Question about Refrigerators
Does a defy c315 fridge have a fan.thank you - Refrigerators
Hi i have a defy f640 SS fridge...the freezer side works fine...but the fridge side is not cold as before...please help
It could be that your evaporator fan motor has broken ... which for some refrigerators results in your symptoms of good freezer temperature and too warm in the fridge side. I am not familiar with your model so there could be other issues.
Jan 11, 2018 | Refrigerators
What is the problem if i fit a new domestic defy fridge thermostat with the same part it still stays running and not cycle.
what temp is in the fridge around 4 degrees and freezer -18 degrees and does the eveporator fully flood with with refrigerant if yes then try checking defrost timer is moving from its position also check is both fans runs
Oct 04, 2016 | Refrigerators
Defy fridge f640 wiring diagram faulty compressor or thermostat
Hi my name is jp. Got a defy f640 the freezer not working. Trips power. Wires been removed at back of the compressor. Need to know where the wires need to go
Dec 22, 2012 | Refrigerators
I have defy fridge/freezer combo c380, freezer gets cold at bottom but fridge above does not want to, what can be the problem?
Defrost cycle has problems. Could be defrost timer, heat element, or defrost stat. temporary solution, if you can see ice accumulated inside the fridge on the back wall, desconnect or turn it off, until this ice it's gone, can be use for couple days, until service could be done on it.
Dec 23, 2009 | Refrigerators
DEFY C361 Double door fridge that does'nt get cold
We solved this by replacing the thermostat with a new one.
Sep 11, 2009 | Freezers
I have a defy gemini petit chef multi function themofan oven but dont have a manual on how to use would you be kind enough to let me no how to us it thanks naaz
i have a defy gemini petit chef thermo fan oven.I only used it for about 20 times the warranty is over the fan works but the elements are not getting hot both the grill and bake.could you please tell me what the problem could be
Apr 01, 2009 | Ovens
Defy Side x Side Refrigerator Freezer
Hissing is not good. You could have lost the gas.
Apr 28, 2017 | Refrigerators
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
