My till says mode error and will do nothing not even when I press clear
3 Suggested Answers
  • 320 Answers
SOURCE: fix system error
Please click on the below link or copy the URL and paste it in your web browser. Follow the steps..
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:93:0:0&docid=ENUS547
OR
If you are getting any type of 'CLEAR SYSTEM ERROR' on the LCD screen of the printer, please follow these steps:
1) Remove the power cable for 2 minutes and the USB cable from behind the printer.
2) Press and hold down the stop clear button and reconnect the power cable back to printer.
3) The printer LCD screen should clear the memory error.
4) If the same error message persist on the LCD screen, please follow the instructions below.
5) Unplug the power cable for 2 minutes and USB cables from behind the printer and open the printer cover and remove both ink carts.
6) Repeat step 2 and Install both cartridges then the screen will display Cartridge's clean, press start.
Thank you........
Posted on Sep 29, 2008
Electroboy
  • 1766 Answers
SOURCE: Casio TE 4500f till register,
You have turned the key before you finished in the previous mode. Turn the key until the mode error stops (not counting the off position). That is the mode you need to finish. Try pressing SUBTOTAL in this mode and then turn the key
Posted on Sep 12, 2011
How to solve E000001-0002 canon ir3300 error code
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
Mar 03, 2018 | Canon Office Equipment & Supplies
Reset Error codes
Select copier
select clear
select ERR
press OK
Jul 02, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon code E000001-0002
press the #2 and #8 at the same time (simultaneously)
Select copier
select clear
select ERR
press OK
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils at 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Oct 21, 2015 | Canon Office Equipment & Supplies
How do i access sp5985 on a ricoh mp c5501
Try
107 press and hold stop button till service mode comes up.
OR
806182 press and hold stop button till service mode comes up.
Feb 13, 2015 | Ricoh Aficio Office Equipment & Supplies
I am getting error code E000001-0002 in my IMAGE COPPIER 3545.... how to solve it
Select copier
select clear
select ERR
press OK
****IMPORTANT****
Dec 20, 2014 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
Casio TE 4500f till register, trying to print Z report but it says error code 001 - wrong mode and will not allow me to clear. I have tried turning key back, even tried PGM key according to user manual...
Sep 12, 2011 | Casio Parts Cash Register PC Desktop
Ir6000 error code e246-0002
Select copier
select clear
select ERR
press OK
****IMPORTANT****
Jan 11, 2011 | Canon Office Equipment & Supplies
I have a ricoh aficio 2035 that reads error sc 546 problem
It is fuser code, to reset enter the sevice mode by pressing All clear 1,0,7 & Keeping Stop button pressing, Press the copy Mode, then OFF & ON the m/c, the code will cleared.
Aug 17, 2009 | Ricoh Aficio 450 Copier
Error message on screen E000001-0002
Sep 21, 2007 | Canon imageRUNNER 2200
Cant get rid of blinking error message, nothing works
The correct buttons to push in order to get into the service mode on a 162D are [#] key, [*] key, [C] key and [*] key. Then you key in 14 - 00 and press the Start key. If that fails to bring your machine back on, you'll have to replace the fusing assembly.
Apr 12, 2007 | Toshiba e-Studio162D Copier
21 people viewed this question
k24674
jasbo
jasbo
