Question about Saws
WE need the on off swich for plasplug power master wet dry saw
    Top Expert:
  • Saws Master
  • 8,302 Answers
You could try looking around the internet or try ebay.
Posted on Dec 14, 2016
How to access the blade on my plasplug wet tile cutting machine
Depending on the model you should be able to lift of on side of the cutting deck
Jan 31, 2017 | Blade Saws
DWW105US replacement motor
there is no 105us but there is 100 and 110 and 150,it is actually a plasplugs tool heres the pdf manual for the dww100
http://www.plasplugs.com/manuals/DWW100.pdf
the 110mt
http://www.plasplugs.com/manuals/DWW110MT.pdf
dww150
http://www.plasplugs.com/manuals/DWW150.pdf
there is also a 1 year guarantee,
Support Shop help
You don't need a Paypal account to buy from us, just select Paypal and then add your credit card details no need to log in.
If you are having problems using this store please contact us at:
Plasplugs Products Limited
Windsor House,
Windsor Industrial Estate,
Hawkins Lane,
Burton upon trent
DE14 1QF
VAT Registration no. GB 130 0581 64
To contact us by telephone, please call 0800 840 6820.lines are open 0830hrs 1730hrs Monday to Thursday and 0830hrs to 1430hrs on Friday, excluding Bank Holidays.To contact us online please complete e-mail sales@qep.com
http://www.plasplugs.com/index.php?main_page=page&id=19
Apr 21, 2015 | Saws
Switch won't work
Take it apart and fix the switch or put a new, different switch in the circuit. May just be a broken wire. Jack
Nov 23, 2013 | Roberts 10-22500 QEP 7 Tile Wet Saw
I'm trying to change the blade on my Plasplugs tile wet saw, after not having used it for over three years. No matter what I do, I can't get the nut off! I've tried WD-40, graphite, hammering...
Try rotating the nut COUNTER-CLOCKWISE.
Usually, nuts and bolts are Righty-Tighty, Lefty-Loosy, but frequently saw blad nuts use a Lefty-Tighty, Righty-Loosy.
They are built so that when the blade starts to turn, it puts a momentum on the nut that tightens it, so that a loose nut won't come flying off, and get someone injured.
Jun 26, 2011 | RTO Plasplugs DWW406US Power Master Wet...
Instructions
I found the instructions at the website www.plasplugs,com you can download them or print them.
Nov 16, 2009 | RTO Plasplugs inc No. TLC207 Tile Cutter
Clutch master cylinder
Why do you think you have a problem with the master cylinder. If it is dry it means the fluid has been lost somewhere in the system and the master cylinder is not necessarily at fault. When yo say the slave is wet, do you mean it is wet on the outside or still contains fluid? If it is wet on the outside then that is the problem. If you cant find a leak then try filling up the master cylinder reservoir again and bleed the system...it might be ok. Rebuilding is a simple job, you just need a set of cir-clip pliers but you need to check the bore carefully because you get pitting and corrosion that prevents the o rings sealing. In some cases the units need to be resleeved whilst in others a light hone is sufficient to restore the surface.
Sep 11, 2009 | 1984 Honda CB 700 SC Nighthawk
How to fix a tile saw pump
take it all apart and clean it completely. They do not put pump in saw water, use only totally fresh and clean water.
Jul 14, 2009 | RTO 6391K Felker 24" Tile Master Plus Wet...
Need to change the blade on a plasplugs diamond wheel wet saw
The shaft threads seemed to be stripped and you may have to get a set of Torx bits or if not then one bit for the torx screws to take them off. If the threads are stripped on the shaft then you may have to replace it.
Ken S.
Mar 23, 2009 | Saws
How do I change a diamond blade on the Plasplugs DWW082 tile cutter
i think u may be able to find manuals @ 911 manuals.com
Sep 08, 2008 | Saws
Tile Saw
i know blades on tile saws don't have to be super tight, i'm not familar with that kind of saw, i put a wrench on the nut and hold on to the blade with my hand and hit the wrench with a rubber mallet, and of course have the unit unplugged
Aug 31, 2008 | Saws
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
