I have a SAMs 4 till ,it says mode error please help
I bought this tv at sams club but didnt use it right away then Iused it for about 4 months then one day it wouldnt turn on at all please help me as Im unemployed
Take it back to Sams Club and explain to them what happened - 95% chance they'll exchange it because Costco in California does. I believe they are owned by the same company. Hopefully you still have the receipt.
Nov 18, 2010 | Televison & Video
I cannot send or receive faxes. The Transmission Error report says phone line error. I don't know how to set up the fax software; cannot find my Lexmark x8350 manual. Thank you.
Please follow the steps given below:
1. Press "Fax Mode" button.
2. Press "Menu" button.
3. Use the "Down Arrow" till the display reads "Maintenance."
4. Press "Select."
5. Use the "Down Arrow" buttons till the display reads "Reset Defaults."
6. Press key pad "1."
7. Press "Select."
Please let us know the results.
This will restore to factory default
Jun 20, 2010 | Lexmark X8350 InkJet Printer
Cant send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 27, 2009 | Lexmark X6170 All-In-One InkJet Printer
Can't send faxes. Dials Ok but no connection to send fax
May 19, 2009 | Lexmark X4270 All-in-One Multifunction...
Took memory card out to print at Sams Club- said "No image"? placed memory card back in camera and when turned on camera diplay said "No Image"? did not delete them- are they in camera and I can recov
Most cameras have built in memory. Remove memory card and turn camera on in play mode. If you see the pics then they in cam memory ; take camera to photoshop they will download it for you.
Please tell me you found them I have a 2nd grader and I know how imporant these memories are for us especially.
May 12, 2009 | Canon PowerShot A470 Digital Camera
Cannot send a fax
Apr 29, 2009 | Lexmark X4270 All-In-One InkJet Printer
Can send faxes but cannot receive - shuts off after 2 rings
Apr 19, 2009 | Lexmark X4270 All-In-One InkJet Printer
3650 phone start up failed pls help me
u have to reset or mobile ..to do that follow this
1. Removed your MMC card first.
2. Make sure you have at least 3/4 charge of battery before performing the
" Safe Mode, and follow-by phone reset *#7370# ". Or maybe you can have the
charger on and plugged into the phone to act as a full power source.
3. Press and hold the ABC key and then press the power button.
Remember not to release the ABC key till you seen the
"Safe Mode" standby screen.
(Fyi, there's no special indicator that telling yo're on a "Safe Mode"
standby screen.)
4. Once in the "Safe Mode" stanby screen press *#7370# to carry-out "Phone Reset"
task.
5. Once "Phone Reset" task completed and back to normal standby screen again,
switch off your phone and re-insert your MMCmag-glass_10x10.gif card.
If any error showing on the phone boot-up, please have the memory card formatted and by next phone
start-up you will not have the error msg again.
If you some important data or programs files on your MMC card, please use
a card reader to have them copied onto a pc before performing memory card
formatting
Dec 04, 2008 | Nokia 3650
Sylvania 37-Inch LCD/DVD combo HDTV remote code for Scientific Atlanta 8003
You can find the sylvania 37" LCD/DVD COMBO at Sam's club for 597.00 it is a special item for sams club. If you go to sams club on line you cna locate what sams club has this tv in stock but hurry they are going fast and there model number is LD370SC8. I am not sure where you are located but please start your search now and if you do not have a sams culb card you can get the lowest priced membership possible and due to the low cost the price of a membership is worth it.
I hope I have helped?
Noreen
Sep 09, 2008 | Televison & Video
26 people viewed this question
k24674
