those timers are 220 volts, but I think you can run just one side, 300 watts is not much at all. That is like 4 or 5 light bulbs. Just leave one wire off the timer on the line side and the load side, you only need one. You will need the neutral to run the timer. Check it out.
Posted on Dec 25, 2010
SOURCE: brinks 44-1030 manual i need a
1) Can you describe the timer in detail?
The buttons and the dial, shape, if it plugs in or is programmable, whatever you can think of to illustrate what timer looks like.
I have extensive files on timers
Most brinks timers are versions of other timers, and manuals exist for those timers.
Add a comment with the information, and I will post a manual if timer matches other brands.
2) You can open following link and see if your timer appears on the page:
Manuals appear for each timer on page with a few exceptions.
http://waterheatertimer.org/Woods-timers-and-manuals.html
3) Another step would be to buy the 44-1030 at Walmart and scan the manual into .jpg format.
Download Cute-writer the free pdf software.
Print your .jpg image but select cute-writer as the printer.
Instead of printing, the software makes a pdf manual.
I use this technique when I need a manual
Title your new manual and post it on the internet for sale.
Return the timer for a refund.
4) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you describe timer.
Posted on Jan 10, 2011
SOURCE: Need how to use my timer. Brinks digital plug in
Manual appears on following links:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
http://waterheatertimer.org/pdf/Brinks-44-1020-manual.pdf
The manual has important illustrations, and has more words than allowed for free answer.
Open manual and get as far along as you can, and then add a comment where manual is confusing and I will help.
The battery is rechargeable type, so plug timer into outlet for hour and then unplug timer to set programming.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 02, 2011
SOURCE: I have GE Model #15089
The problem with answering questions where somebody cannot program a timer, or programming stopped working, is that expert doesn't know if timer is defective, or needs to be reset, or timer has conflicting programming, or if person has mis-read the instruction manual, or if wrong button sequence is being used, or if internal battery has gone bad, or if circuit has interference or loose wiring, or if light bulb burned out, and however expert guesses, the person asking question is unhappy because the timer still doesn't work and/or the manual still doesn't make sense.
I work with timers every day and suggest the following steps to get started:
Reset timer and try setting program again.
Write out steps in manual at point where timer doesn't seem to work.
Double-check that you are pushing correct buttons all the way down.
Make sure same days of operation are selected for ON and for OFF. For example if ON is set for all days, and OFF is set for Tuesday, then timer will not work as expected.
Reset timer and make sure there are no conflicting or overlapping programs, or timer will not work as expected.
Test outlet with cheap circuit analyzer from home center, try timer on different outlet, try timer on different Load, check that Load works when plugged into outlet without the timer.
Save some headaches listed above, and buy another 15089 at Home Depot and return defective one in new package.
http://waterheatertimer.org/GE-timers-and-manuals.html#15079
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Posted on Apr 26, 2011
Brinks model 42-1050 manual?
Brinks timers and manuals: - Water Heater Timer
waterheatertimer.org/Brinks-timers-and-manuals.html
Brinks timers and manuals. ... Brinks 44-1020 manual · Brinks 42-1020 manual ·Brinks 42-1020 instructions ... 42-1050 yard stake · Invisa timer 52-9206 · Brinks ...
I need an instructions guide for Brinks timer 42-1050 - Fixya
www.fixya.com/.../t10900275-need_instructions_guide_brinks_timer_4...
Nov 28, 2011 - SOURCE: Brinks model 44-1050 digital outlet timer- I don't. I have an instruction for a Brinks 44-1030 which I believe programs the same.
Brinks-outdoor analog stake timer-42-1050 Timer will not ...
Dec 14, 2015 | Hardware & Accessories
How do I get my Brinks timer to come on at 7.30 pm and turn off at7..30 am
Do you know what model Brinks timer you have? This will help when searching for specifics on programming.
Sep 02, 2014 | Hardware & Accessories
The Brinks Model 42-1014 fails after a few weeks. The motor that turns the timer dial is not strong enought to trigger the on switch. I can move the dial by hand to turn it on and it does turn off but...
I agree.
I test timers.
Brinks timers are near lowest quality of all timer brands, yet all timer manufactures sell lower end products to meet price points. Brinks are probably made by one of the bigger brands.
http://waterheatertimer.org/UPM-timers-and-manuals.html
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
http://waterheatertimer.org/How-to-set-timers.html
Test your outlet with cheap circuit analyzer from box store to make sure that polarity of outlet is not reversed. Notice that Brinks timers, like most plug-in timers, have polarized plug.
Polarized plug has wide and narrow blades so they plug into outlet correctly.
Wide blade is for Neutral, and narrow blade is for Hot.
If outlet has polarity reversed, this will adversely affect timer motors, and other appliances.
Jun 23, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Need how to use my timer. Brinks digital plug in home timer. Model # 44-1020. 6 settings per day. Battery backup
Mar 02, 2011 | Hampton Technologies Brinks Timer
Got a brinks EZ- dial timer model42-1034B @ Walmart a few days ago can not seem to get it to work, Inst, seem so easy too. I read on some forum online someone thought the am/pm may be backwards to how it...
1) This Brinks timer is a bit lightweight for an appliance (unless for coffeemaker or tiny gerbil-feeding motor)
You might need 1/3 HP (horsepower) appliance timer like Woods 59201
http://waterheatertimer.org/Woods-timers-and-manuals.html#59201
http://www.amazon.com/Woods-59201-Appliance-Grounded-3-Prong/dp/B001Q9EFTQ
Intermatic HB113C is for heavier appliances
http://www.amazon.com/Intermatic-Hb113c/dp/B000GHKO6C
http://waterheatertimer.org/images/Intermatic-HB114C-plug-in-4.jpg
2) How to set the Brinks:
I will use lamp as example since you can easily test the timer using a lamp.
Turn lamp ON. Make sure bulb is good.
Leave lamp turned ON and plug lamp into timer.
Move slide switch one direction.
Plug timer into outlet.
Manually rotate timer dial clockwise and see if lamp turns on-off
Move slide switch other direction, and rotate dial clockwise again to see if lamp turns on-off.
Now you know which way switch has to be moved.
Push down trippers and rotate around dial until they line up with 1:00 on dark part of dial and 5:00 on dark part of dial. Dark is for pm hours.
Last step: Set current time: rotate dial clockwise until current time lines up with arrowhead located on inner dial
Dial rotates at time passes, trippers push lever that turns circuit on-off.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Jan 29, 2011 | Hampton Technologies Brinks Timer
How do i set the Brinks 44-1040 timer?
Brinks 44-1040 is a 24-hour plug-in timer, with 1 on tripper and 1 off tripper.
Dial has 24 hours with each hour marked for am and pm times.
Push tripper down and rotate until tripper aligns with time you want for ON and OFF.
Rotate dial until current time lines up with arrowhead located on inner dial.
Plug lamp into timer. and plug timer into wall.
Move slide switch one direction or the other to control mode.
When switch is one direction, lamp in ON all the time.
Move switch other direction, and timer programs work.
Dial rotates as time passes, and trippers move on-off lever that turns lamp ON-and-OFF.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Dec 24, 2010 | Hampton Technologies Brinks Timer
Jvc model av36f702 it jumps of evry time im trying to put it on with the remote . i tink the timer is set to 0 secones .can i reset the tv.
press display button & it shows the following
07
NOW 12:20 PM
SLEEP TIMER OFF/on
ON/OFF TIMER EVERYDAY
ON TIME 7:00 PM
OFF TIME 10:00 PM
• The current channel or AV input (Channel 07)
• The current time (12:20 pm)
• Sleep Timer status/minutes remaining (The Sleep Timer is off)
• On/Off Timer status (Set to turn on everyday at 7:00 PM, off at 10:00 PM)
• Each Press of the DISPLAY button changes the display mode:
Press the SLEEP TIMER button & set it to OFF
Dec 22, 2010 | JVC AV-36F702 36" TV
How do i set it
i think i figured it out. i have the same one. i bought it last year for my christmas tree lights and it worked great. but this year i can't get it right. finally i think i did. u see, since it is hard to read the dial it makes it hard to set the current time and on/off times. i will give u my example: to have the timer turn on at 4pm and off at 11pm: set the timer at 8pm ( the 8 left of the PM mark). set green marker at 4pm (left of the PM mark) set red at 11pm ( left of PM mark and just before the 12am mark. basically i think the dial is backwards so what looks like pm times is not and vice versa. Crossing my fingers, Good Luck!!
Dec 06, 2010 | Hampton Technologies Brinks Timer
Do not know how to set the brinks 44-1060 timer.
Push down the "ON" tab and move it to the time of day that you want the switched device to come on. Push down the "OFF" tab and move it to the time of day that you want the device to go off. Rotate the dial in the direction of the arrow to the current time of day, watching for am/pm.
If the device is supposed to be on currently, use manual switch to turn device on. If the device is supposed to be off currently, use manual switch to turn device off.
Nov 30, 2010 | Hampton Technologies Brinks Timer
Hardware & Accessories Logo
315 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
