Question about Brother Mfc-7360
Brother 7360 scan unable - Brother Mfc-7360
Scanning flatbed When I put a paper to scan on the window it comes with lines and if i do a clear scan. Empty so it's OK
Hi clean the window with a dry cloth and if you know how to adjust your contrast then adjust the scan contrast to +30... That should stop the lines.
Mar 30, 2016 | Brother Mfc-7360
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
Jan 14, 2015 | Brother MFC 7360N - Multifunction fax /...
How to reset brother j125 printer's ink absorber full
Go To Below official brother Printer Page For Your problem Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Brother Printer Support
May 04, 2014 | Brother DCP-J125 Inkjet Multifunction...
Unable to clean 5a
If one of the following messages is displayed on Your Printer,I suggest You Go To Below Official Brother Website For Troubleshooting,
  • Unable to Clean (Clean Unable)
  • Unable to Init. (Init Unable)
  • Unable to Print (Print Unable)
  • Unable to Scan (Scan Unable)
Or If You FaceProble Then Follows Us On For Online
Jan 08, 2014 | Brother MFC-465CN InkJet Printer
I have brother DCP 7055 it shows print unable 71 error pls suggest
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
Dec 18, 2012 | Brother Dcp-7055 Laser Print Copy Scan...
Brother Mfc-7360 Logo
67 people viewed this question
James Cagle
James Cagle
Jim Keysor
