Question about Kenwood Car Audio & Video
Dear sir or madam :I have a M929 Kenwood car radio & md player.I need the Pin's specification (24 pins) of it's Tuner.this code is written on it's PCB:J74-0686-52 Best regards-M.Asiaban
How do i find out what my puk code or pin code is on my phone
The default PIN code for nokia mobile are
PIN 1: 1234
PIN 2: 1234
and The security code is 12345
To get the PUK code you need to call to your service provider.they wil giive you the PUK code.You should give your informationsso that the service provider officer will cross check it with the database that they have and they wil give you the PUK code
Jul 18, 2010 | Nokia 5230 Cell Phone
I took the battery out of and now my Kenwood Stereo asks for a code.
Reset the radio by pushing the small button on left side of the #1 preset. it is probably pulling the code for the anti theft protection. if you already have a lock code use it to unlock the tuner otherwise reset the tuner
Mar 24, 2010 | Kenwood KDC-135 CD Player
Its Radio from my junked 2000 dodge - I need to know pin inputs
yes it wil if you dont know the circuit layer of the radio wiring
Jun 25, 2009 | Kenwood KDC-MP235 CD Player
Looking for code for CDR500 ( vauxhall Zafira 2003)
Dear Sir,
We got problem to audio of zafira 2002. we need pin lock code for playing radio and CD player.
thank you for cooperation
May 28, 2008 | Car Audio & Video
SAT Radio installation
What you need is the SCC1 (Sirius tuner) and the KCA-SR50 (Kenwood adapter). The ESN number can be found on bottom of SCC1 before you install it.
Mar 17, 2008 | Kenwood KDC-MP435U CD Player
Need a wire color code for a ford radio f58f-18c815-aa
Notice, this is from the 2005 Ford F150 Wiring Harness. Other radios should be the same or very close. From the main 24 wire connector on back of radio (C290A).
Pin 1- Light Green w/Violet stripe - Voltage always
Pin 2- Light Green w/Yellow - Accessory delay relay output
Pin 3- Light Blue w/Red - Instrument illumination
Pin 4- Black - Ground
Pins 5, 6, & 7 - Not used
Pin 8- Orange w/Light Green - Speaker, left front +
Pin 9- Grey w/Light Blue - Speaker, left rear +
Pin 10- Orange w/Red - Speaker, right rear +
Pin 11- White w/Light Green- Speaker, right front +
Pin 12- Dark Green w/Orange- Speaker, right frt -
Pin 13- Black w/Light Green- Ground
Pin 14- Grey w/Black- Vehicle Speed Signal
Pin 15- Red w/Black- Voltage supplied in Start
Pins 16 & 17- Not used
Pin 18- Light Blue w/Red- steering wheel signal
Pin 19- Dark Green w/Orange- steering wheel return
Pin 20- Dark Blue- Parking Aid mute signal
Pin 21- Light Blue w/White- Speaker, left front -
Pin 22- Tan w/Yellow- Speaker, left rear -
Pin 23- Brown w/Pink- Speaker, right rear -
Pin 24- Not used
Good Luck
Feb 09, 2008 | Car Audio & Video
Forgotten pin number
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Sep 03, 2007 | Kenwood KDC-519 CD Player
Auxillary option not available in menu
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Jul 01, 2007 | Kenwood KDC-MP628 CD Player
Will not play
on the front panel, look for a tiny pinhole and insert a pin while powered up to reset
May 27, 2007 | Kenwood KDC-MP228 CD Player
Car Audio & Video Logo
37 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
