How to you fix the click on model 000285 jukebox lamp. It runs really fast
One injector not working
USA forum and no KBs sold in USA>
no engine posted, sizes and if petrol or diesel.
im looking in Africa, now, and see a 220 listed as gas.
is that it?
KBs started in 1997
then
2001 is Faster Gen. series 3
sold world wide under, 19 names.
wiki:
"Holden Rodeo was the only name used in Australasia, with the Isuzu KB name used in South Africa and some other markets. "
and sold out of Chilean plant. and others, in SA.
and
From 1999 and to little success, Thai Rung Union Car supplied the Chevrolet plant in Africa
best i can tell is its an...
engine real name.
It is code-named C22NE and 22LE.
so this is petrol with 4 injections. right?
and one is dead and engine runs rough, right?
and you found the number x spark dry. (yes?)_
does coil on this injector read the same as the other 3? unplugged, yes. (dmm meter set to OHMS)
does it>? if not it's bad. the one reading wrong.
next, does an attached NOID lamp flash cranked/ or running,
does the $5 stethoscope show it clicking, running?
if no, then the wires to injector x are bad.
or the ECU has blown injectors transistor driver.
the last test with good ecu, and wires
is to do an injector leakdown test with a fuel pressure gauge, (text book tests all are here)
and then do the balance test, (in the book)
if that is how you found the injector x dead.
the check the injector signals.
there are many ways to do that.
click (sound ) there is a magnetic tool too.
scope signals. ? dead on x.
one pin has 12vdc keyon too all 4 injectors does it>
then NOID lamp. tests.
the noid tests, checks for 2 basic failures.
stuck on , glows key on,
or dead injector, crank or running.
any tiny non LED lamps works. for a NOID.
the signal is fast, 3/1000th of a second fast.
and humans cant see that fast.
so only special tools allow you to do that.
even a 50cent lamp, i use 12v, 0.050amps) lamp.
low current lamps are safest to not overload any ECU.
if confused, get car serviced.
and last, (really its first)
did you SCAN THE ECU first.?
Jun 18, 2016 | Isuzu Cars & Trucks
Jukebox manual
Many on eBay
http://www.ebay.com/itm/Original-Rockola-Jukebox-Model-488-Service-Manual-w-wiring-diagrams-/231244858100?pt=LH_DefaultDomain_0&hash=item35d74482f4 Original Rockola Jukebox Model 488 Service Manual wiring diagrams
Aug 05, 2014 | Collectibles Jukeboxes Book Rockola...
I have Musicmatch Jukebox 10 but have just changed over to Windows 7.I have a Packard Bell Hard Drive.How do I update from xp please ?
Musicmatch Jukebox 10 is not compatible with windows 7 >>
http://www.microsoft.com/windows/compatibility/windows-7/
MusicMatch Jukebox 10 was designed to be used on older 32-bit operating systems like Windows XP.Note that MusicMatch Jukebox 10 is also no longer being developed, so it is unlikely that these problems will be resolved in future.
Before proceeding with installation of Musicmatch Jukebox 10, you need to look on your Windows 7 PC for any previous versions of Musicmatch Jukebox. If you've already tried installing version 8, for example, then you need to run a complete uninstall, not to mention a good clean up of the registry.Use Revo uninstaller to uninstall and clean any registry trash ,revo uninstaller can be downloaded on the link below:
http://www.revouninstaller.com/revo_uninstaller_free_download.html
Once you have done this, or if you had no earlier versions of Musicmatch Jukebox installed, you will need to download and install the only suitable version.Download and Install Musicmatch Jukebox 10 on Windows 7 >>http://musicmatch-jukebox.com/
Once downloaded, right-click the installer file and select Run as Administrator. Next, you will need to OK the first of many warnings that the file is incompatible with this version of Windows.Proceed through the installer, clicking Next at each option.When you come to the registration page, click the option to not register and also claim to be under 13. Click Next to complete more steps of the installation, changing the location required for your Music folder if necessary. Musicmatch Jukebox 10 will add files and playlists to this location.As the installer finishes, you will be prompted to install the Yahoo! toolbar. You will need to deselect this.A successful installation should result in more incompatibility warnings. Ignore these, but agree to reboot your PC. Next right click Musicmatch Jukebox icon and select properties > compatibility >check run this program in compatibility mode for: (Windows XP) click apply ->ok.
Nov 13, 2011 | Audio Players & Recorders
Heeelp > My 1960 wurrlitzer jukebox is dead ?
you really need a service manual you can get it at jukeboxworld go to archives then wurlitzer then choose your model
Mar 31, 2010 | Wurlitzer Jukebox Princess 120-Disc CD...
All lights not working
CHECK FOR 115 POWER LINES GOING TO FLORCENT LAMPS. CHECK FOR 115 POWER LINES GOING TO FLORCENT LAMP
May 19, 2009 | Wurlitzer Jukebox CD Player
Musicmatch Jukebox shows just PSS instead of PSS110.
This is the LEAST of your problems - the official MusicMatch service was cancelled in October 2007, so you are only going to get limited functionality out of this player in the first palce. If the jukebox is working, don't mess with it. If it is not working:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
-Tha Mp3 Doctor
Jan 24, 2009 | Philips PSS110/17 MP3 Player
Cd wheel spining non stop
ITS NOT THE WHEEL SPINNING ITS THE LASER ITS TRYING TO READ THE DISC THAT CAUSE IT TO SPIN FAST AND SLOW FAST AND SLOW YOUR LASER NEEDS A CLEAN
Jun 27, 2008 | Wurlitzer Jukebox 1015 One More Time...
Rowe ami jukebox
Check the optical sensor, it may be blocked with dust.
Jun 09, 2008 | Audio Players & Recorders
Rowe CD 100 err 05-62
have a cd100c and a check sum error comes up anyone know what it is
Dec 21, 2007 | Wurlitzer Jukebox CD Player
37 people viewed this question
 Grubhead
Grubhead
