Question about Home
1225 cartridge replace - Home
Having great difficulty removing old Moen 1225 to install new one. Can not figure out why? Followed both written and video instructions. Any thoughts? Thank you.
Hi! You can buy or rent a cartridge puller for Moen's 1225 cartridge. Try Home Depot or your local hardware store or online at part #104421
Mar 07, 2015 | Moen Plumbing
How to remove rubber seals from inside moen 1225 faucet body
Make a cutter from the old cartridge. Cut some slots in the base that normally sits on the seal. Use a hacksaw or grinderette.
Clean up with a file to prevent damage to the sealing face. Insert the old cartridge back and give it a few gentle turns with minimum pressure. Remove 'cutter' and flush out debris.
Oct 26, 2017 | Home
Just replaced the cartridge in a Moen single handled kitchen faucet with a 1225 cartridge. The old one was leaking at the top of the stem. Now I get warm to the far right and left with hot in the center....
Sounds like you put cartridge in 90 degrees wrong. Did you take it apart and check to see if you ligned up the tabs correctly? If they are in correctly you have gotten the wrong cartridge replacement.
May 31, 2014 | Plumbing
Do any plumbing stores carry moen 12801 replacement cartridges
I am not familiar with that cartridge, but most hardware stores and plumbing supply houses should have Moen parts. #'s 1224, 1225, 1200 and 1222 are the cartridges I'm familiar with.Bring the part with you.
May 19, 2014 | Moen & Replacement Cartridge
I need replacement part for bath sink cartridge 4570
The Moen 1225 or 1200 cartridges are the same except the 1200 is brass in stead of plastic. They will fit most Moen single handle faucets. If it is a two-handle faucet, the 1224 cartridge will fit most two-handle models unless it is a fancy widespread faucet more than about 15 years old. I don't know the model numbers for those cartridges. All of these cartridges require a removal tool if you can't get them out with a pair of pliers.
Dec 09, 2011 | Moen Soap & Lotion Dispenser 3910S
Need step by step directions to replace cartridge in one handled Moen bathroom faucet
If this is a Moen 1225/1200 cartridge, try this link at the Moen site for instructions. You can even click on a link at the top of that site for a step-by-step Animation Enhanced turotial that is very helpful.
If it is a different cartridge, try searching that site for the specific number of your cartridge for instructions.
Sep 23, 2010 | Moen & Replacement Cartridge
Faucet is leaking. Can you tell me if this is a
yes it is a cartridge replacement,the cartridge is,should be all that you need to did not list what kind of faucet. so here is a few number's. some bath/shower valves' take#1225-(plastic) this is also use'd in some kitchen,lav, model's.two handle faucet's#1224,the "posi-temp"#1222 is a tub shower only,there are cartridge puller's available,and recomened them,one is made by moen,another by brass craft,i have pulled cartridge's with out,so it is up to you.hope this help's.
Nov 03, 2009 | Moen & Replacement Cartridge
Moen fauset # 1225 Shower new cartridge and it still drips.
is it official moen 1225 ? generics can be of poor quality. turn off house water and remove cartridge. Small fingers? Put in valve and feel for debris or turn on whole house again for a few seconds to flush out valve. try another cartridge. Or try this first. take off handle and push in on stem. does drip stop. ? perhaps handle is not on right.
Apr 28, 2009 | Moen Plumbing
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
