No voltage to pump.
I replaced the pump and the washer still does not work. I checked the voltage to the pump by putting it into spin and drain only. The recycle pump kicks on for a moment and then the drain pump is supposed to start but does not. That is when I checked for the 120 volts and I had nothing. The washer did drain all of the sudden at one point today, but then stopped after about 5 seconds of running.
catriver
  • 878 Answers
SOURCE: drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Posted on Nov 05, 2006
catriver
  • 878 Answers
SOURCE: Washer will not pass wash cycle...Will not Drain
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad timer....Catriver..post back.
Posted on Nov 08, 2006
  • 209 Answers
SOURCE: Wont power on after replacing drain pump.
could be just the fuse, but failing that check all circuit boards for signs of blowing or burns, some machines when there is a short on the pump blow the circuit on the timer which is the most expensive part to replace best of luck
Posted on Oct 07, 2007
  • 1003 Answers
SOURCE: Hoover washer Time 1600 H160E UK stops mid cycle with flashing lights
REPLACE TIMER OR POWER CONTROL BOARD
Posted on Feb 02, 2008
  • 30 Answers
SOURCE: Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Posted on Mar 14, 2008
How do i fix Samsung WF337AAR/XAA, water pump does not power?
some makers used a neutral from inter lock make a test lamp up ie bed side lamp if uve no multy meter
Apr 21, 2015 | Samsung Washing Machines
Drain pump
follow this steps and fix it. God bless you
Drain Pump Filter
This is the most common problem. Some have a small cover in the lower front put a screwdriver in the hole and turn counterclockwise to remove. There will be a cover to remove, water will come out so be prepared with a towel or wet vac. Clean this out. Other Machines will need to access the drain pump to get to the filter. This can be done by remove back panel on some washers. On others you will need to remove the lower panel or complete front panel depending on model. The filter is located inside the large hose from the tub to the pump. remote the hose and filter.
Drain Pump
The drain pump may have failed. If you hear it making noises you will need to remove the drain pump and check for obstructions, broken impeller, or not spinning freely. Remove obstructions if it does not spin freely replace the drain pump. If you hear it hum replace the pump if nothing is found inside. If no noise is heard check the pump for power. To do this remove the wire connectors and connect a voltmeter turn to a drain cycle, refer to tech sheet or service manual for proper voltage reading, usually any voltage would probally indicate a faulty pump. If no voltage to the pump replace the main control board.
Hoses
Check the hoses from the pump by disconnecting them and make sure there are no obstructions. Check your hoes drain, if it is a slow drain this can cause your washer to not properly drain.
Jul 13, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
WASHER IS NOT DRAINING
see this causes and fix it. God bless you
Drain Pump Filter
This is the most common problem. Some have a small cover in the lower front put a screwdriver in the hole and turn counterclockwise to remove. There will be a cover to remove, water will come out so be prepared with a towel or wet vac. Clean this out. Other Machines will need to access the drain pump to get to the filter. This can be done by removing the back panel on some washers. On others you will need to remove the lower panel or complete front panel depending on model. The filter is located inside the large hose from the tub to the pump. Remove the hose and clean filter.
Drain Pump
Hoses
Oct 11, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Water not flowing
SEE this causes and fix it. God bless you
Drain Pump Filter
Drain Pump
Hoses
Sep 25, 2012 | LG WM-2277HW Front Load Washer
Not washing or draining
see the causes and fix it. use the common sense. God bless you
Drain Pump Filter
Drain Pump
Hoses
Sep 22, 2012 | Zanussi ZWF1630 Front Load Washer
Indesit iwc6145 washing machine all lights flashed now not spinning or draining??
see the causes and fix it. God bless you
Drain Pump Filter
Drain Pump
Hoses
Sep 22, 2012 | Washing Machines
Oe message on lg front loader washer model wm2277hb. wont drain or spin. already check the drain filter and hose. what else could be wrong
It is a long drain error and occurs when the washer is not fully drained after 10 minutes of draining. Remove the cabinet cover and check the following:
  1. Drain Pump Connector The connector may be disconnected or disassembled. Reassemble or repair if necessary.
  2. Drain pump coil
    Check pump coil resistance between the terminals using an ohmmeter. Resistance should be between 10-20 ohms. If the resistance is too high or too low, replace the drain pump.
  3. Voltage Check the voltage between the connector in step 1 during spin. The voltage should be 120Vac, else replace the main board assembly
Main board replacement:
  1. Disconnect the power connector and sensor switch assembly.
  2. Remove the main board protective cover.
  3. Disconnect the connectors.
  4. Remove the screw on the back of the main board.
  5. Slide the main board to the right then pull it up.
  6. Replace the main board in reverse order above.
Nov 24, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
OE Code LG washer - cleaned filter, checked pump still not working. Checked pump for power when should be draining and found no power to it. Pump not being told to drain. Help?
It is a long drain error. The washer is not fully drained after 10 minutes of draining. Remove the cabinet cover and check the following:
  1. Connector The connector may disconnected or disassembled. Reassemble or repair if necessary.
  2. Drain pump coil
Nov 10, 2009 | LG WM-2277HW Front Load Washer
Washer won't drain and clothes stay soaked
Can you give me a model and brand name. Does the washer drain at any time during the wash cycle?
Will it go into a spin at all in any setting? heavy duty, normal and delicate cycle? is water not draining?
Jan 11, 2009 | Frigidaire ATF6000ES Front Load Washer
Will not drain
Hi smonalisax,
If you washer is not draining you could have a problem with your lid switch. It will also cause the washer not to spin or pump. If your washer tries to spin then stops it is not the lid switch.
If it tries to spin you should next check your pump. Your pump could have an obstruction in it. Like a sock or hair pin. For this problem remove the hoses from the pump and clear obstruction be ready for the flood of water. you may want to dip the water out before you do any hose removal. If you do not find anything in the pump, check voltage to the pump. To do this put the machine in spin and start. read the voltage going to the pump. If you have voltage and it is not pumping, you will need a new pump. If you have no voltage and the lid switch is good, you will most likely need a new timer. Good luck and I really hope this will FIXYA.
Mike Anderson
May 08, 2008 | Haier XQJ50-31 Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
