Question about Ovens
F5EI error can I bypass oven door lock - Ovens
    Master:
  • 610 Answers
Oven not working
F9 Door Latch Error Check latch and latch circuit
F9 Door Lock Warning Check door lock circuit or Replace Clock
F9 Program with door circuit Check wiring
4 different brands of stove indicate an issue with the door lock circuit. Hunt down the the tech manual for your machine on my youtube channel video
May 05, 2013 | Ovens
No power, door locked
there are 2 thermal switches within the component area in front of the fan of the oven, they open and close like a switch at certain temps,if one of these go bad (stays open after oven clean cycle)and oven cools then it wont let power back to the unlock motor,you can access these switches and bypass them to test them,if lock works then merely replace that particular switch
Feb 04, 2013 | GE Ovens
F5E1 or FSE1 error code DOOR LOCKED LATCH NOT OPERATING
On this double oven, each door has it's own latch mechanism that consists of a motor, a position switch, and the door switch used to activate the cavity lights. Because the error indicated a latch failure (and the bottom door was locked), Start by cycling the power to the unit. Each time the power is removed and then applied to these ovens, both latches will lock then unlock the doors to ensure they are in the home open position. By doing so, you might be able to get the bottom oven door opened allowing me access to the latch assembly. With the latch removed, I try to begin a clean cycle so you could watch the motor operate and you will probably find that it will start to turn, but never would rotate enough to lock the door. Since the position switch was not actuated at the end of the motor operation, the F5 E1 error was again displayed. Replace the motor assembly
E
Nov 23, 2011 | KitchenAid Architect Series KEMC308KSS...
What does the F-9 code for a Ge oven mean
An F9 error code on a General Electric (GE) oven indicates that the oven's electronic control system has detected a problem with the automatic door lock. The automatic door lock mechanism prevents the oven door from being opened when the oven is set for "Clean" mode. The malfunction may be a jammed door lock mechanism, a pinched or broken wire, a faulty lock switch or a fault in the control board itself.
Jun 17, 2011 | GE Ovens
I tried to "clean" the oven and only got a F9
The F9 error code indicates a problem with the oven door lock assembly. The door lock assembly will need to be checked and replaced if defective. If the door lock assembly is okay, then the electronic oven control board will need to be replaced.
Feb 07, 2011 | Maytag Ovens
Got error code F9 while oven cleaning in process. What does this mean?
9 out of 10 times the lock switch has failed.
STEP # 1 - Disconnect power to the oven!!
  • Step 2 Open the oven door. Remove three screws from underneath the oven's control panel. Lift the control panel straight up to disengage the mounting pins on the top corners of the panel, then tip the panel toward you.
  • Step 3 Inspect the door lock mechanism. The mechanism is in the lower left area of the space behind the control panel. Rotate the cam on the door lock mechanism to be certain it moves without binding. Replace the mechanism if its mechanical parts do not function properly.
  • Step 4 Inspect the wires that connect the door lock mechanism to the control panel. Check for pinched or broken wires. Check for wires with frayed insulation2_bing.gif. Repair wires as needed if defects are present.
  • Step 5 Locate the six-pin connector on the door lock motor on the right end of the door lock mechanism.
  • Step 6 Rotate the cam on the door lock mechanism to the unlocked position. Test the resistance between Pin 3 and Pin 1 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 2 of the door lock mechanism if the resistance reads other than 0.
  • Step 7 Rotate the cam on the door lock mechanism to the locked position. Test the resistance between Pin 3 and Pin 2 of the door lock connector with the ohmmeter. The resistance should be 0. Replace Lock Switch 1 of the door lock mechanism if the resistance reads other than 0.
  • Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Apr 01, 2010 | GE Profile JTP56 Electric Double Oven
    E1 F5 Error on Whirlpool Accubake Oven
    The lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed srew driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
    Apr 07, 2009 | Ovens
    E-1 F-5
    After cleaning the oven the oven door remained locked and this error displayed E-1 F-5
    Jan 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    F93 error
    F93 error code means Maximum oven door lock time exceeded. Check oven door lock/door lock switchs.hope this helps
    Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Over door locked
    Error code F93 means the lock motor assembly spent too much time to lock. Someone needs to read the continuity of the lock switches and the door switch and apply 120 volts ac to the lock motor to see if it will run. If the oven is less than 1 year old you should schedule service and let a technician diagnose and repair the problem. If you want to repair the oven yourself make the checks with a volt/ohm meter and send another email if you need more advice.
    Dec 17, 2008 | Frigidaire FGB24S5A Gas Single Oven
    Ovens Logo
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
